Jack rush 0 #1 Posted June 13, 2017 Hi ive got a peerless 800 gearbox and i have rebuilt it but as i tighten the casing the differencial axle tightens likely to be a cog/sprocket not sitting right and or washer in the wrong place has anyone got a photo of the inside of the gearbox please thanks in advance Share this post Link to post Share on other sites
the showman 4,074 #2 Posted June 13, 2017 Try this Jack, it should cover yours. http://www.wheelhorseforum.com/files/file/2087-transmission-gear-peerless-sm-01-02-691218pdf/ Share this post Link to post Share on other sites
Jack rush 0 #3 Posted June 14, 2017 Thanks mate (the showman) that helped lastly i need a detent ball for my gear selector in the transaxle i can only find them in the usa and its like 30 pound shipping so looking for one in the uk this is the part number (792077A) thanks Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted June 14, 2017 You may be able to use an old ball bearing out off a ball bearing. If you can find one small enough. Share this post Link to post Share on other sites
Wristpin 400 #5 Posted June 14, 2017 The most common problem is incorrect positioning of one of the bushes with locating " nibs" not sitting in theit cut outs in the casings. 1 meadowfield reacted to this Share this post Link to post Share on other sites
meadowfield 1,901 #6 Posted June 14, 2017 35 minutes ago, Wristpin said: The most common problem is incorrect positioning of one of the bushes with locating " nibs" not sitting in theit cut outs in the casings. got the t shirt there 1 Jack rush reacted to this Share this post Link to post Share on other sites
Jack rush 0 #7 Posted June 14, 2017 Thanks anything more on the detent ball Share this post Link to post Share on other sites
Anglo Traction 1,018 #8 Posted June 14, 2017 What size of Ball is required?. I have an assortment of fractional inch sizes in Steel, Stainless and Phosphor Bronze, all precision finished. Size range from 1/16" to about 5/16" I think....some bigger. If I have what you need, I can help you. Share this post Link to post Share on other sites
meadowfield 1,901 #9 Posted June 14, 2017 from the ones I've split they are around 1/4" - but more likely 5/16" (just under 8mm) Share this post Link to post Share on other sites
