Steve2018
    46
Steve2018 last won the day on May 30 2018
Steve2018 had the most liked content!
About Steve2018
3,585 profile views
  1. Just got a Qualcast 35s that I have refurbished the carb on but wow the Self Propel drive speed is like a jogging pace and nearly pulls your arm out of the socket if your not ready for it. Is there a way to adjust the drive speed or do you need to adjust the drive speed by the throttle control? Only thing with that is the mower is near enough at idle for a slow drive pace or is that correct? Thanks
  2. Hi, got a old Cement mixer here that I need help with. It starts and idles fine but almost cuts out when load is added to it (sand etc) Took the filter housing off and can't see any governor springs attached which I'm guessing is the issue?? Engine code seems to be 92232 0141 01 970228f a Pic of the carb but as you can see it doesn't have one of thenspring mounts it's like it was never threaded at the factory? Carb on left is a image I found online carb on right is mine Any ideas on where the springs should go? Thanks
  3. Thanks, Only use Tesco Momentum Ron99 that's E5 I think Yes it's the 504 with 8hp Briggs and stratton engine. Will have to look for a guide on how to do the valves, guessing won't be too much hassle to do :-) Checked the clearence of the ignition coil and that was way out so adjusted that It's a good little mower :-) gave the grass it's final cut on Sunday with no issues :-)
  4. Sorted for the grand total of £4 Sprayed carb cleaner in the inlet while turning it over and it fired up and spluttered for a while spluttering moisture out the exhaust. I'm guessing it was maybe just damp and condensation inside the engine? Fires up nice now :-)
  5. My Lawnflite 504 worked fine in October but went to start it at end of November and it just keeps turning over. Occasionally it will almost fire up (Bit like trying to start a classic car that doesn't want to fire up) and I will get a puff of smoke from the exhaust. It's getting a spark and also tried 2 other plugs. Fuel is flowing fine, filter isn't blocked. Float is working as it should Poked some carb cleaner needels in the carb holes and all seemed clean It's getting fuel Took the airfilter off to make sure it's not blocked and when it turns over I can see fuel vapour puffing out It's like it's on the edge of firing up Would cold start spray work? Also read that carb cleaner can be used as an alternative? Any other ideas or is it just the weather making it hard to start? Thanks
  6. Hi, how free should the variable speed pulley move should it slide up and down with little effort eg put it upside down it should drop down with gravity? I have freed mine up but require 2 hands to clunk it up and down Thanks
  7. Sorted :-) The engine with the £50 lawnflite had a running problem (only ran on choke) sorted that by cleaning all the blockages out the carb. Swapped the cutting gear over from the non runner and its going great. I even have all 6 speeds to select from instead of just speed 5 or 6 :-) The engine must be newer as it uses the two piece carb with only one adjuster needle instead of the one piece carb with two needles and it runs so much smoother and easier to setup I think. The old engine was puffing blue smoke at high revs this ones nice and smooth :-) Still going to look at getting the non runner going again but good to have two of the same mowers for spares
  8. Thanks I will add it to the todo list :-)
  9. Is it as easy as checking valve clearance on a classic mini with feeler gauges? Purchased a running Lawnflite 504 mower without cutting deck for £50 so should be sorted soon :-)
  10. Ok took carb apart and looked ok and put back together and still wouldn't run. Took the spark plug out (wish I did this first) and it was covered in black soot, cleaned it and it started and ran :-). Stupidly I thought I will try and adjust the carb settings as it was a little roughish sounding... Wish I just left it alone... Turned it a little and now not running again seems to be alot of fuel coming through the carb when trying to start and fuel vapour popping out the carb inlet. Can the adjustment needles become worn? Thanks
  11. Im guessing this tree is dead? Moved into the house 2 years ago and it doesn't seem to have done much... Bits snap off easy like its dry. Should I just cut it down? How does a tree just die? Could something affect the tree next to it? Thanks
  12. It was for a non fuel pump engine but maybe the filtration of it was poor... Still haven't had time to strip it lol I thought it was supposed to be red as well. I was going to order a 298090S filter on Amazon but it is White Briggs & Stratton 992350 298090S Fuel Filter https://www.amazon.co.uk/dp/B016BXY078/ref=cm_sw_r_cp_apa_i_4J2UCbWMXY6W9
  13. Dipstick smells ok and it also still cuts out on full throttle + choke. Going to pull the carb off and clean it out maybe i should use a genuine briggs fuel filter instead of a universal one... Thanks
