Fix'em all 49 #1 Posted August 29, 2018 I have a later style Merry Tiller with a 5hp Briggs I/C engine that is refusing to start & is stretching my normally good diagnostic skills now. It is fuel related as it will start when I tip fuel in via the air filter but once it stops it will not draw fuel into the carb. It is pumping up into the raised chamber in the tank but that is as far as it will come. So far I have cleaned the carb thoroughly including under the mixture screw. When you blow through both the pipes on the bottom of the carb it is all clear with no obstruction. I have fitted a new diaphragm and there is a good seal between the carb & inlet manifold. Any ideas what I can try as I am stumped now Share this post Link to post Share on other sites
nigel 1,881 #2 Posted August 29, 2018 I can’t see that it can be anything other than diaphram I would check that again and also start it by chucking carb cleaner down the air intake a couple of times I’ve found sometimes doing that will clear things out and carry on running Share this post Link to post Share on other sites
Fix'em all 49 #3 Posted August 29, 2018 Am I correct in saying that the diaphragm only draws fuel up from the main tank to the upper section in the tank. If so then it is doing that, but is it the vacuum of the intake stroke that draws it up into the upper part of the carb. Share this post Link to post Share on other sites
Reiver 14 #5 Posted August 30, 2018 Is the choke working properly? Share this post Link to post Share on other sites
Fix'em all 49 #6 Posted August 30, 2018 Nigel, thanks for the parts breakdown. I wondered if I am getting a good enough seal between the tank and the carb, so I ordered a new gasket first thing this morning. Only trouble is I have ordered part no 272996 & your breakdown shows 692241. They look the same but not sure on dimensions. Reiver - the choke does fully close, but I did notice that if the screw fixing the air filter base plate to the choke lever plate is too long it stops the choke lever before the choke flap is fully closed. Share this post Link to post Share on other sites
Wristpin 400 #7 Posted August 30, 2018 Take the air cleaner off and put your hand over the intake while pulling the rope. That will tell you whether it’s a choke problem. Share this post Link to post Share on other sites
Fix'em all 49 #8 Posted August 30, 2018 The choke flap is fully closed so I don't believe it is the issue with this. The tank to carb gasket does seem to weep a spot of fuel so my thinking is that it is also sucking air and preventing the fuel from being drawn up from the upper tank chamber. Am I right in assuming this ? 1 Sammoore13bolens1053 reacted to this Share this post Link to post Share on other sites
Wristpin 400 #9 Posted August 30, 2018 Still try the hand over the intake and see if it makes a difference. Share this post Link to post Share on other sites
Reiver 14 #10 Posted September 1, 2018 Any luck getting your engine started? Share this post Link to post Share on other sites
Fix'em all 49 #11 Posted September 1, 2018 (edited) I took the air filter housing off & put my hand over the carb & fuel came up straight away. I have put it all back together and put the air filter cover on but it still takes about 10 pulls on full choke to get it to start from cold. Runs lovely when it it starts. The only thing that is different is there was a foam & mesh filter in the air filter cover that was rotten so I removed it. The paper filter is all good so don't know if not having the additional filter is enough to cause this. The new tank gasket should arrive in the week. It does weep a bit so it may be sucking air in & preventing the fuel drawing up. Edited September 1, 2018 by Fix'em all Share this post Link to post Share on other sites
Wristpin 400 #12 Posted September 1, 2018 The fact that the "hand over" treatment worked suggests an air leak somewhere. The gauze ore cleaner shouldn't cause a problem as it was a standard fitment on Industrial Commercial spec engines. 2 nigel and Fix'em all reacted to this Share this post Link to post Share on other sites
Fix'em all 49 #13 Posted September 5, 2018 Fitted new tank gasket & still the same. Looked again at the choke & although it looked closed there was a tiny gap both sides of the flap. Slight mod to the set up and it closes tight now & started second pull. I should have checked it properly, thanks guys 1 nigel reacted to this Share this post Link to post Share on other sites
Reiver 14 #14 Posted September 5, 2018 Good to hear you got a result. Share this post Link to post Share on other sites
Fix'em all 49 #15 Posted September 9, 2018 Have now finished the Merry Tiller Spartan & looks so nice it will be a shame to get it dirty 2 Stormin and nigel reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #16 Posted September 9, 2018 Looks better than new. Share this post Link to post Share on other sites
