Potash123 26 #1 Posted October 9, 2018 I have been asked by an old mate to look at his Bolens Ride on. It is powered by a Mitsubishi 3 Cylinder Diesel Engine. I have never worked on a diesel in my life. My mate who is not a well man at all, tells me that it has been diagnosed with a defective electric fuel pump. Therefore I am on this forum cap in hand. I don't have any photos of the machine or even which model it is. Where on this machine will I find the fuel pump please, where will I get a replacement, new or exchange. What make will the pump be. I am willing to dive in and help my mate, but a bit of guidance will help this Hayterette DIY member would be helpful. Thank you in anticipation. Share this post Link to post Share on other sites
Anglo Traction 1,018 #2 Posted October 9, 2018 I'm not familiar with Leccy fuel pumps, or diesels, but I am aware that many people in the U.S fit electric fuel pumps as replacements on their Wheel Horses. FACET is a brand that seems to crop up a lot. The pressure rating and litres/gallons per hour is important, as well as any bypass for pressure relief. Presume 12volts. The pump could be anywhere on the machine, so you will have to follow the fuel system to locate it. It will help to establish what the current (iffy) pump specification is and start form there. Also check the fuel line Inside diameter. Lots of pumps online to look at. Share this post Link to post Share on other sites
HeadExam 1,783 #3 Posted October 10, 2018 The diesel fuel pumps on many bigger Bolens tractors made by ISEKI were water cooled just like large tractors and had injector pumps, However the Large Frame Bolens garden tractors were offered with an air-cooled diesel Mitsubishi and/or Wisconsin (Teledyne) engines that used a standard 12 volt fuel pump. Those models include the DGT-1700, HT20D and HDT1000. The 14 ISEKI geared models from 15-29 hp were the G152 (15hp), through G294 (29hp), and the two hydrostatic models H1502 and H1704 15 and 17 hp respectively. The first two numbers were the approximate horsepower. A model ending in the number 2 was two wheel drive and a model ending in 4 was 4 wheel drive. Share this post Link to post Share on other sites
Potash123 26 #4 Posted October 10, 2018 Seems to be 5117H, part number 1743165, shall start looking unless anyone has one. Thanks for replies to date. Share this post Link to post Share on other sites
Potash123 26 #5 Posted October 10, 2018 Spent a good hour looking for a pump in the UK----- HELP. Share this post Link to post Share on other sites
HeadExam 1,783 #6 Posted October 10, 2018 Any low volume 12 volt fuel pump will work. Most spares stores will carry it Share this post Link to post Share on other sites
Potash123 26 #7 Posted October 11, 2018 Thank you, the pump seems to be under the seat/fuel tank, getting to it is another matter, can't even see it to read the make. Will have another go the weekend. 1 HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #8 Posted October 12, 2018 10 hours ago, Potash123 said: Thank you, the pump seems to be under the seat/fuel tank, getting to it is another matter, can't even see it to read the make. Will have another go the weekend. Remove the seat pan, 4 bolts under the seat. Be careful with the tail light wiring. The 2 speed trans axle shift lever knob should unscrew and you can work the pan over the lever or just lift it out of the way a bit. You need the parts or service manual? I have them. Share this post Link to post Share on other sites
HeadExam 1,783 #9 Posted October 13, 2018 On 10/11/2018 at 8:50 AM, Potash123 said: Thank you, the pump seems to be under the seat/fuel tank, getting to it is another matter, can't even see it to read the make. Will have another go the weekend. Here are the manuals for the 5100 series. the part number of the fuel pump is 1743165. I don't see a OEM pump for sale, but I've just always bought the aftermarket pump for 12.00 and change, just take the old one to the spares store and match the electrical connection, most universal aftermarket pumps should have the same connector. Here is a Facet OEM pup used on Bolens and John Deere tractors. https://www.ebay.com/itm/John-Deere-70-128-400-Fuel-Pump-90-67-from-JD-Facet/183464396372?hash=item2ab7548654:g:O~EAAOSwtltbiKWS:rk:7:pf:0 Share this post Link to post Share on other sites
Potash123 26 #10 Posted November 8, 2018 Got a pump locally £30, all fixed and happy, thank you. 2 HeadExam and Stormin reacted to this Share this post Link to post Share on other sites
wurzel 117 #11 Posted January 28, 2019 Hi just seen your post i have a DGT1700 as well. I have a set of new pistons ,rings , rods and gaskets for this engine if you need any parts .Also a new tiller and second hand deck Share this post Link to post Share on other sites
