JUST O&R 237 #26 Posted March 7, 2020 I see you have been doing something I thought you were just sitting home this time of year. looks great color looks great. You seem to paint good when you need to looks great paint matches very good . so is that a chip-a-saw or a bunyan or bonyan YOU do know the chain is on backwards. Made you look 1 Wallfish reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #27 Posted March 7, 2020 Is that some of the new decal ? Share this post Link to post Share on other sites
Wallfish 723 #28 Posted March 7, 2020 39 minutes ago, JUST O&R said: so is that a chip-a-saw or a bunyan or bonyan It has the original Chip A Saw decals on the cover and the bar yet also a painted label on the bar for Bunyan. That's the black label you sent me. Stole it from ya! 1 JUST O&R reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #29 Posted March 7, 2020 I will get you back one day Share this post Link to post Share on other sites
CNew 409 #30 Posted March 7, 2020 That turned out great, nice match on the color! Share this post Link to post Share on other sites
CNew 409 #31 Posted March 16, 2020 I hold very much appreciate some high quality photos and dimensions of both the Chip-a-Saw and Paul Bunyan decals. I’d like to try to work with Titch but he needs some good images and dimensions. Share this post Link to post Share on other sites
factory 487 #32 Posted March 16, 2020 Neither of the pair of later style red chainsaws I bought had any surviving decals, as they were both identical I sold one of them to Paul & he had some decals made from the best image I could find at the time. Here are various images of the Chip-A-Saw & Paul Bunyan decals I have saved from either ePay listings or the web; Wallfish should be able to help with dimensions for the above Chip-A-Saw decal on the red chainsaw (it's from the ePay listing of the one he bought), I forgot to mention that this Paul Bunyan decal image came from another forum, Paul Bunyan chainsaw on forestryforum. David Share this post Link to post Share on other sites
Wallfish 723 #33 Posted March 17, 2020 I can email some pics of the chip a saw decal with dimensions later today if that helps. Might have a print of one from usedtoolman which might be better to use for duplication but let me know. Depending on cost, I could use 3 decals for the older saw. It was stripped down but never painted 2 CNew and factory reacted to this Share this post Link to post Share on other sites
CNew 409 #34 Posted March 19, 2020 Thanks for all the images. What are the dimensions and then I can try to get this info to Titch for evaluation. Share this post Link to post Share on other sites
JUST O&R 237 #35 Posted March 19, 2020 8 hours ago, CNew said: What are the dimensions and then I can try to get this info to Titch for evaluation. I can get you the dimensions for the chip-a-saw if you need them. Can't help with the bunyan if your going to order some chip-a-saw decals i would be interested in a couple myself let me know, Share this post Link to post Share on other sites
CNew 409 #36 Posted March 19, 2020 Sounds good, I’ll definitely let everyone know what the cost estimates look like. Share this post Link to post Share on other sites
Wallfish 723 #37 Posted March 19, 2020 I'm holding those saw parts hostage for free decals Just sent the box today Clint Sent Terry's box yesterday 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 409 #38 Posted March 22, 2020 I sent Titch some of the photos, just need the dimensions and he can put together an estimate for us. I personally like the little Chip-a-Saw decal best. Share this post Link to post Share on other sites
CNew 409 #39 Posted March 22, 2020 I’ve been searching around and I can’t tell if the decals on the Chip-a-Saw recoil cover should be oriented in the normal vertical direction or tilted like the Orline Mustang saws where they’re turned slightly to compensate for the tilt of the engine when mounted in the saw. Is there a consensus? Share this post Link to post Share on other sites
JUST O&R 237 #40 Posted March 22, 2020 10 hours ago, CNew said: I sent Titch some of the photos, just need the dimensions hope this helps . and yes I'm an artist 2 CNew and Wallfish reacted to this Share this post Link to post Share on other sites
Wallfish 723 #41 Posted March 22, 2020 IMO the tilted decal looks funny if there's a bird decal because that is always oriented with the recoil. Without the bird decal, the recoil decal looks better tilted to vertical. Not 100 % sure if mine was original or not but those recoil covers have a factory hole for the switch so I believe it's original because the hole didn't appear to be just drilled out, the paint was original and the decal was oriented with the bird decal. Either way is fine so doing it to your preference is the best way to do it. Maybe the un-branded saw above is the Bunyan which tilted the decal and the Chip A Saw had it oriented with the recoil as I see Terry has his the same 1 CNew reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #42 Posted March 22, 2020 9 hours ago, CNew said: I’ve been searching around and I can’t tell if the decals on the Chip-a-Saw recoil cover should be oriented in the normal vertical direction or tilted like the Orline Mustang saws where they’re turned slightly to compensate for the tilt of the engine when mounted in the saw. Is there a consensus? I think my saw was the original recoil Share this post Link to post Share on other sites
CNew 409 #43 Posted March 22, 2020 1 hour ago, JUST O&R said: hope this helps . and yes I'm an artist Very Nice! Thank you for drafting up the dimensions - I’ll get these over to Titch. Do you think these same dimensions apply to the red version of this decal? It looks like the red one has a larger red border. How much interest is there in the Paul Bunyan decal? I think Titch already did that one before. Share this post Link to post Share on other sites
CNew 409 #44 Posted March 22, 2020 1 hour ago, Wallfish said: IMO the tilted decal looks funny if there's a bird decal because that is always oriented with the recoil. Without the bird decal, the recoil decal looks better tilted to vertical. Not 100 % sure if mine was original or not but those recoil covers have a factory hole for the switch so I believe it's original because the hole didn't appear to be just drilled out, the paint was original and the decal was oriented with the bird decal. Either way is fine so doing it to your preference is the best way to do it. Maybe the un-branded saw above is the Bunyan which tilted the decal and the Chip A Saw had it oriented with the recoil as I see Terry has his the same I tend to agree, I think I like symmetry when there is a bird decal. Share this post Link to post Share on other sites
CNew 409 #45 Posted March 22, 2020 On 3/7/2020 at 10:20 AM, Wallfish said: Am I correct to assume this saw uses a typical chainsaw muffler, the one with the little spark arrestor screen inside? Share this post Link to post Share on other sites
JUST O&R 237 #46 Posted March 22, 2020 Not sure. There was no muffler on mine when I got it. had to make the spacer too and of course it was missing the baffles. Share this post Link to post Share on other sites
factory 487 #47 Posted March 22, 2020 6 hours ago, CNew said: 7 hours ago, Wallfish said: IMO the tilted decal looks funny if there's a bird decal because that is always oriented with the recoil. Without the bird decal, the recoil decal looks better tilted to vertical. Not 100 % sure if mine was original or not but those recoil covers have a factory hole for the switch so I believe it's original because the hole didn't appear to be just drilled out, the paint was original and the decal was oriented with the bird decal. Either way is fine so doing it to your preference is the best way to do it. Maybe the un-branded saw above is the Bunyan which tilted the decal and the Chip A Saw had it oriented with the recoil as I see Terry has his the same I tend to agree, I think I like symmetry when there is a bird decal. See post #32, one of the pair I imported has the vertical decal & the other has it tilted, both have the switch fitted are have engine type 13A253. I guess it your choice which you prefer if you need a new decal. David Share this post Link to post Share on other sites
Wallfish 723 #48 Posted March 22, 2020 1 hour ago, CNew said: Am I correct to assume this saw uses a typical chainsaw muffler, the one with the little spark arrestor screen inside? A regular muffler is fine too. That's what was on there and it was clean so just reused it. If it was crappy then maybe change it. Don't sweat the little details on a chainsaw. Save that 100% original stuff for the good ones! Share this post Link to post Share on other sites
factory 487 #49 Posted March 22, 2020 A pair of Chip-A-Saw or Bunyan's, the O&R instruction decal position/rotation differs on these. David 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 409 #50 Posted March 22, 2020 1 hour ago, Wallfish said: A regular muffler is fine too. That's what was on there and it was clean so just reused it. If it was crappy then maybe change it. Don't sweat the little details on a chainsaw. Save that 100% original stuff for the good ones! Yep, I was just scrounging through old saws and parts trying to find the cleanest pieces I can since this will be a full restore job. Would like it to all match as much as possible with new paint and decals (hopefully new decals, we will see what Titch comes back with). Definitely saving the NOS parts for the rarer items. Share this post Link to post Share on other sites
