Wallfish 718 #1 Posted January 14, 2020 So a few of us have some NOS parts but if it's contents is anything like mine, there's an abundance of some but nothing for others. So, maybe some trading of parts will help diversify our portfolios, maybe not but might as well make an effort. I'll have to go through what's out there to inventory it. It's not a huge stash of parts but I'm willing to trade the multiples. Carb parts, besides diaphragms, nice recoil housings and the can type gas tanks are always a premium item. Off the top of my head, here's a few I have. NOS newer type governor veins Gov springs for the bottom of the carb There's about 6 or so air filters but those are a coveted item. I'd still be willing to share a couple new and old school high speed carb needles Induction side crank seals 1 or 2 recoil springs new points sets piston rings gearbox gaskets Autolite spark plugs equivalent to the 10 mm Champion UY-6 plugs wire holders for the recoil rope to the spool (but you can use common copper wire for these) For used parts carb diaphragm caps with the primer button Some check valve bottom halves with different fuel inlet locations Some heads different gearboxes. TT generator parts Misc engine parts I'm short on Mufflers Carb arm springs the smaller ball bearing for carb check valve (but I'll have to go check the drawers at the old hardware store again) Share this post Link to post Share on other sites
CNew 408 #2 Posted January 15, 2020 I’ll have to sort through some stuff as well and see if I have many multiples of anything. I have some of the little steel balls for the carb. Do you need the 1/16 or 1/32 size? Share this post Link to post Share on other sites
Wallfish 718 #3 Posted January 15, 2020 1/32 Had some before but they're MIA Share this post Link to post Share on other sites
CNew 408 #4 Posted January 15, 2020 Ok, I’ll see if I can scrounge up a few. Share this post Link to post Share on other sites
JUST O&R 237 #5 Posted January 15, 2020 I have a bag of 50 of each of the balls . I have some carb arm springs not sure how many. I will look Not sure on muffler I will check they are like the air filters and heat baffles they take them off and there gone. Share this post Link to post Share on other sites
CNew 408 #6 Posted January 15, 2020 Found the 1/32 balls last night and can send a few. Share this post Link to post Share on other sites
JUST O&R 237 #7 Posted January 15, 2020 (edited) Have 6 of the arm springs I can send 2 I have 3 mufflers # 122-1 #122-2 # a-11-13 Can send you 1. Also have muffler bolts in I think 3 to 4 sizes and extensions and have 50 - 1/32 balls Edited January 15, 2020 by JUST O&R Share this post Link to post Share on other sites
Wallfish 718 #8 Posted January 15, 2020 3 hours ago, JUST O&R said: Have 6 of the arm springs I can send 2 I have 3 mufflers # 122-1 #122-2 # a-11-13 Can send you 1. Also have muffler bolts in I think 3 to 4 sizes and extensions and have 50 - 1/32 balls Anything you're looking for? Think I have some used baffles but not many. Share this post Link to post Share on other sites
Webhead 95 #9 Posted January 16, 2020 I have tons of odd stuff that I'd like to unload. Including screws and bearings. Share this post Link to post Share on other sites
CNew 408 #10 Posted January 16, 2020 Screws and bearings are always helpful! Share this post Link to post Share on other sites
JUST O&R 237 #11 Posted January 16, 2020 (edited) 13 hours ago, Wallfish said: Anything you're looking for? Think I have some used baffles but not many. A set of baffles would be nice I have a few more that are missing in action. Maybe a few diaphragms I'm getting low on them any thing else you could use before I send this out. Clint what about you any thing you need how about anyone I'm willing to do some horse trading Edited January 16, 2020 by JUST O&R Share this post Link to post Share on other sites
CNew 408 #12 Posted January 16, 2020 Thanks JustO&R- I think I’m ok at the moment, nothing specific that I know of that I need. I think I’m on the hunt just like everyone for those hard to find parts like seals. I don’t have much in the way of parts for the 20A engines but then again I only have a couple of those and I’m not sure how likely it is that part of the collection will grow. I’m more interested in things with the 13A & B Engines. Share this post Link to post Share on other sites
JUST O&R 237 #13 Posted January 16, 2020 9 hours ago, Webhead said: I have tons of odd stuff that I'd like to unload. Including screws and bearings. I could use some baffles if you have any. Share this post Link to post Share on other sites
CNew 408 #14 Posted January 16, 2020 I don’t think I have extras of the larger baffles but I’ll dig through stuff, I may have another small one. Share this post Link to post Share on other sites
Wallfish 718 #15 Posted January 16, 2020 10 hours ago, CNew said: I think I’m on the hunt just like everyone for those hard to find parts like seals. Try soaking the old ones in spray carb cleaner. It swells the rubber. I have sprayed small engine carbs without removing the rubber bowl gasket by mistake. They swell enough to not fit back properly after carb cleaner. I'm not sure how long it lasts but I ended up throwing one out after couple weeks because it never did shrink back to fit. Or maybe I just didn't wait long enough. Try experimenting if you're up for it. Re-generizing those old seals would make them plentiful. Think there was a bunch of the induction side crank seals in that parts stash. Share this post Link to post Share on other sites
CNew 408 #16 Posted January 17, 2020 That might be worth a try. I might have a couple old seals that are too far gone to be useful that I could experiment with to see if they rejuvenate a little, nothing to lose really. FYI- I sent you a PM on another topic... Share this post Link to post Share on other sites
Wallfish 718 #17 Posted January 17, 2020 1 hour ago, CNew said: nothing to lose really. Exactly. These seals don't need to swell very much and the carb cleaner seems to soften them as well. It won't work for the hard brittle stuff but the ones that are still pliable and a little stiff, it should. Just another thing from the bag of tricks! Like Joe told me when I first got into these things, "You gotta be resourceful" Especially for the actual tool stuff attached to the engine. Be sure to share your results! Share this post Link to post Share on other sites
JUST O&R 237 #18 Posted January 17, 2020 Brake fluid will swell rubber to just don't leave the seal in there long or it will fit your ridding mower. 1 CNew reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #19 Posted January 19, 2020 I know talked about this before but did anyone figure out what gasket material to use for the A-13-18 induction gasket and the 5-6 feather valve gasket? Share this post Link to post Share on other sites
CNew 408 #20 Posted January 19, 2020 1 hour ago, JUST O&R said: I know talked about this before but did anyone figure out what gasket material to use for the A-13-18 induction gasket and the 5-6 feather valve gasket? I have a big roll of this vegetable fiber gasket material in the 0.006” thickness. It seems to be very close to the original gasket material. Let me know if you want to try some. https://allstategasket.com/info_gasket_material_style-1165.asp Share this post Link to post Share on other sites
Wallfish 718 #21 Posted January 19, 2020 10 ft by 3 ft is only $25. That would supply the world for a while. I'm in. Those gaskets are nice to have after opening an engine. Do you have NOS gaskets to send along to Eric? I have some if not. Share this post Link to post Share on other sites
CNew 408 #22 Posted January 19, 2020 Can’t remember if I bought that much but I think it was several feet x 3ft so I definitely have plenty of the gasket paper. 1 art faulkner reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #23 Posted January 19, 2020 Sorry been gone all day I'm also in just let me know what you need to get them done . I also have a couple of those gasket's if you need them. This project will run me about out think there's three left in the goody bag. induction case I have 1. This will be a problem very soon. LET ME KNOW AND ILL SEED SOMEONE SOME $$$$ TO GET THIS SHOW ON THE ROAD!!!! Share this post Link to post Share on other sites
CNew 408 #24 Posted January 19, 2020 I’ll try to get by the post office this week and send you both a piece of this gasket paper. Then, we can all assess if we think it will work for these specific gaskets. If so, then we can see what Eric would charge to CAD them up and laser cut us a batch. Just want to make sure we have a good gasket material selected for this- I’m pretty certain it’ll work but I’d like other experts to weigh in on it. In the mean time if one of you with a NOS gasket wants to send me a good photo of each gasket I can send the photos to Eric and get him thinking about it, and maybe quoting the job while we get a consensus on the gasket material. let me know what you think! Share this post Link to post Share on other sites
JUST O&R 237 #25 Posted January 19, 2020 14 minutes ago, CNew said: Just want to make sure we have a good gasket material selected for this- I’m pretty certain it’ll work but I’d like other experts to weigh in on it. Do be leave this We just become experts I did not know it was that easy!! If only David could see me now 1 Wallfish reacted to this Share this post Link to post Share on other sites
