factory 487 #51 Posted July 14, 2019 (edited) On 2/16/2015 at 2:10 AM, tackdriver56 said: Webhead: diaphragm received and metal disc transplanted with Seal-All adhesive. Curing overnight. Tomorrow will be the moment of truth... On 7/14/2019 at 12:15 PM, JUST O&R said: THE DIAPHRAGMS FOR MY OLDER ONE ARE HARD TO FIND I THINK THE # IS 400102. DO YOU KNOW WHERE I COULD FIND A FEW? I have found a service bulletin about the later carb diaphragm membrane assembly part no #400102, used to replace the separate diaphragm membrane (#95-2) & diaphragm disc (#148-1) that may be found in later 1HP engines (or 3/4HP & 0.85HP engines that were serviced at some point in their working lives). If you find one of these diaphragm membranes with the disc bonded to it, be sure to transfer the disc to the replacement diaphragm. David Edited July 26, 2019 by factory Added picture. Share this post Link to post Share on other sites
JUST O&R 237 #52 Posted July 27, 2019 I need help!!!! does someone have a breakdown of the early carburetors the needle valve assembly that I have is to long . Somewhere I must have misplaced it. And there is a hole on the side of it that I have never seen. Share this post Link to post Share on other sites
factory 487 #53 Posted July 27, 2019 That's an early carburettor as you already know, which would have originally had a side mounted needle valve, the diaphragm bowl has a screw in place of the later needle valve shown in your pictures. It's possible it got converted to the later style needle valve at some point in the past, in this case the hole in the side would have a small screw to blank it off, the later needle valve assembly should fit if you unscrew the needle part before fitting. Here are some pictures of a side needle valve carb I rebuilt sometime ago, if you need any more pictures let me know. All the parts (note: that rubber check valve in these goes bad the same as the diaphragm does). Lower half showing side needle valve. Complete early carb (note: the earliest ones didn't have the primer button, but a modification kit was produced for a very short time to add this). David P.S. I'm sure we can find you a side needle valve should you need one. Share this post Link to post Share on other sites
CNew 404 #54 Posted July 27, 2019 That’s very interesting David, thank you for the detailed photos. I’ve never seen one of these really early carbs before. Share this post Link to post Share on other sites
JUST O&R 237 #55 Posted July 28, 2019 Thank you very much I was not sure this thing was take apart 35 years ago. and I don't have all the parts but that makes complete sense now. I have got a few of the newer one this one just looked different. Thanks much do you have a part # for that needle valve? Share this post Link to post Share on other sites
JUST O&R 237 #56 Posted July 28, 2019 p.s. found the Part # I think its an 18-12 also found a pic thank you very much if I didn't see the pic,s I would still be lost. I have three of them nos . Share this post Link to post Share on other sites
factory 487 #57 Posted July 28, 2019 On 7/28/2019 at 1:30 AM, JUST O&R said: Thanks much do you have a part # for that needle valve? Looks like you found the correct one, have a look at the 1961 parts list & separate pdf of the parts diagram, it not the easiest to follow and is very faint in places due to being printed in blue, it's probably the nearest one to your engine. #21-20 is the spring to go with the needle valve. David Share this post Link to post Share on other sites
JUST O&R 237 #58 Posted July 29, 2019 Thanks David got a chance to dig in my boxes found 2 springs. ( THANKS VERY MUCH) Share this post Link to post Share on other sites
factory 487 #59 Posted July 29, 2019 Good to hear you found some. I just remembered that they re-used that spring on later carbs for the governor mechanism, though by 1971 you could no longer obtain it as a spare part, see post #5 linked below. David Share this post Link to post Share on other sites
JUST O&R 237 #60 Posted July 30, 2019 good to know if someone need to find one. Thanks again Share this post Link to post Share on other sites
Brad 0 #61 Posted September 30, 2019 (edited) Need carb kit please contact me. Edited October 1, 2019 by factory Phone & Email removed to help prevent spam & unwanted calls, it's best to send contact information by personal message (PM). Share this post Link to post Share on other sites
JUST O&R 237 #62 Posted October 1, 2019 If you message wallfish he could help you or I seen this on ebay . https://www.ebay.com/itm/Ohlsson-Rice-Carburetor-Gasket-Kit/113 Share this post Link to post Share on other sites
factory 487 #63 Posted October 1, 2019 Welcome to the forum Brad, I don't know where you are located, but a PM to either Wallfish or Webhead if you are in the US or me if you are in Europe and we can help with a new carb diaphragm for your O&R. On 11/28/2014 at 7:59 PM, factory said: Sources for new reproduction Carb Diaphragms USA, contact either @Wallfish or @Webhead. UK & Europe, contact me @factory. David Share this post Link to post Share on other sites
factory 487 #64 Posted October 1, 2019 On 10/1/2019 at 4:55 PM, JUST O&R said: If you message wallfish he could help you or I seen this on ebay . https://www.ebay.com/itm/Ohlsson-Rice-Carburetor-Gasket-Kit/113 The item number seems to have got shortened, try this one instead https://www.ebay.com/itm/113908569482 Question is who on here is selling them on ebay? I don't think it's anyone I've already mentioned. David Share this post Link to post Share on other sites
JUST O&R 237 #65 Posted October 1, 2019 The man on ebay seller info is meatballbutch from it looks like mesa Arizona. looks kike he has 5 thing on there that's the only o&r parts . Share this post Link to post Share on other sites
CNew 404 #66 Posted October 1, 2019 I might be able to help as well but not for another month or so as all my O&R stuff is packed getting ready for a move. Share this post Link to post Share on other sites
JUST O&R 237 #67 Posted October 1, 2019 I Thought you were lost int the Deseret! when are you heading out ? Share this post Link to post Share on other sites
CNew 404 #68 Posted October 2, 2019 End of October. Share this post Link to post Share on other sites
CNew 404 #69 Posted October 2, 2019 Funny - I’ll be a fairly close neighbor to this “meatballbutch” seller on eBay. Mesa isn’t far from where I’ll end up. Share this post Link to post Share on other sites
factory 487 #70 Posted October 2, 2019 I had noticed the ebay seller was located in Arizona, which is why I don't think it's any of the regulars who post on here. Of course the source of the gaskets is mentioned on the forum, so someone not on the forum could have contacted Eric "The Gasket Man" directly and bought a load to sell on ebay, hopefully any buyers of the carb kits on ebay will find us if they need further help with their O&R's. David Share this post Link to post Share on other sites
Wallfish 700 #71 Posted October 2, 2019 On 10/2/2019 at 6:32 PM, factory said: hopefully any buyers of the carb kits on ebay will find us if they need further help with their O&R's. Joe added a link to the old forum in his ebay ads when we started. That was a major advertisement to drive people to it. Maybe contact the seller and ask? I'm just glad to see them being offered as I just don't have the time to do it Share this post Link to post Share on other sites
JUST O&R 237 #72 Posted October 3, 2019 Will I Know if I was looking for parts and had run into that on ebay would not have thought about it I would have grabbed a them. And the price is not bad! but now I know were to find carb parts. Sorry but some one will do it! at lest there not coming out of china. Share this post Link to post Share on other sites
factory 487 #73 Posted October 11, 2019 On 10/2/2019 at 10:23 PM, Wallfish said: Joe added a link to the old forum in his ebay ads when we started. That was a major advertisement to drive people to it. Maybe contact the seller and ask? I'm just glad to see them being offered as I just don't have the time to do it Well I've tried to contact meatballbutch, but as usual ePay has blocked international messages as my address isn't in the US, why do they do this? You can't send helpful information to sellers either. David Share this post Link to post Share on other sites
JUST O&R 237 #74 Posted October 11, 2019 What is your question or comment I will ask him for you ? Share this post Link to post Share on other sites
factory 487 #75 Posted October 11, 2019 On 10/11/2019 at 6:05 PM, JUST O&R said: What is your question or comment I will ask him for you ? Just thought I would ask if they would like to add something to the description to help people find the forum, should they need any help with their O&R's, same as Joe (Webhead) did in the past. Note eBay doesn't like direct links any-more, they tend to automatically remove them. If you could ask for me that would be great, thank you. David Share this post Link to post Share on other sites
