Stormin 4,458 #1 Posted September 24, 2018 Feeling a bit bored as I've no project as such now the plough depth wheel is done, I decided to mow the green. Put the deck onto the C-125, topped up the fuel, checked the engine oil and off I went. Got the green done and the verge on the opposite side of the lane, then proceeded with the area between the pond and our neighbours drive. Just about to move on to the other verge by the pond and a horrible rattling noise appeared. Knocked off the deck and it was still there. Not coming from the engine thank goodness. If it had been I reckon the engine would have disintegrated. I then noticed the clutch pedal was bouncing back and forth. Drive belt on it's was out? Gently drove back into the workshop and took footplate and side panel off. Started the engine and I then notice the clutch idler pulley had quite a wobble. Bearings gone? So take the pulley off and that was when I realised the part of the bracket the pulley fits on had been repaired by a PO. It must have snapped off at sometime and a piece of flat had been welded to the top half then bolted through the bottom half. On the bench with the pulley off I discovered the hole the pulley bolt goes through was elongated. Also the nut and bolt were a bit loose. The pulley bearings were not bad. Just a little play. So I tightened up the nut and bolt with thread locker on. Good and tight. All back together now and though there is still a bit of movement in the pedal, it will do till winter. Looks like the old girl will be getting an overhaul this winter. The engine does smoke a bit and uses a bit of oil. So that will be rebuilt as well. Sorry no photo's. I got too engrossed in what I was doing. 4 HeadExam, Triumph66, 4x4forks and 1 other reacted to this Share this post Link to post Share on other sites
4x4forks 258 #2 Posted September 24, 2018 funny when you start a simple job how these things escalate. 😂 1 HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted September 27, 2018 Changed the belt this morning, as I had a bit of time while waiting for the call to go silaging at the farm. I remembered I'd a OE belt off the Raider 10. Put that on practically no movement in the pedal. I suspect the belt which was on, a normal Vee belt, had developed a slack point. It had been on there for about 7yrs and done a lot of work, so hasn't done bad. Share this post Link to post Share on other sites
Anglo Traction 1,016 #4 Posted September 27, 2018 Surprising how long to OEM belts seem to last. Should get a few more years if you're lucky (fingers crossed). On 9/24/2018 at 7:02 PM, 4x4forks said: funny when you start a simple job how these things escalate. 😂 Oh yeah!. Very true observation Share this post Link to post Share on other sites
