Chris 642 #1 Posted May 11, 2014 Now that got you looking!!! Now the Bolens 1886 is running, I have got the deck on & apart from a few small probs it works well. Its a beast of a mower & good fun to drive. One thing it does do, is when its run for approx 40 mins it cuts out . Let it cool for 15mins, off I go again. Its got a good spark now its got a new condensor & ajusted the points. I am sure its carb ajustment as if I turn it off it wont start from hot. From cold it starts well. Been mowing the lawn today Just after I took these pics, it cut out!! Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted May 11, 2014 The cutting out and refusing to start when hot, could it be the coil over heating? BTW. That's some lawn. Share this post Link to post Share on other sites
Chris 642 #3 Posted May 11, 2014 I did also think of the coil, I wipped the plugs out when it stops & its still sparking well. I do have a spare coil which I can try. Have a kohler manual for the engine which says how to set the carb up. Looked at it again today & on another page says something else. I think shes running on the hot side. Will have to have another look in the week. Share this post Link to post Share on other sites
Stormin 4,458 #4 Posted May 11, 2014 Just had a thought. How close is the exhaust to the carb, fuel pipe? I'm thinking fuel evaporation. Share this post Link to post Share on other sites
Ian 2,417 #5 Posted May 11, 2014 That's a beast of a mowing machine Chris Share this post Link to post Share on other sites
pmackellow 2,738 #6 Posted May 11, 2014 Looking good Chris thats one hefty mowing deck !! Share this post Link to post Share on other sites
ranger 373 #7 Posted May 11, 2014 Hi Chris. My C121, when I first got it , would run for about an hour then cut out when throttle was moved from max, It would restart when cooled a little.I rebuilt the carb,including turning up some bushes to remove play in the spindle. The cause was traced to the exhaust valve clearance,after adjusting it runs fine.Hope this maybe of some use to you. Doug Share this post Link to post Share on other sites
Chris 642 #8 Posted May 11, 2014 Thanks for the info Doug. I did grind in the valves & set the clearance when I rebuilt the engine according to the manual. But worth checking again now its run in I made a good carb up from 2 units with all good parts. My money is on the settings at the min, but maybe bit of both causing the problem Share this post Link to post Share on other sites
Chris 642 #9 Posted June 22, 2014 Well, still having problems with the engine but have now worked out whats wrong with help from a Kohler Expert Even though it fires up well. Some issues with the carb were sorted & now runs for a bit longer The problem is serious lack of compression Done a leak down test & it leaks like a sieve. So engine is coming back out for a birthday, fitment of new rings & valves etc Keep you posted Share this post Link to post Share on other sites
Ian 2,417 #10 Posted June 22, 2014 It's a shame the engine is giving you problems Chris, but at least you know it will be a strong runner after it's rebuild. Share this post Link to post Share on other sites
Chris 642 #11 Posted June 22, 2014 It can only get better than it is Ian Each cylinder should have 90-100psi when cold. Mine have 40 & 50. Raising to 60psi when hot As the valves are not doing there thing correctly, I have hot gases going up the intake manifold thus causing carb problems Have placed an order for parts so have to wait before I do open heart on the engine Share this post Link to post Share on other sites
