kathy 0 #1 Posted July 10, 2016 HELP - Some advice would be just great to receive. Have a Westwood Gazelle with the Code 79042311 which I believe indicates the year of production as being 1979. The cutter deck was rattling madly, making a hideous noise. Friend offered to take a look and completely took apart the deck, snapping what I think is the cutter spindle or blade boss and removing the pulley and adjacent bearings, nuts and bolts. Sadly I think he has perhaps killed off my Gazelle completely. Have tried to locate replacement washers, pulley, bearings, blade boss, bolts etc to repair the deck, but no luck. I have managed to find a 1983 instruction/spare parts manual but the part numbers listed appear to no longer exist. If there is anyone out there who knows of someone I could contact for old parts then that would be so helpful. I've had my Westwood Gazelle for many years and I'm loathe to give up on it. I'll give all the info I have to hand in case this helps. The Westwood Gazelle is a 5-speed transaxle drive, 11 horsepower 399cc synchro balanced, 4 cycle engine at 360rpm, rear discharge, 36" twin cutters. Model 52707 - Type 0162-01. There is another number but I can't see it all: - -9--1003019. The dashes indicate the numbers that are unclear. Thank you for any help there is. Share this post Link to post Share on other sites
Chris 642 #2 Posted July 10, 2016 Parts are still easy to get for Westwoods Few guys on here dabble with them & sure they will help Share this post Link to post Share on other sites
nigel 1,881 #3 Posted July 10, 2016 What size deck 36" ? Share this post Link to post Share on other sites
the showman 4,074 #4 Posted July 10, 2016 Hi Kathy, a friend of mine has 4 Westwards under his carport but I cant remember if they have decks, we plan to get them out on Tuesday and do some photos of them. If you send Alan a private message he may be able to help. Chris Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted July 10, 2016 Next to last line down, Nigel. Size, model and type. 1 the showman reacted to this Share this post Link to post Share on other sites
Wristpin 400 #6 Posted July 10, 2016 As has been said, parts should not be a problem, as well as forum members , there are a few breakers who advertise on the bay of evil. Try Stuart Oliver stuart.oliver@btinternet.com Or. 01233 820811 Share this post Link to post Share on other sites
the showman 4,074 #7 Posted July 10, 2016 2 minutes ago, Stormin said: Next to last line down, Nigel. Size, model and type. He didn't read that bit Norm Share this post Link to post Share on other sites
Alan 1,274 #8 Posted July 10, 2016 28 minutes ago, the showman said: Hi Kathy, a friend of mine has 4 Westwards under his carport but I cant remember if they have decks, we plan to get them out on Tuesday and do some photos of them. If you send Alan a private message he may be able to help. Chris No decks on any of the 4 Westwoods Chris. Only decks left are 1 Wheelhorse ? and the black one of unknown make. Share this post Link to post Share on other sites
the showman 4,074 #9 Posted July 10, 2016 I think the black one is off the Roper and goes with the black frame we found Share this post Link to post Share on other sites
nigel 1,881 #10 Posted July 10, 2016 As anguus ( wrist pin ) says Stuart Oliver has lots of them Share this post Link to post Share on other sites
