CNew 408 #1 Posted February 18, 2020 Well, what I had hoped was going to be a quick tear down and rebuild as a test engine for new gasket materials and seal alternatives has turned into a bit more of a project. I should have known better with these older model engines... This is is the first I’ve seen of a flywheel that doesn’t have a key. There is a little nub cast into the area where the key slot would normally be, very odd design concept. Mine was ruined upon removal so now I will have to pull another from a donor engine if I have one. It barely protrudes enough to catch the slot on the mating shaft. Another bad design flaw... This engine also has the plastic bearing cages... Share this post Link to post Share on other sites
JUST O&R 237 #2 Posted February 18, 2020 I have the a-27-4 in the new metal bearing should be a-27-17 used I have the a-27-2 in the new # metal bearing a-27-18 only in a new one I have a-27-3 in a used one I don't see an old # for that one If you need one let me know Share this post Link to post Share on other sites
Wallfish 719 #3 Posted February 18, 2020 That "nub" looks like a sheared key to me but there was another guy before stating his flywheel didn't have a key way. The key only lines it up for the timing and the taper is actually what holds it in place. Is the crank slot normal? Now I see what takes you guys so long. All of those neat little compartments for parts takes time. Wish my organizational skills were that good Share this post Link to post Share on other sites
factory 487 #4 Posted February 18, 2020 I remember finding a flywheel like that with some parts engines I bought, it would be interesting to see if the crankshaft is different too. David Share this post Link to post Share on other sites
JUST O&R 237 #5 Posted February 18, 2020 Will were new at this I like to know were my parts are not all over the table and the floor . I seen somewhere on here to use a big pan under the engine so you don't lose parts . 2 minutes ago, factory said: I remember finding a flywheel like that with some parts engines I bought, it would be interesting to see if the crankshaft is different too. I think the one on my s/saw was that way can't remember for sure it was1961 I think is what you said. no looked back at the s/saw post it had a key Share this post Link to post Share on other sites
factory 487 #6 Posted February 18, 2020 I hope he knows that the shaft seals are different in these early engines. The carb with the red needle valve, I'm sure I seen that on the Creme Lure generator, mine doesn't use a Type 115 117 though. David Share this post Link to post Share on other sites
JUST O&R 237 #7 Posted February 18, 2020 good eye didn't see the red needle valve ( but that way we have you ) . Share this post Link to post Share on other sites
Fishnuts2 22 #8 Posted February 18, 2020 The taper is what holds the flywheel, and the key is only there for setting the timing. Just make sure the tapered surfaces are ultra clean, and the flywheel is torqued properly. I've known guys to skip the key on modified chainsaw engines to get the timing where they want. 1 CNew reacted to this Share this post Link to post Share on other sites
factory 487 #9 Posted February 18, 2020 Correct torque tightening is very important, we had someone injure themselves when a flywheel came off, not sure what they were doing but I suspect the starter housing was not attached. They changed the flywheel keys from steel to aluminium for later engines (again the sizes are different) this would allow the key to shear off & prevent keyway damage if the flywheel became loose. David Share this post Link to post Share on other sites
CNew 408 #10 Posted February 18, 2020 I think the shaft slot looks normal. I’ll take a photo later tonight. Share this post Link to post Share on other sites
CNew 408 #11 Posted February 18, 2020 2 hours ago, Wallfish said: That "nub" looks like a sheared key to me but there was another guy before stating his flywheel didn't have a key way. The key only lines it up for the timing and the taper is actually what holds it in place. Is the crank slot normal? Now I see what takes you guys so long. All of those neat little compartments for parts takes time. Wish my organizational skills were that good Yeah, I made the mistake thinking it was sheared and initially tried to remove it and that’s when I found out it was part of the design. I use to be more organized but now that I’ve done a few these you start to know each little piece pretty well. 1 hour ago, factory said: I hope he knows that the shaft seals are different in these early engines. The carb with the red needle valve, I'm sure I seen that on the Creme Lure generator, mine doesn't use a Type 115 117 though. David The seals are different sizes or design? I haven’t removed them from the housings yet. I was also wondering about the little red cap on the needle valve- I hadn’t seen that before. Share this post Link to post Share on other sites
CNew 408 #12 Posted February 19, 2020 6 hours ago, factory said: I remember finding a flywheel like that with some parts engines I bought, it would be interesting to see if the crankshaft is different too. Shaft looks normal to me. Share this post Link to post Share on other sites
CNew 408 #13 Posted February 19, 2020 18 hours ago, JUST O&R said: I have the a-27-4 in the new metal bearing should be a-27-17 used I have the a-27-2 in the new # metal bearing a-27-18 only in a new one I have a-27-3 in a used one I don't see an old # for that one If you need one let me know Can the plastic bearings actually be swapped out with metal ones on these early model engines or is the design too different? Share this post Link to post Share on other sites
JUST O&R 237 #14 Posted February 19, 2020 From what I see they should fit a price list I have the numbers supersede I'm not sure on the a-27-3 I have no # change but it has a metal case. David will know for sure Share this post Link to post Share on other sites
CNew 408 #15 Posted February 20, 2020 Ok, cool that’s good to know - it would be much better with metal bearing cages. Share this post Link to post Share on other sites
CNew 408 #16 Posted February 20, 2020 On 2/18/2020 at 12:09 PM, JUST O&R said: I have the a-27-4 in the new metal bearing should be a-27-17 used I have the a-27-2 in the new # metal bearing a-27-18 only in a new one I have a-27-3 in a used one I don't see an old # for that one If you need one let me know If you have a couple minutes can you send a photo of these? I’m curious to compare the design of the metal to the plastic ones? Wondering if I can find a metal version off a donor engine or something and it would help to have another visual reference since they won’t be NOS with part numbers. Share this post Link to post Share on other sites
JUST O&R 237 #17 Posted February 20, 2020 Here's some pic's hope this helps I had plastic and metal for all this is the order a-27-4 & a-27-17 a-27-2 & a27-18 a-27-3 that's the only number I could fine but i did have a Plastic and a metal Share this post Link to post Share on other sites
CNew 408 #18 Posted February 20, 2020 This is awesome! Yes, very helpful, thank you! Share this post Link to post Share on other sites
factory 487 #19 Posted February 22, 2020 A couple of sources (1971 price list & 1965 parts list) give the following bearing changes, of course it all depends on the age of the engine as to which are used, the changes started happening around 1963/64 following the NIAE test report; Crankshaft main* bearing: A-27-4 use A-27-17. *When they changed the crankshaft main bearings in August 1964 they used part no A-27-8 for this one, for A-27-8 use A-27-16. Backshaft (PTO) reed* & induction housing bearings (2 sets): A-27-2 use A-27-18. *When they changed the PTO shaft reed valve bearings in August 1964 they used part no A-27-4 for this one (1 set), again A-27-4 use A-27-17. The A-27-3 bearing never changed part number for both the plastic & steel cages, I did note the steel cages are slightly thicker than the plastic ones, this may have been because they were used of course (it was a while ago I checked). David Share this post Link to post Share on other sites
CNew 408 #20 Posted February 22, 2020 Thanks for all the research on this David, very helpful knowing the progression and changes in part numbers. Do do you know if the bearing swap is all that’s needed or are there any spacer washers or other pieces requires drivers to fit the metal bearings with the various shafts? I will try to add a photo in a little while of one in particular I’m thinking about. Share this post Link to post Share on other sites
factory 487 #21 Posted February 22, 2020 On 2/19/2020 at 2:27 PM, JUST O&R said: From what I see they should fit a price list I have the numbers supersede I'm not sure on the a-27-3 I have no # change but it has a metal case. David will know for sure By the way the 1971 price list fails to mention* anything about the A-27-11 main con-rod bearing change to A-20-5-13-7, that must be used with a slotted con-rod and also a change of piston & wrist pin, here is the April 1964 parts list information; From the August 1964 parts list, the con-rod main bearing was changed to A-20-5-16-7 with 7-25 washers. David *Which is why it takes a long time to cross check to find the correct information, also note you will find more bearing differences with engines below SN 006072. Share this post Link to post Share on other sites
factory 487 #22 Posted February 22, 2020 23 minutes ago, CNew said: Thanks for all the research on this David, very helpful knowing the progression and changes in part numbers. Do do you know if the bearing swap is all that’s needed or are there any spacer washers or other pieces requires drivers to fit the metal bearings with the various shafts? I will try to add a photo in a little while of one in particular I’m thinking about. I will need to do more research to check about the thrust washers, adding a picture will help confirm which ones you are thinking of too. David Share this post Link to post Share on other sites
CNew 408 #23 Posted February 22, 2020 Here’s one of the shafts and it has a flat washer with the plastic bearing. If I switch to a metal bearing I’m wondering if this washer will still work or if a different set up is needed. Share this post Link to post Share on other sites
JUST O&R 237 #24 Posted February 22, 2020 That must be an early one I think my c/saw had that washer/spacer Share this post Link to post Share on other sites
Wallfish 719 #25 Posted February 22, 2020 Click through the manuals David has posted. There's drawings of the different engines Share this post Link to post Share on other sites
