Josh4722
Westwood w8 exhaust removal
How do I remove the front to back exhaust system on the old w11s? I’m thinking of getting rid of mine but I want to keep the exhaust because it’s really good. Cheers
  I would suggest from the look of it, to leave it alone. That bend is a BSP elbow and the threads will be well corroded. You'd have to disconnect the pipe underneath first and the section going through the chassis, to be able to unscrew it.
The whole consists of two parts. The first part is secured to the engine by a small screw, and the second part is screwed to the tractor by the muffler. Both are inserted one into the other and fastened with a clamp.
This can be easily removed.
