Stormin 4,458 #1 Posted August 4, 2016 The Work Horse, C-125, has been a bit off colour lately. Suspect dirt in the carb. So today off with the float bowl and my suspicion was correct. Some strange foreign particles floating about in there. Cleaned and re-fitted, then started up and did the hand over venturi trick to clear the jets. Re-set the carb for idle then full throttle and the old thing is running like a good un. I then decided to check over the C121 and C81 as they are going to R.P.T. and Biddenden shows. They are both now in the peak of fitness. Here they are, snug as bugs in a rug. 6 Triumph66, the showman, pmackellow and 3 others reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #2 Posted August 4, 2016 Look forward to see them at RPT Norm. Share this post Link to post Share on other sites
pmackellow 2,728 #3 Posted August 4, 2016 Aye looking forward to seeing you in the wilds of Sussex Norm ! Share this post Link to post Share on other sites
Alan 1,271 #4 Posted August 4, 2016 Looking forward to showing you where everything WAS at John's Norm. 2 Stormin and pmackellow reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted August 4, 2016 Looking forward to meeting you, Alan. BTW. I know where most things are now. Pity I'm t'other end of the country. 2 Alan and pmackellow reacted to this Share this post Link to post Share on other sites
Ian 2,417 #6 Posted August 6, 2016 It will be good to catch up with you again Norm Share this post Link to post Share on other sites
