Mike in NC 37 #1 Posted July 27, 2020 (edited) Here is a link to my wife's O&R collection. She also has a Tiny Tiger (not pictured) that is partly disassembled. It all started with the yellow pump (Type 217) that a friend of her grandfather gave me. Jen's O&R Collection Edited July 27, 2020 by Mike in NC 4 1 Wallfish, factory, pmackellow and 2 others reacted to this Share this post Link to post Share on other sites
Wallfish 724 #2 Posted July 27, 2020 Glad you found us Mike. I remember seeing that page when I first got into collecting O&R engines a while back. 1 Mike in NC reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #3 Posted July 27, 2020 Nice collection ! 1 Mike in NC reacted to this Share this post Link to post Share on other sites
factory 487 #4 Posted July 27, 2020 Nice collection, the Derby Tiller was also made by Little Wonder (same as the hedge cutter next to it) I scanned the manuals a few years ago as Little Wonder didn't have them on their website. The NOS water pump looks to be a Kenco and the yellow engine with gearbox looks to be from a chainsaw with that style of muffler. David 1 Mike in NC reacted to this Share this post Link to post Share on other sites
Mike in NC 37 #5 Posted July 28, 2020 Factory, you are correct about the pump. It is a Kenco Model 61. The yellow engine with the gear box is NOS and it does not have mounting tabs on the base, they seem to have been milled off, and the output shaft is cut off with a plug closing off the hole. Our friend that we got it from said that it was a display unit for salesman to show off. Here is a picture of the output side. 3 pmackellow, CNew and factory reacted to this Share this post Link to post Share on other sites
factory 487 #6 Posted July 28, 2020 It's certainly an interesting display engine. The base tank (part no #A-32-26) with no mounting tabs was made for at least one tool, the Orline Yard-Arm, but that doesn't use a gearbox as it's direct drive, is it possible it's been added to display the engine? The blanked off PTO shaft is used when the shaft is fitted to the other side of the gearbox, i.e. towards the engine, the chainsaws & bicycle engine kits are set up like this. That style of muffler/exhaust is used on some of the chainsaws, such as the Model 13 Mustang. Has it got a engine model/type stamped into the cylinder baffle plate or on the end of the crankcase mounting flange (exhaust side)? David 2 Mike in NC and CNew reacted to this Share this post Link to post Share on other sites
Mike in NC 37 #7 Posted July 29, 2020 (edited) Stamped on the cylinder baffle plate is "13B 329" I looked behind the gear box and there is no shaft on that side either and there is no clearance for a shaft or something to attach to the gearbox with that gas tank on it. Our friend that we got it from said he was told that it was a store display unit. The gas tank has no signs of gas ever being in it. I will try to get some other pictures of it maybe tomorrow, to show no shaft and no clearance. Edited July 30, 2020 by Mike in NC Share this post Link to post Share on other sites
CNew 409 #8 Posted July 29, 2020 That’s interesting. It has a 13B exhaust collector and muffler like some of the Orline chainsaws but looks to have a 13A recoil cover. Neat piece to have in your collection. 1 Mike in NC reacted to this Share this post Link to post Share on other sites
Wallfish 724 #9 Posted July 30, 2020 Hmm, just a guess but it probably is a chainsaw engine and put together for a display engine. The missing screws for the gearbox is most likely because the chainsaw cover screws that went there would have been too long and hit the tank without the spacing of that cover. And guessing the shaft was cut off for the engine to sit on that particular type of tank. All just $0.02 Share this post Link to post Share on other sites
factory 487 #10 Posted July 30, 2020 Unfortunately my information is missing engine Type 329 but the short-block replacement list does include it (doesn't give use). I think it was a chainsaw engine, I can see some of the starter housing screws have nuts on the back, this is because most of the screws would have gone through the back-plate and straight into the chainsaw tank. The starter is the wrong type for a 13B, but fitting the 13A or Compact I, II or III type would also require a change of flywheel as the starter dogs are different. It's strange that it uses a very late coil, but the air filter is only a single stage type, possibly been added as some chainsaws use a completely different type. Of course none of this really matters if it was a new spare chainsaw engine that was setup for a shop display. For comparison this is an engine that was on a Mustang Model 13 chainsaw. And here is the same engine on this chainsaw. David 3 Mike in NC, CNew and pmackellow reacted to this Share this post Link to post Share on other sites
Mike in NC 37 #11 Posted June 16, 2022 Our old website host no longer is around so we had to start over and redo our site. Here is the current link to my wife's O&R collection Jen's O&R Collection 2 1 pmackellow, factory and Kevgall reacted to this Share this post Link to post Share on other sites
factory 487 #12 Posted June 17, 2022 On 7/29/2020 at 3:03 AM, Mike in NC said: Stamped on the cylinder baffle plate is "13B 329" I looked behind the gear box and there is no shaft on that side either and there is no clearance for a shaft or something to attach to the gearbox with that gas tank on it. Our friend that we got it from said he was told that it was a store display unit. The gas tank has no signs of gas ever being in it. I will try to get some other pictures of it maybe tomorrow, to show no shaft and no clearance. I've now got more information, engine type 13B329 in for an Orline chainsaw, release date was 7-18-73 according to the list. David 1 Mike in NC reacted to this Share this post Link to post Share on other sites
Mike in NC 37 #13 Posted June 26, 2022 I will be getting these out and ready for an upcoming show. I will try to get some more pictures and also have a new addition to her collection to take pictures of and add to the web page. Thank you for your help!! Share this post Link to post Share on other sites
Mike in NC 37 #14 Posted June 27, 2022 Here is the newest addition to her O&R collection. It appears to be NOS with the factory box. The serial numbers match. 2 pmackellow and factory reacted to this Share this post Link to post Share on other sites
factory 487 #15 Posted July 15, 2022 That is a Type 133 engine, they were supplied to the military as spares, for use on the military version of the Kenco pump; David 3 Mike in NC, pmackellow and K-TRON reacted to this Share this post Link to post Share on other sites
Kevgall 0 #16 Posted December 19, 2022 I’m looking to buy a OnR tiny tiger generator what’s the price for one in working good condition. and do you know of one for sale Share this post Link to post Share on other sites
CNew 409 #17 Posted December 21, 2022 There are a few on eBay right now, looks like $250-350 range for something decent. Share this post Link to post Share on other sites
Kevgall 0 #18 Posted December 22, 2022 Thanks CNews I’ll take a look Share this post Link to post Share on other sites
