Steve2018 3 #1 Posted February 20, 2019 Is it possible to replace the disc with 8 blades on to just a single blade? I think my blades are blunt as they seem to just flatten the grass but there's 8 at £15 each! Thanks Share this post Link to post Share on other sites
4x4forks 258 #2 Posted February 20, 2019 Cheep enough to have a go but balancing may be a issue . I think I would have a go Share this post Link to post Share on other sites
nigel 1,880 #3 Posted February 20, 2019 Why not just sharpen the 8 blades Share this post Link to post Share on other sites
Wristpin 400 #4 Posted February 20, 2019 I would follow Nigel’s advice and sharpen the blades. The later 30” deck on the 604 had a bar blade but also a fan to create enough air flow to fill the bag. On your machine it is the wings on the 8 blades that create the air flow . Unless you are just going to cut and drop, I would keep them. Share this post Link to post Share on other sites
Steve2018 3 #5 Posted February 21, 2019 3 hours ago, nigel said: Why not just sharpen the 8 blades Is there a special way to sharpen them? Eg a certain angle or as long as they sort of follow the original angle would that be ok? I remember sharpening a garden shredder blade that was blunt but still working sort of ok, i made it nice and sharp and it would shred anything... Thanks Share this post Link to post Share on other sites
Stormin 4,458 #6 Posted February 21, 2019 Just follow the original angle, but take off as little as possible. Share this post Link to post Share on other sites
Steve2018 3 #7 Posted February 21, 2019 Thanks had a look but all the bolts look untouched from the 80's and not wanting to budge. I got the main centre bolt out but the disc is stuck solid Might be easier removing the deck to attack them easier do you think? from the looks of it the deck is held on by just some R clips is this correct or am I missing something? Thanks Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted February 22, 2019 I had a 504 and if I remember right, the deck is just held on by R clips. If you get it off, turn it upside down and soak the bolts in releasing fluid. Or apply some gentle heat. Share this post Link to post Share on other sites
nigel 1,880 #9 Posted February 22, 2019 As Norm says steve Share this post Link to post Share on other sites
Wristpin 400 #10 Posted February 22, 2019 This may help https://www.dropbox.com/s/pvg63wyrievumwn/Lawnflite 504 deck0001.pdf?dl=0 Three suspension links with R clips and one cable connecting the blade brake to an anchor point on the transaxle. Share this post Link to post Share on other sites
Steve2018 3 #11 Posted February 25, 2019 Thanks got it off will have a go at sharpening Share this post Link to post Share on other sites
Steve2018 3 #12 Posted April 9, 2019 Gave it a quick sharpen and seems to cut alot better but had a problem towards the end of my mowing that I have started a new thread for :-) Share this post Link to post Share on other sites
