CNew 408 #1 Posted April 11, 2020 Might tackle this one next. Has some original Octura brochures and a few parts. The engine mount and prop assembly are both genuine Octura. 1 Wallfish reacted to this Share this post Link to post Share on other sites
factory 487 #2 Posted April 11, 2020 What happened to the rest of the parts? I thought the lot included another boat mount & some other fittings. None of the three engines in the lot you bought are anywhere near new enough to go with that 1977 brochure, is the other one older? Also I've seen this engine before, it last sold in 2017. The rest of the parts & literature (dated 1971 on price list) look suspiciously like the parts from this lot (also sold in 2017), but the newer engine wasn't in the lot you just bought. David Share this post Link to post Share on other sites
CNew 408 #3 Posted April 11, 2020 I think I have most of those other parts. Many of the other items are for smaller boats and not the 1 hp O&R, or maybe a smaller O&R engine. Yes, the brochures are mainly for other smaller engines as well and are 70s era. By the way - I didn’t pay that price... Share this post Link to post Share on other sites
Webhead 95 #4 Posted April 12, 2020 I have an Octura engine with the high performance rotary valve installed in my White Heat, instead of the feather valve. It makes the engine sound much meaner and probably increases power output. That would be a pleasant surprise if yours has one. David, have you ever seen any paperwork on the rotary valve? Share this post Link to post Share on other sites
CNew 408 #5 Posted April 12, 2020 Very cool, I bet that would be a fun boat to blast around a small lake or pond. I tore this one apart this afternoon. I didn’t see anything out of the ordinary and it has the usual feather vane. I’m curious what the rotary valve looks like that’s in your engine. Do you have any photos? Share this post Link to post Share on other sites
Webhead 95 #6 Posted April 12, 2020 I do not. Is there any mention in the Octura catalogs? I used to run it with my son using a high quality Futaba controller. It was very cool, except when it died in the middle of the lake. Share this post Link to post Share on other sites
CNew 408 #7 Posted April 12, 2020 I’ll take a closer look but in my brief skim I don’t recall seeing anything in there on the 1 hp O&Rs. Share this post Link to post Share on other sites
Webhead 95 #8 Posted April 12, 2020 I think it’s pretty rare. I read about them some where in the past, maybe the old forum, and then I happened upon one. Share this post Link to post Share on other sites
Wallfish 709 #9 Posted April 12, 2020 8 hours ago, Webhead said: Octura engine with the high performance rotary valve Is that engine run on glow fuel or just gasoline? Share this post Link to post Share on other sites
factory 487 #10 Posted April 12, 2020 11 hours ago, Webhead said: I have an Octura engine with the high performance rotary valve installed in my White Heat, instead of the feather valve. It makes the engine sound much meaner and probably increases power output. That would be a pleasant surprise if yours has one. David, have you ever seen any paperwork on the rotary valve? I don't actually have much paperwork for anything to do with Octura except a leaflet from a UK reseller of them, that doesn't mention the special rotary valve. Does it look similar in design to the rotary valves used on the older O&R model plane engines (before the Compact engine existed)? David P.S. just ordered an Octura 1965 catalog featuring the O&R powered White Heat, will see if that has anything in it when it arrives from the US. Share this post Link to post Share on other sites
Webhead 95 #11 Posted April 12, 2020 4 hours ago, Wallfish said: Is that engine run on glow fuel or just gasoline? Gas Share this post Link to post Share on other sites
JUST O&R 237 #12 Posted April 12, 2020 Clint nice looking engine are you going to put it in a boat or shelf ? that looks like most of the parts for the drive. do you have a boat ? I have toyed with that but no scroll saw and I'm not good with wood one good hit with a hammer and it's done . Share this post Link to post Share on other sites
CNew 408 #13 Posted April 12, 2020 I’m hoping to put it in a boat some day- it’ll be a nice shelf piece for now. I tore it apart yesterday and getting it back together today/tomorrow so it’ll be ready when the right boat comes along. After opening it up I don’t think the engine has been run much at all. There was no carbonization and all the little plastic bearing cages looked new. I’m still kicking myself for not buying the O&R boat I had a chance at when I was back in Minnesota. I need to figure out what all bits and pieces I’m missing - like drive shaft, collars, etc. Share this post Link to post Share on other sites
JUST O&R 237 #14 Posted April 12, 2020 I have a engine and the bracket but that's it. one day I will get my ducks in a row. Share this post Link to post Share on other sites
CNew 408 #15 Posted April 12, 2020 All cleaned and buttoned up... 2 Wallfish and pmackellow reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #16 Posted April 13, 2020 looks good just need to find a boat. Share this post Link to post Share on other sites
Webhead 95 #17 Posted April 13, 2020 I'm sure most of you have seen this, but scroll down quite a bit and there is is a good read on these engines, including the mention of a "hopped up" version for race enthusiasts. http://collectair.org/vintageengines.html 2 JUST O&R and CNew reacted to this Share this post Link to post Share on other sites
CNew 408 #18 Posted April 13, 2020 Very cool, man no wonder they called it White Heat, that’s nuts! That’s a nice little article/write-up as well - thanks for posting the link. Share this post Link to post Share on other sites
factory 487 #19 Posted April 13, 2020 O&R listed the water-cooled cylinder in the 1962 parts diagram (part no. #A-40-3), I'm still looking for a decent one for my engine, but I do have the large exhaust and an Octura carb. And I should point out that there are other versions of the White Heat hydroplane for smaller engines than the Compact engine. David 1 CNew reacted to this Share this post Link to post Share on other sites
factory 487 #20 Posted April 13, 2020 If anyone is interested there is an O&R with the Octura V-8 style exhaust on ePay at the moment; https://www.ebay.com/itm/383498494441 The same seller has another lot with some other parts including the correct Octura mount for the O&R, shame it's mixed in with a load of other parts; https://www.ebay.com/itm/383498470128 Note: these are only available for shipping to United States, Canada, Bahamas, Uruguay. David Share this post Link to post Share on other sites
factory 487 #21 Posted April 21, 2020 On 4/12/2020 at 12:46 PM, factory said: On 4/12/2020 at 1:32 AM, Webhead said: I have an Octura engine with the high performance rotary valve installed in my White Heat, instead of the feather valve. It makes the engine sound much meaner and probably increases power output. That would be a pleasant surprise if yours has one. David, have you ever seen any paperwork on the rotary valve? I don't actually have much paperwork for anything to do with Octura except a leaflet from a UK reseller of them, that doesn't mention the special rotary valve. Does it look similar in design to the rotary valves used on the older O&R model plane engines (before the Compact engine existed)? David P.S. just ordered an Octura 1965 catalog featuring the O&R powered White Heat, will see if that has anything in it when it arrives from the US. The 1965 Octura catalog arrived today, the main catalog doesn't have anything O&R in it, but the extra newsletters, leaflet & the price list does. The Octura rotary valve is mentioned as being available in 1966, other modifications mentioned for boosting performance include throwing away the governor vane & the ball valve mechanism from the carb, boring out the carb (this requires a making a new butterfly throttle) and different fuel mixes. Also sold by Octura in the US was the Sea Queen boat kit, imported from Aerokits in England. David Share this post Link to post Share on other sites
Webhead 95 #22 Posted April 22, 2020 David, can you please post a copy of the performance upgrades mention? I’ve never seen anything on paper, only heresy from somebody else. Actually, anything about the White Heat would be great. Thanks Share this post Link to post Share on other sites
kdsbrs 1 #23 Posted April 29, 2020 Does anyone have full size plans for the White Heat X? Bruce Share this post Link to post Share on other sites
Daren89 18 #24 Posted April 29, 2020 Yes I do Regards Daren Share this post Link to post Share on other sites
Wallfish 709 #25 Posted April 30, 2020 2 hours ago, Daren89 said: Yes I do Regards Daren Are you interested in sharing? selling? I'd be interested in building one Share this post Link to post Share on other sites
