mickrochip
    24
mickrochip last won the day on July 16 2020
mickrochip had the most liked content!
About mickrochip
    Northern Ireland
10,198 profile views
  1. mickrochip
    no spark
    back again, just to let you know that the engine started with the old points, I just took an earth wire to ground (direct to battery) turned on ignition and engine started and ran ok i now have a few other problems but that is for another forum on where to get parts like tinware and a breather cover so thanks for now see you all shortly
  2. mickrochip
    no spark
    thanks to every body for their info. I just got my points today, and am just about to fit them, but when checking round coil fixings and condenser i found out that the condenser was not connected to earth, problem being that the mounting points have been cracked and broken, the cowl needs some repair around this point , i will earth with a cable for now and either weld cowl or look for another one will let you know later on how i ggot on
  3. mickrochip
    no spark
    sorry for that. I had to rewire machine as per c141 wiring diagram, and wired direct without safety switches which were either broke or not working, i have now the cranking side of it sorted out ,now it is just the spark, the points are cra cked at the button in the point that makes the spark , the points and condenser have probably not been changed since this machine was made in 78 or 79 .it is a kohler k321 14hp engine on a c141 8 speed tractor
  4. mickrochip
    no spark
    thank you for your reply.the solenoid is no the original one , this one has 4 terminals one for the switch connection , the other tab connection is for the earth, the mounting bracket is not earthed, my problem was all wires being ate by cattle before i got machine, i
  5. mickrochip
    no spark
    thanks for your reply , have ordered a set of points, condenser, will let you kow how i get on when i get them
  6. mickrochip
    no spark
    thanks for your info. can you recommend someplace where i can get these items , as most places on ebay seem to be from america with extortionate postage
  7. mickrochip
    no spark
    hello folks aint been on for a while , tried to start my wheelhorse c141 today, had problems with solenoid , would not even click untill I ran an earth wire from solenoid terminal to earth, 4 terminal solenoid, after this i got the engine tor turn over quite quickly, i then set the points but got no spark points opening and closing but no spark could it be the condensor or coil or both , by the way my points have a crack in the insulation just at the movable point , could this be the problem also any help in this matter would be very helpful asI would lik to get this machine going again to toe my car trailer about the yard thanks for any info that will help me
  8. thanks for info , checked out wiring diagram, bot problem still persists, can get engine going , driving , but when trying to lower cutting head motor stops, could it be that the blades have siezed
  9. howdy lads need help to get a wiring diagram and service manual for a mtd rn145 smart ,can any one help please,or maybe machine is to young thanks
  10. hello folks i have a problem with an efco ef92 /13.5 m , i was wondering what is the length of the transmisson belt on this machine, my problem is that when i press clutch pedal it is very hard to change gear, the gearbox seems to keep running even whe pedal is depressed can any one help with this problem thanks for now
  11. howdy lads , aint been in contact for a while, , I have come cross a problem in wiring . I either need a wiring diagram or a wiring loom for tractor, also an air intake cover if any one can el please let me know the price and postage to bt78 4hu my tractor is WHEELHORSE C141 8 speedwith a 14 horse engine
  12. just to up date on belt situation the belt mentioned in above post is also too long,when converted to imp. it works out about 80 3/4" LONG. but this belt is still long , when clutch is released fully it will not put pressure on belt to drive machine, so will be going for a shorter belt again
  13. thank you for all your information, to day i got a belt., no. on belt B 17 x 2050 li , will this belt fit my machine, thanks
  14. thank you for your reply , as far as i know the tractor is original , this is the first time i have had anything to do with the tractor ,in the few years that i have had it, the old belt just broke in bits whilst mowing the side of the road at home,. by the way what way do you measure a belt, I will try and post a few pictures when my son takes them an downloads them to my computer thanks for now
  15. thank you for your quick reply, i will try to get one which is about an inch shorter tomorrow, by the way a very nice tractor,
