CNew 408 #1 Posted January 24, 2020 Now that’s more like it, it only took 4 days shipping for this one to arrive. I’ll add more photos this weekend. If this was used as a manhole fan that would explain some of the corrosion, sewer gases. This thing is going to be a project but also a really fun one. 1 pmackellow reacted to this Share this post Link to post Share on other sites
Wallfish 718 #2 Posted January 24, 2020 Nice score! Get to work! Terry has been knocking them out recently so have to keep up. Share this post Link to post Share on other sites
CNew 408 #3 Posted January 24, 2020 I hear ya, I think I’m going to start tackling this fan. Terry has been cranking through these. I’m still making slow progress on that Clinton outboard. I’m having to fully strip the paint which is tedious. I think it’s going to look cool when I’m done though. Turns out the main fan shroud on the Orline looks to be either a molded plastic or fiberglass material. I thought it might be metal... Share this post Link to post Share on other sites
Wallfish 718 #4 Posted January 24, 2020 Still curious if that is actually a manhole fan. It's my understanding those fans blow air into the holes to ventilate the areas. Seems blowing in the engine exhaust would not be a good idea but maybe the amount of exhaust compared with the amount of air volume makes it minimal. Does the tank have a bracket? That would give the orientation of how it's intended to be used, either like it is in the pic or horizontal. Share this post Link to post Share on other sites
CNew 408 #5 Posted January 24, 2020 It does have a tank bracket. There are also a couple arrow stickers showing the direction of the airflow. Looks like the aluminum handle would actually sit on the ground which would make the engine upside down and air flowing past it. In this orientation the exhaust from the engine would also get blown up and out. Share this post Link to post Share on other sites
Wallfish 718 #6 Posted January 24, 2020 29 minutes ago, CNew said: In this orientation the exhaust from the engine would also get blown up and out. But the tank fill neck would need to be facing the fan blade in that orientation so it doesn't empty and would be difficult to fill. Which orientation does the bracket hold the tank? Share this post Link to post Share on other sites
JUST O&R 237 #7 Posted January 24, 2020 I"m glad you figured out how to get things shipped to you!! That will be a good project. That is a good question about the exhaust. Clit should be done with the outboard in time for summer. Share this post Link to post Share on other sites
CNew 408 #8 Posted January 24, 2020 Probably true, that paint removal process is time consuming. The fan will be more fun. Share this post Link to post Share on other sites
CNew 408 #9 Posted January 25, 2020 Couple pics of the tank orientation and the direction of air flow. Share this post Link to post Share on other sites
Wallfish 718 #10 Posted January 25, 2020 That thing is for blowing something. Now I see, it's made for hand held use and has a throttle speed control. Share this post Link to post Share on other sites
CNew 408 #11 Posted January 25, 2020 It’s definitely different. The hand throttle is interesting. Maybe some sort of early leaf blower? Share this post Link to post Share on other sites
CNew 408 #12 Posted January 25, 2020 Started on the fan. Everything was going ok until the shaft sleeve on the end of the crankshaft that holds the fan blade. It doesn’t want to free off. Share this post Link to post Share on other sites
JUST O&R 237 #13 Posted January 25, 2020 Well you got got it Share this post Link to post Share on other sites
JUST O&R 237 #14 Posted January 25, 2020 Well it only been on there 50 to 60 years I don't see what all the fuss is about Share this post Link to post Share on other sites
Wallfish 718 #15 Posted January 25, 2020 did that shaft have a screw in it holding it to the crank? If so, screw it back in with very slight gap between the head of the screw and the end of the shaft, hold the shaft or put in a vice and strike the head of the screw with a hammer to separate it. Just guessing it's a taper fit like the flywheel but could be something else. I use a hard rubber mallet so it doesn't distort the heads or nuts being hit.. Share this post Link to post Share on other sites
CNew 408 #16 Posted January 25, 2020 Well I heated it and tried all the tricks and was just about to give up on it for the day when it finally started to move. After some more gentle persuasion it finally came free. Good feeling..... I think it ended up being a combo method. I did the “screw the bolt in almost all the way” method and worked at it for awhile. Then I did the gentle heat and quickly followed it with the bolt method at the same time. All the while I was keeping it good and soaked in Kroil. Oh, and because the fan blade is so thick it had two of the sleeves/spacers so I decided to use the long bolt and both sleeves when doing the “bolt method” and that’s when it started to free up. Share this post Link to post Share on other sites
JUST O&R 237 #17 Posted January 25, 2020 I was just about to have you box it up and send it here so I could get it apart . 1 1 Wallfish and CNew reacted to this Share this post Link to post Share on other sites
CNew 408 #18 Posted January 25, 2020 Curious, has anyone found a good substitute for these old O&R throttle cables? This one is pretty beat up. I’ll probably be able to get it free and working again but it hasn’t been treated well over the years. It’s a bit kinked and the white sheath is cracked in places. Share this post Link to post Share on other sites
JUST O&R 237 #19 Posted January 25, 2020 Is it a hard center cable or soft? Share this post Link to post Share on other sites
CNew 408 #20 Posted January 25, 2020 Just O&R, what yellow paint did you end up using on the chainsaw? I may end up trying to touch up the paint on the recoil housing - it’s missing half the paint. I don’t want to make it too new looking since the overall fan tool shows its age. 5 minutes ago, JUST O&R said: Is it a hard center cable or soft? It’s the braided/twisted wire type. I just got it free and moving so I think I can make this one work. Maybe if I can find some white Plasti-dip I can touch up some of the chipped and cracked areas on the outer sheath. Share this post Link to post Share on other sites
JUST O&R 237 #21 Posted January 25, 2020 You can get that from a bike shop . some Walmart's have the small bike cables . Share this post Link to post Share on other sites
CNew 408 #22 Posted January 25, 2020 Started doing some cleaning on the parts. Wow, not sure what got splattered all over the main fan shroud but it is glued to it like tar. It’s taking some serious elbow grease but I think I’ll be able to get it to a presentable state. This black gunk stuff also stained the paint a little. It won’t be perfect when I’m done but I’ll get it looking nice. Share this post Link to post Share on other sites
JUST O&R 237 #23 Posted January 25, 2020 Any of them cleaned up and restored is a good thing. There not all spotless it will look great. Share this post Link to post Share on other sites
JUST O&R 237 #24 Posted January 26, 2020 Just looking back a the pic this morning that throttle is like one of my hedge trimmers. I may have one like that but wont be back to the shop until Tuesday . p.s I dont think the yellow i use will work (To bright and shiny ) Share this post Link to post Share on other sites
CNew 408 #25 Posted January 26, 2020 I think this cable will work ok. I’m going to try some white heat shrink at the kink where the cable exits the grip to see if that helps tidy it up a little. Whatever this was used for the crap it was sucking and blowing was nasty and corrosives! Share this post Link to post Share on other sites
