Brad 0 #1 Posted October 1, 2019 In search of carb diaphragm the little small ball and the u shaped spring steel piece if anybody has these parts l need payment instructions Share this post Link to post Share on other sites
factory 487 #2 Posted October 2, 2019 Suggestions for a replacement carb diaphragm were given in the carb repair thread, I guess you missed my reply, also someone is selling them on ebay in the US. Ask about the U shaped spring in a personal message to whoever is nearest to you. On 10/1/2019 at 6:52 PM, factory said: Welcome to the forum Brad, I don't know where you are located, but a PM to either Wallfish or Webhead if you are in the US or me if you are in Europe and we can help with a new carb diaphragm for your O&R. On 11/28/2014 at 7:59 PM, factory said: Sources for new reproduction Carb Diaphragms USA, contact either @Wallfish or @Webhead. UK & Europe, contact me @factory. David There are two sizes for the ball bearing used in the carbs, it shouldn't be to hard to find some replacements online or at a hardware shop if you still have a local one (my local one closed a few years ago ). Also note that some later carbs don't actually use the ball bearing, they had a small rubber seal attached to the diaphragm arm. David Share this post Link to post Share on other sites
CNew 406 #3 Posted October 10, 2019 I have some of the little steel balls. I ended up buying a bag of each size. If you’re not in a hurry I could probably get you one in November. All my stuff is packed up for a move. Man it’s hard not being able to work on these things and look at them... If you’re in a hurry the diaphragm and gasket can be purchased on eBay... https://www.ebay.com/itm/Ohlsson-Rice-Carburetor-Gasket-Kit/113909901615?hash=item1a858f292f:g:YgoAAOSwLApdkpGV 1 JUST O&R reacted to this Share this post Link to post Share on other sites
CNew 406 #4 Posted December 28, 2019 On 10/1/2019 at 12:32 PM, Brad said: In search of carb diaphragm the little small ball and the u shaped spring steel piece if anybody has these parts l need payment instructions Brad, Did you end up getting the parts you were looking for? What kind of O&R tool or engine are you rebuilding? Share this post Link to post Share on other sites
