The Fife Plooman 632 #1 Posted December 11, 2018 some pictures of the ploughing matches at the weekend hope you like 5 4x4forks, Triumph66, C-101plowerpower and 2 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted December 12, 2018 Nice straight furrows there George. Share this post Link to post Share on other sites
HeadExam 1,783 #3 Posted December 15, 2018 I'm a long way from your ability, but as soon as it dries our I will be practicing some more. Setting the plow up has been tricky for me and I suppose others as well. 1 Triumph66 reacted to this Share this post Link to post Share on other sites
The Fife Plooman 632 #4 Posted December 15, 2018 Hi can you put up some pictures of your setup may be able to guide you , keep well 2 HeadExam and Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted December 15, 2018 Take George up on his offer, Alain. He gave me a lot of good advice. 1 HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #6 Posted December 16, 2018 23 hours ago, The Fife Plooman said: Hi can you put up some pictures of your setup may be able to guide you , keep well Thank you George. One problem I had was in the hydraulics, the lift would go up and down, but I could not set it to stop or hold. I believe by tightening the nut on the lift lever has helped that situation, I may need to tighten a little more. The plow would bury itself and stop the tractor when I let the plow into the ground and when I lifted the lever a little it would come out of the ground. I'm not sure how to set the center link on a 3 bottom plow either. I'm running a 54hp David Brown Selectamatic 990 live drive six speed Share this post Link to post Share on other sites
The Fife Plooman 632 #7 Posted December 17, 2018 Hi Alain check for David Brown Tractor club forum they seem to cover the part about hydraulics quite well this would be your best way forward as far as your plough is concerned do you have discs or skimmers for your plough, if you have fit them. on a starting point with your plough is put it down on level ground adjust the top link until the plough is sitting level. when the plough is level and the ploughshare tip is on the ground and the heel of the plough is on the ground you should be able to put your fingers in a hollow between the two if you cannot your ploughshares are worn, I hope this gets you started I will take pictures on Saturday and post them on line it will give you a better idea Keep well Share this post Link to post Share on other sites
HeadExam 1,783 #8 Posted December 17, 2018 Thank you George. I do not have the 3 coulter/disc wheels that cut the sod and any I have found are 100's of miles away and hundreds of dollars a piece used; which I find unfathomable. I tightened the nuts on the lift handle pivot and that seemed to take care of the hydraulic problem. I also shortened my center link so my tips would not point up, the plow pins are offset to so I don't have to change the draught arms differently and the plow has the ability to tack left or right in case of hitting a hard root or rock. I have stabilisers on both sides and will take some more pictures tomorrow morn. I'm hoping it will be dry enough to put the plow in the dirt later this week. Thanks to all for the advice, I hope to make a decent plow very soon. Share this post Link to post Share on other sites
