CNew 409 #1 Posted August 9, 2020 Decided to experiment with finishing out a crude soup can gas tank. I bought something a long time ago and it came with a soup can that was mid way through being made into a gas tank by the previous owner. I have the bug to start learning how to solder so I thought I would give it a go and try to finish it up. With a bit more practice I may try to make one entirely from scratch using a can that is a better copy of the O&R tanks. This one is literally a soup can. The can had a hole punched near the filler hole so I just soldered the intake tube there rather than making another hole in the bottom. Since the hole was too large for the 1/8” brass tube I ended up using a piece of 5/32” for the main pickup and added a small section of the 1/8” for the connection to the 3/32” fuel line. I’ll probably just use this tank on one of the engine test stands. 1 pmackellow reacted to this Share this post Link to post Share on other sites
factory 487 #2 Posted August 10, 2020 Looks good to me, the originals probably weren't anything special, I've seen very old beer cans etc. made in a similar way to the O&R tanks, trouble is people collect them too. I've been saving the steel cans that coffee comes in these days, they don't have the corrugated look of a soup/bean can. David 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 409 #3 Posted August 16, 2020 Found this cool shaped 8 oz can. It’s a good size and might make a neat tank for a test stand or maybe even with an O&R engine. Got it all sanded. soldered in the fuel fitting And drilled a small vent hole in the cap. Next up is to paint it O&R red. 1 pmackellow reacted to this Share this post Link to post Share on other sites
CNew 409 #4 Posted August 17, 2020 Painted and ready for mounting. 5 factory, Wallfish, pmackellow and 2 others reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #5 Posted August 18, 2020 That's a cool tank where did you find it? 1 Daren89 reacted to this Share this post Link to post Share on other sites
CNew 409 #6 Posted August 18, 2020 It was a vintage syrup tin. 1 pmackellow reacted to this Share this post Link to post Share on other sites
mattblack 76 #7 Posted August 18, 2020 (edited) 1 hour ago, CNew said: It was a vintage syrup tin. You should have kept quiet, patina'd it and fitted it to an old tool. You'd have had the O&R geeks in a frenzy looking for another one... Edited August 18, 2020 by mattblack 3 1 JUST O&R, pmackellow, Twinsport and 1 other reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #8 Posted August 18, 2020 1 hour ago, mattblack said: You should have kept quiet, patina'd it and fitted it to an old tool. You'd have had the O&R geeks in a frenzy looking for another one... Oi, who are you calling a geek ? 2 Twinsport and CNew reacted to this Share this post Link to post Share on other sites
factory 487 #9 Posted August 21, 2020 That looks very nice, excellent job. David Share this post Link to post Share on other sites
tvenetis 1 #10 Posted December 9, 2022 I made a gas tank using a half pint metal maple sourp can. I drilled the cap just large enough to fit the fuel line in to and it works well. Share this post Link to post Share on other sites
