CNew 408 #1 Posted February 14, 2020 Finally received the piece of Garlock 2900 gasket material to experiment with for the cylinder head gaskets. At first glance it looks promising. I’ll take some more measurements this weekend and try cutting a sample to try out on an engine. Share this post Link to post Share on other sites
factory 487 #2 Posted February 14, 2020 Looks good to me. David Share this post Link to post Share on other sites
Wallfish 718 #3 Posted February 14, 2020 Nice Let us know how you make out. These won't need to be a total precision cut down to the .001 so cutting them with your new tool should be fine. The biggest hurdle will be the head lining up correctly when tight so the thickness is more critical. If that material has some "squish" to it then it probably doesn't matter as much. Share this post Link to post Share on other sites
CNew 408 #4 Posted February 14, 2020 Good point John, I’ll make note of that when I assemble the head. Can’t remember the compressibility properties for this material. Share this post Link to post Share on other sites
Wallfish 718 #5 Posted February 14, 2020 9 minutes ago, CNew said: compressibility properties Are you stating the word "squish" isn't the right term? 1 1 JUST O&R and CNew reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #6 Posted February 15, 2020 Some how I mist all this we do need to be politically correct . I'm the worst for that 21 hours ago, Wallfish said: If that material has some "squish" We need to politically correct . so it it squish or compressibility 1 Wallfish reacted to this Share this post Link to post Share on other sites
CNew 408 #7 Posted February 15, 2020 First set of gaskets are now cut. I measured the thickness vs the original gasket as well and it looks like the original material is close to 0.034” whereas the new Garlock 2900 material is about 0.030”. Hopefully the difference isn’t an issue once installed... It also seems the older gasket material is a little stiffer while the new material has slightly more squish Share this post Link to post Share on other sites
JUST O&R 237 #8 Posted February 15, 2020 Ok so it has more squish you remember the originals are 50 years old they to were probably a littler more compressible when they were new. look they would work just fine. Share this post Link to post Share on other sites
Wallfish 718 #9 Posted February 16, 2020 We can always add a shim ring if the compressibility properties are more squishable than anticipated. The next guy who finds 4 rings is gonna have to figure out what's going on. (see what I did there?) Or do they offer that same material in .035 or .036? 1 JUST O&R reacted to this Share this post Link to post Share on other sites
CNew 408 #10 Posted February 16, 2020 2 hours ago, Wallfish said: We can always add a shim ring if the compressibility properties are more squishable than anticipated. The next guy who finds 4 rings is gonna have to figure out what's going on. (see what I did there?) Or do they offer that same material in .035 or .036? I haven’t seen any material like this in the 0.035-36 thickness. Share this post Link to post Share on other sites
