mrtom 2 #1 Posted October 29, 2020 I’m looking for a cooling shroud with the recoil to complete my little outboard motor. I’m pretty sure they are the same on all the O&R engines. Share this post Link to post Share on other sites
CNew 408 #2 Posted October 29, 2020 Can you post some photos? Share this post Link to post Share on other sites
mrtom 2 #3 Posted October 30, 2020 I have pix but don’t know how to post them. Share this post Link to post Share on other sites
Wallfish 718 #4 Posted October 30, 2020 Cooling shrouds are a common missing part so your best bet is to be persistent searching the auction sites for them. Share this post Link to post Share on other sites
1olddog 3 #5 Posted October 30, 2020 On 10/28/2020 at 8:55 PM, mrtom said: I’m looking for a cooling shroud with the recoil to complete my little outboard motor. I’m pretty sure they are the same on all the O&R engines. Are you looking for the cylinder cooling shields or the shroud that has the recoil starter on it ? Share this post Link to post Share on other sites
mrtom 2 #6 Posted October 30, 2020 I need the red shroud with the recoil intact. Mine had the spring missing. I tried to install a spring from a weed wacker and that little tab that holds the end To the shroud broke. 2 pmackellow and CNew reacted to this Share this post Link to post Share on other sites
1olddog 3 #7 Posted October 30, 2020 34 minutes ago, mrtom said: I need the red shroud with the recoil intact. Mine had the spring missing. I tried to install a spring from a weed wacker and that little tab that holds the end To the shroud broke. Could you maybe heat ,then bend the recoil wire around to make that little tab that broke off ? That recoil is only made of 3/16" material if you could find one that size. Share this post Link to post Share on other sites
mrtom 2 #8 Posted October 31, 2020 Well, I tried for about three hours before I threw in the towel! I didn’t know the original spring had a loop as in your photo. I thought it just had a small right angle that was held by the tab that I broke. There’s not much room in there! Share this post Link to post Share on other sites
CNew 408 #9 Posted October 31, 2020 That’s a cool outboard! Share this post Link to post Share on other sites
