Mebob2 8 #1 Posted April 8, 2020 (edited) Hi guys, I’ve been reading your site for awhile now, never posted before, just newly registered. Incredible info here, lots of talent. I just got 2 O&R tiny generators. I’m the 3rd owner, 2nd owner only hade for a few days. They were advertised as new, never used. I can’t really confirm that but they are in incredible condition, look like new. The 2nd owner said he didn’t try to start them so my plan was to strip them down, clean, reassemble and get running if possible. A little pull on start cord seems to indicate lots of compression. I’m mechanically inclined but not a mechanic have tinkered with small engines, cleaned a few carbs. You guys have great tutorials. Should I tackle it or just try to sell them ? I’ll get a couple of pics and post them. appreciate your replies thanks, Rob Edited April 8, 2020 by Mebob2 Share this post Link to post Share on other sites
Wallfish 718 #2 Posted April 8, 2020 Rob Typically to get them running a new carb diaphragm is required if it ever had fuel in it before. You can easily open the diaphragm cap on the carb and check it. If it's stiff at all it will need to be changed to get it to pump fuel and that also indicates that the carb will need to be cleaned because of sticky old 2 stroke oil in there. Maybe after you get it to run you won't want to sell. These little airplane type engines are kinda of fun to run. We can hook you up with diaphragms if you need them. A NOS engine would most like have a clean white pull cord and no exhaust residue in the collection manifold. Wipe a clean white towel or cloth inside there to check. If you do sell them it might be best to have them running before that to demonstrate to perspective buyers. I prefer non runners as they're typically less expensive and I like to work on them anyway. Share this post Link to post Share on other sites
Mebob2 8 #3 Posted April 8, 2020 Thank you for the reply, very helpful. Here are some pics of one, maybe you could identify the small piece I found in the box it came in. I also would be interested in any parts you could lead me too that I might need to rebuild 2 carburetors. Could also use a new black receptacle. Again, appreciate your thoughts . Rob 4 JUST O&R, CNew, factory and 1 other reacted to this Share this post Link to post Share on other sites
Mebob2 8 #4 Posted April 8, 2020 (edited) Here are some pics of second unit. The pull cord cover is oxidized a bit but appears not to be damaged. This one says “110/220 “ as well, maybe they are all the same, I don’t know Edited April 8, 2020 by Mebob2 3 CNew, pmackellow and factory reacted to this Share this post Link to post Share on other sites
Wallfish 718 #5 Posted April 8, 2020 nice. 240v would be the European version. Whats your location? open the carb caps and check the diaphragms. Not sure but maybe that piece is a spacer where it mounts to the base? electrical receptical here https://www.ebay.com/itm/MPJ-32040PL-AC-POWER-SNAP-IN-OUTLET-RECEPTACLE-JACK-NEMA-1-15R-2-WIRE-15A-125V/401227594123?hash=item5d6b07398b:g:H30AAOSwImRYLkHk Make sure you check the air cleaners. If there's any foam inside, poke at it to see if it crumbles. If it does you'll need to remove it all or it will get sucked into the engine I have a few generators but those are nice. If your plan is to sell, let me know what your asking Share this post Link to post Share on other sites
Mebob2 8 #6 Posted April 8, 2020 I really appreciate your help and direction. I’m in Nova Scotia, Canada . Is the fuel line easy to get, is it similar to modern small engine fuel line. tks, Rob Share this post Link to post Share on other sites
Wallfish 718 #7 Posted April 8, 2020 yes, fuel line is the same. Share this post Link to post Share on other sites
Mebob2 8 #8 Posted April 8, 2020 Very good, I’ll likely start by taking the 220v one apart on weekend. Get exhaust, fuel tank off, plug out and see what piston, cyl walls look like. If I put some oil down plug hole would it be ok to pull it over to check for spark? Share this post Link to post Share on other sites
factory 487 #9 Posted April 8, 2020 Very nice, there aren't many 220/240V versions about, even in the UK where our mains supply is that voltage. The first one with the serial decal, has an engine dating from Feb 1968, can't see the plate clearly enough on the second one to comment on the date. I recommend changing the filter foam, even though they don't look used, 50+ year old foam ages badly and will crumble apart. 2 hours ago, Wallfish said: If you do sell them it might be best to have them running before that to demonstrate to perspective buyers. If he plans to sell & ship them, it may be best not to run them, as gas & shipping companies are not a great mix. I had someone send an O&R bike kit full of gas, USPS seized it as it was leaking out of the box and that was the end of that. 1 hour ago, Mebob2 said: If I put some oil down plug hole would it be ok to pull it over to check for spark? Yes distributing a small amount of oil around the cylinder & piston is a good idea as it will prevent it getting stuck in long term storage, be sure to park the piston so that it blocks the exhaust ports if storing. David Share this post Link to post Share on other sites
Mebob2 8 #10 Posted April 10, 2020 I posted a pic with a better view of serial number on 220v unit. I watched a great video on the disassembly of a tiny tiger generator, I spent the last 2 evenings looking for it again, no way can I find it, any idea of where it may be? thanks again for help, I have no spark on 220v unit, so starting to take apart and check points Share this post Link to post Share on other sites
Wallfish 718 #11 Posted April 10, 2020 Not a video but you can follow through this thread. Mine was a lot rougher looking than yours are Share this post Link to post Share on other sites
factory 487 #12 Posted April 11, 2020 11 hours ago, Mebob2 said: I posted a pic with a better view of serial number on 220v unit. I watched a great video on the disassembly of a tiny tiger generator, I spent the last 2 evenings looking for it again, no way can I find it, any idea of where it may be? thanks again for help, I have no spark on 220v unit, so starting to take apart and check points That one has an engine made in Feb 1974, which was the last year that these engines were branded as O&R, in December 1974 they started advertising under the new name of AEP (Advanced Engine Products Inc). I've not seen any videos that I can recommend, none of them seem to do any research into how to repair these engines beforehand, but then again you've got to remember they are mainly made for entertainment purposes only and aren't really tutorials. As well as the Tiny Tiger rebuild guide @Wallfish posted, there are others here for the carb & engine, also if you don't have the original manual for those Tiny Tigers I scanned mine & added it to the Manuals thread. David Share this post Link to post Share on other sites
Mebob2 8 #13 Posted April 11, 2020 Thanks David, much appreciated, nice to have the serial number info. I’m pretty much set to go to try and rebuild them just need a contact for carb parts if you could point me in right direction. thanks again Ronert Share this post Link to post Share on other sites
factory 487 #14 Posted April 11, 2020 (edited) Contact either @Wallfish or @CNew by private message & they should be able to supply some new laser cut carb diaphragms. What condition were the original ones in? The later Tiny Tiger engine may use the carb with the rubber pad attached to the diaphragm arm, we don't have a source for replacing these, but hopefully it will still be OK if it's not been run. If not we can advise alternate parts. David Edited April 11, 2020 by factory Share this post Link to post Share on other sites
factory 487 #15 Posted April 15, 2020 @RobertDFW I'm a bit confused as to why you've quoted that post twice but haven't added a comment or question about it. David Share this post Link to post Share on other sites
RobertDFW 1 #16 Posted April 15, 2020 7 minutes ago, factory said: @RobertDFW I'm a bit confused as to why you've quoted that post twice but haven't added a comment or question about it. David I'm sorry I don't mean to be unkind. Or anything to hide I just simply didn't understand the format of the Forum I guess 1 Wallfish reacted to this Share this post Link to post Share on other sites
Wallfish 718 #17 Posted April 15, 2020 11 minutes ago, RobertDFW said: I'm sorry I don't mean to be unkind. Or anything to hide I just simply didn't understand the format of the Forum I guess It's No problem. I can delete those posts. Do you have a question to ask about it? There's a little "Thumbs up" at the lower right of each post which you can use to react to any post but don't necessarily want to reply. 1 RobertDFW reacted to this Share this post Link to post Share on other sites
factory 487 #18 Posted April 15, 2020 43 minutes ago, RobertDFW said: I'm sorry I don't mean to be unkind. Or anything to hide I just simply didn't understand the format of the Forum I guess That's OK, if you do have any questions about the Tiny Tiger or these engines we will try & help. David Share this post Link to post Share on other sites
RobertDFW 1 #19 Posted April 15, 2020 thanks David it was just like the one that had been refurbished on this form I don't know if I'll keep it or sell it or what it all depends on what it's worth can you tell me refurbished what they're worth please her And that's a thumbs-up on the thumbs up LOL Share this post Link to post Share on other sites
factory 487 #20 Posted April 17, 2020 Here is what I said around 12 months ago when someone asked about the value of a Tiny Tiger, along with certain chainsaws they are very common, remember to check recent sold prices/completed listings, but be very careful with "buy-it-now" items as ePay hide the actual lower sold price if "best offer" was used. I'm not sure a refurbished one would sell for more than a nice clean original one, it all depends on the amount of people interested at the time of selling and what they are prepared to pay. David On 5/25/2019 at 1:05 PM, factory said: Welcome to the forum Alex and thanks for posting pictures of your Tiny Tiger. It looks like it maybe the very common Model 300 (the band around the generator with these details is missing), these don't make anywhere near that (where did you get the 350 figure from?) as they were very popular in the 1960's and so many have survived. From your pictures I can see the condenser needs a repair, the spark-plug lead reattaching and the cylinder side plate is missing, also I can't tell if the primer button is missing from the carb or if the carb has one of the top covers without this. Model 300 Tiny Tiger generators in this condition typically make around $75 to $125. Rarer models with the larger tank and boxed like new ones can make around $200 to $250 or sometimes more dependant on the number of interested buyers at the time. Here is a current screen-grab of completed listings on eBay.com, even that very nice condition complete Tiny Tiger with paperwork only made $138. Hope this helps with the value and I'm sorry if it seems a lot lower than you thought. David Share this post Link to post Share on other sites
