Cub Cadet 613 #1 Posted January 29, 2018 I have an issue with the pull start on the Clinton engine on my RJ, I think its stemming from the fact that the flywheel backing plate is bent and cracked which means the cowl doesn't bolt on how it should, this means that the pull start won't disengage from the flywheel properly and when we start it it catches. Does anyone think the plate can be straightened or does anyone have any spares? Its a Clinton B1290/B1260, thanks Share this post Link to post Share on other sites
Wristpin 400 #2 Posted January 29, 2018 Attempting to straighten a die cast? alloy component has its risks. Is the recoil unit bolted to the cowling? If so, for the time being, could you compensate for the misalignment with spacing washers in the appropriate positions. Alternatively, could you slot the cowling mounting holes in the cowling so as to fudge its alignment on the back plate? 2 Triumph66 and Cub Cadet reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #3 Posted January 30, 2018 As Angus says, straightening it would be dodgy. Besides what he has said, is it possible the get the split welded and then the plate skimmed flat? 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
the showman 4,074 #4 Posted January 30, 2018 Look at my post under stuff for sale Ewan Ive just refreshed it 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #5 Posted January 30, 2018 If searching for spares the part may be listed as a Bearing Plate 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #6 Posted January 30, 2018 The old part number for the bearing was 12336 or 12337 either one, it was superseded by part number 12054 and later 215-70 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
Cub Cadet 613 #7 Posted January 30, 2018 22 hours ago, Wristpin said: Attempting to straighten a die cast? alloy component has its risks. Is the recoil unit bolted to the cowling? If so, for the time being, could you compensate for the misalignment with spacing washers in the appropriate positions. Alternatively, could you slot the cowling mounting holes in the cowling so as to fudge its alignment on the back plate? I might try some spacing washers, the holes are slotted a little already, one problem i've had is that the bolts that holt the recoil on are spotwelded and the spotweld had broken therefore I cannot undo or tighten them, I may have to drill them out 13 hours ago, Stormin said: As Angus says, straightening it would be dodgy. Besides what he has said, is it possible the get the split welded and then the plate skimmed flat? Yes I thought straightening it wouldn't be an option. Share this post Link to post Share on other sites
heliosuk 6 #8 Posted April 12, 2018 If it helps I travel to India 3 or 4 times a year. If you could get the part scanned and turned into a 3D CAD model then I can get it machined from solid very cheaply, alternatively send me the part and I'll do it over there. I've had numerous parts made for me at ridiculously cheap prices. For example I've had 3 mower deck shafts and end stops made for £50 when quoted £500 in the UK and got a load of Bolens tube frame PTO front seals made for I wont say how much as selling them for a stupid mark up but still considerably cheaper than getting them from the states!!. I actually exported some of them to the USA !!! I'm scheduled to go again end of May returning early June this time so if it helps let me know! 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
Cub Cadet 613 #9 Posted April 13, 2018 18 hours ago, heliosuk said: If it helps I travel to India 3 or 4 times a year. If you could get the part scanned and turned into a 3D CAD model then I can get it machined from solid very cheaply, alternatively send me the part and I'll do it over there. I've had numerous parts made for me at ridiculously cheap prices. For example I've had 3 mower deck shafts and end stops made for £50 when quoted £500 in the UK and got a load of Bolens tube frame PTO front seals made for I wont say how much as selling them for a stupid mark up but still considerably cheaper than getting them from the states!!. I actually exported some of them to the USA !!! I'm scheduled to go again end of May returning early June this time so if it helps let me know! Thanks for the offer but we’ve managed to straighten it out and braced it, and I’m getting a spare Engine shortly that I can use if I need to. Share this post Link to post Share on other sites
