Wallfish 724 #1 Posted November 20, 2014 Courtesy of Webhead Arrived on Thursday, rebuilt engine and restored over the weekend. This is the first one of these that I had ever seen. 3 CNew, JUST O&R and pmackellow reacted to this Share this post Link to post Share on other sites
Wallfish 724 #2 Posted November 20, 2014 Courtesy of Enginesilo I don't know what would be more annoying...the bugs...or this thing running in the backgroundTake a look at this ad from way back when (1970). The shipping costs are a good laugh. 1 pmackellow reacted to this Share this post Link to post Share on other sites
Mitymoehelp 5 #3 Posted February 23, 2020 I aquired one, I found it in my friends dead neighbors barn I was wondering if you could help me find a new carb diaphragm or if I can make one and how to do it or any info would be a great help thank you Share this post Link to post Share on other sites
factory 487 #4 Posted February 23, 2020 Laser cut replacement diagrams are available from several forum members in the US including @Wallfish & @Webhead and from me in the UK. If you haven't already seen it check out the carb rebuild thread and don't forget to replace the old crumbly air filter foam, any other questions feel free to ask & we can help. Have you got any pictures of your Mity Moe? David Share this post Link to post Share on other sites
JUST O&R 237 #5 Posted February 23, 2020 That is awesome Ive never seen one of those ether I guess I need to get out more. Share this post Link to post Share on other sites
factory 487 #6 Posted February 23, 2020 Look for the other version powered by the Series 20A engine too, a seller had a pallet load of them which "were" all new-old-stock till the seller ran them all , I did try and get them to list one they hadn't run but got no-where with them so didn't buy one myself. David Share this post Link to post Share on other sites
CNew 409 #7 Posted February 23, 2020 8 hours ago, Mitymoehelp said: I aquired one, I found it in my friends dead neighbors barn I was wondering if you could help me find a new carb diaphragm or if I can make one and how to do it or any info would be a great help thank you Welcome to the forum! You have us drooling over the fogger, that is a really neat tool. PM me and I can also help you with a diaphragm if someone else hasn’t already got you fixed up. please add some photos of your Mity Moe. Share this post Link to post Share on other sites
Wallfish 724 #8 Posted February 23, 2020 Nice find, Those Mighty Moe sprayers are neat little items. Share this post Link to post Share on other sites
Mitymoehelp 5 #9 Posted February 23, 2020 I’ll add some pictures in a little bit, I don’t have any pictures of when it was together sadly but I do have some of when it is all torn apart and I do have access to a laser cutter is there a way I can purchase carb diaphragm material and then cut it out myself Share this post Link to post Share on other sites
Wallfish 724 #10 Posted February 23, 2020 Yeah, Allstate gasket for the correct material but you'll have to buy a big piece. One already cut diaphragm is $10 with a new paper gasket or I can send you a small piece of material for $10 with a gasket if I can find a piece. You could also find a carb diaphragm for something else on ebay and cut it down to to size. 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 409 #11 Posted February 23, 2020 It took me awhile to track down a source for the diaphragm material in the right thickness. I ended up going with a material from Alpha Engineered Composites. It’s a Fairprene product code WFP-B2N1. https://www.alphainc.com/en/products/fairprene/ http://www.fairprene.com/Documents/WFP-B2N1_Rev-1.pdf http://www.fairprene.com/coated_fabrics.htm Hope me this Helps! Share this post Link to post Share on other sites
Wallfish 724 #12 Posted February 23, 2020 Thanks for adding some pics. Unfortunately that's about the condition many of these tools are found in but they clean up nice if you spend the time. Looks like you're well on your way. Share this post Link to post Share on other sites
CNew 409 #13 Posted February 23, 2020 I second Wallfish, Allstate Gasket is another source for the material. Unfortunately either route you go they require a pretty large minimum order so it gets really expensive. Per Wallfish, he or I can send you a small piece at the price mentioned if you decide you want to cut your own. Share this post Link to post Share on other sites
JUST O&R 237 #14 Posted February 23, 2020 That one will need some cleaning but like john said with a little time and elbow grease it will look good then you are done. If you need help you found the place to get it. Share this post Link to post Share on other sites
factory 487 #15 Posted February 23, 2020 1 hour ago, Mitymoehelp said: and I do have access to a laser cutter is there a way I can purchase carb diaphragm material and then cut it out myself What about the CAD files then? The carb diaphragms we supply were all cut by Eric "the gasket man". David Share this post Link to post Share on other sites
Mitymoehelp 5 #16 Posted February 23, 2020 (edited) Thank you guys for your advice, I plan on getting this engine running and Might use it for a rc boat project. I was originally just trying to get it running without a rebuild and I didn’t have spark but when I stuck a screw driver in the plug wire and grounded myself to the unit I got a pretty strong shock so I tried some different spark plugs and neither did the trick so I cleaned the points and when I went to adjust them the set screw snapped right off in the aluminum and so didn't many other fasteners, luckily I was able to get them out using a stick welder and vice grips. It’s a cool trick I found on YouTube by deboss garage. Anyways could dirty points or a weak condenser cause no spark but A good shock. How much would wallfish charge me to send me a diaphram or diaphram material Edited February 23, 2020 by Mitymoehelp Share this post Link to post Share on other sites
factory 487 #17 Posted February 23, 2020 The condensers are usually fine, cleaning & adjusting the points should sort out the spark problem. You would probably find an RC carb much better if you plan to use one of these engines in a boat. What do you plan to do with the rest of the unit? they aren't exactly common. Usually I find a small gas blowtorch more than adequate for heating up seized fasteners to free them. David Share this post Link to post Share on other sites
Wallfish 724 #18 Posted February 23, 2020 A bad condenser could cause that issue. Not too many go bad on these for some reason but it's certainly possible. If it's sparking the points are making a connection although it's always good practice to clean the contacts anyway. Also clean the copper spring where it contacts that little post. Clint, @CNew will send you a diaphragm or piece for $10. Share this post Link to post Share on other sites
Mitymoehelp 5 #19 Posted February 23, 2020 Yes I was thinking of finding a more responsive carb when I eventually build a boat, I have the frame modeled on solid works mostly I just need to get some kinks worked out, the rest of the unit I might restore also just Incase I find out the mity moe is worth a million dollars or something haha but I will definitely hold on to the rest of the parts What would you recommend for a fuel to oil ratio, most modern equipment I think is 50:1 I’m assuming the mity moe calls for a 25:1 or 30:1 Share this post Link to post Share on other sites
Mitymoehelp 5 #20 Posted February 23, 2020 What would you recommend for a fuel to oil ratio, most modern equipment I think is 50:1 I’m assuming the mity moe calls for a 25:1 or 30:1 and also what about the little pushrod for the points about an 1/8 inch of mine broke off durring removal, can I get some bulk rod and cut it do length to replace it? Share this post Link to post Share on other sites
JUST O&R 237 #21 Posted February 23, 2020 I would just replace it. If Clint is sending you a diaphragm for the carb I know he would have a spear he could send you. Share this post Link to post Share on other sites
JUST O&R 237 #22 Posted February 23, 2020 1 hour ago, Mitymoehelp said: Yes I was thinking of finding a more responsive carb when I eventually build a boat, I have the frame modeled on solid works mostly I just need to get some kinks worked out, the rest of the unit I might restore also just Incase I find out the mity moe is worth a million dollars I don't think it will be worth a million but one thing for sure if you don't put it back together there will be one less. and there's a bunch of engine that you could put in a boat. Share this post Link to post Share on other sites
factory 487 #23 Posted February 23, 2020 2 hours ago, Mitymoehelp said: What would you recommend for a fuel to oil ratio, most modern equipment I think is 50:1 I’m assuming the mity moe calls for a 25:1 or 30:1 The old ratios used were 11:1 till 1963 then 24:1, we have been using 32:1 with modern mineral based 2 stroke oils. 2 hours ago, JUST O&R said: I don't think it will be worth a million but one thing for sure if you don't put it back together there will be one less. and there's a bunch of engine that you could put in a boat. I've only seen a couple of these 1HP engined versions, the larger 1.6HP 20A engined version is only slightly more common due to eight boxed ones appearing from one seller in 2018/19. David Share this post Link to post Share on other sites
Mitymoehelp 5 #24 Posted February 24, 2020 Ok yea I’m not quite sure if I want to put it in a boat it was just a thought and who actually made these engines for Buffalo turbine Share this post Link to post Share on other sites
CNew 409 #25 Posted February 24, 2020 5 hours ago, Mitymoehelp said: Yes I was thinking of finding a more responsive carb when I eventually build a boat, I have the frame modeled on solid works mostly I just need to get some kinks worked out, the rest of the unit I might restore also just Incase I find out the mity moe is worth a million dollars or something haha but I will definitely hold on to the rest of the parts What would you recommend for a fuel to oil ratio, most modern equipment I think is 50:1 I’m assuming the mity moe calls for a 25:1 or 30:1 I would hunt for a different engine for your boat and keep the Mity Moe all together and original. You can still find the O&R engines that aren’t part of actual tools on eBay sometimes. Keeping it original is worth more. Share this post Link to post Share on other sites
