Drumnagorrach 9 #1 Posted November 8, 2020 hi folks just signed up after buying an Allen Scythe . Any information would be appreciated . It has a Kohler engine fitted which looks original ,maybe the engine wasn't painted gold originally but it is now . any ideas what model and year it's likely to be ? Is there a source of parts ? the tyres are perished , I thought of motorcycle trials front tyres , but maybe something more original is available . I bought it to cut rushes in a couple of fields so it's here to work but if I can tidy it up at the same time it's no bad thing . 1 Triumph66 reacted to this Share this post Link to post Share on other sites
nigel 1,880 #2 Posted November 8, 2020 Need some photos and the id tag if it has one, then someone should be able to help you Share this post Link to post Share on other sites
pmackellow 2,738 #3 Posted November 9, 2020 Welcome to the forum, As Nigel says some photos would help with identification Paul Share this post Link to post Share on other sites
Jarrovian 237 #4 Posted November 9, 2020 was the machine originally red with with cream/off white wheels because the only model fitted with a Kohler K91T fitted was the last TS model made about 1970/1972 engine parts are available from Meetens at Preston who do an excellent mail order service as regards tyres there is a firm called China Parts in county Durham there is also Villiers Parts but George can be a bit troublesome at times so I personally use him but many have had good service Share this post Link to post Share on other sites
Drumnagorrach 9 #5 Posted November 9, 2020 I think yesterdays ride home in my trailer in the rain has upset the engine , no sark today . How do I get the flywheel off , no tapped holes , no nothing to get a grip of ? 1 Triumph66 reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #6 Posted November 9, 2020 Also try John Cruse at The Mower Centre for parts, 01323 842477 Share this post Link to post Share on other sites
Jarrovian 237 #7 Posted November 9, 2020 looking at your picture I would say at a guess it has been re-engined to remove flywheel you will need to make a puller mine have 2 tapped UNC holes to draw it off Share this post Link to post Share on other sites
Drumnagorrach 9 #8 Posted November 9, 2020 (edited) Flywheel now off , any figures for resistance in coil ? just warmed the flywheel taper are and on the opposite side of the backplate to the points is a 1/2 inch hole that a wee punch can contact the flywheel , a few gentle taps and the flywheel came off 😃 Edited November 9, 2020 by Drumnagorrach 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Drumnagorrach 9 #9 Posted November 10, 2020 Not having any resistance values for the coil and condenser to check against ,although the coil has very little at .9 ohms and the condenser seems like it's open circuit, I've got to assume they're duff . I found a coil cheaply from China ,nothing in UK , but I'm struggling to find the correct condenser outside of US . And there lies the problem , a $9 part but a $15 shipping cost and then there's customs and the damn post office who ransom your part until you've paid the duty and then charge you to collect the duty . So , anyone know where I can find one in the UK ? it's unusual in that it has a screw connection on the end and a mounting bracket at 90 deg to the axis of the cylindrical body . Share this post Link to post Share on other sites
Stormin 4,458 #10 Posted November 11, 2020 Try Meetens at Preston. They're good for Kohler parts. Share this post Link to post Share on other sites
Drumnagorrach 9 #11 Posted November 11, 2020 9 hours ago, Stormin said: Try Meetens at Preston. They're good for Kohler parts. Thanks ,I did try them but they could only offer to fit new innards into my old casing for £28 ,it's only a condenser so if I can't get one cheaply from the US ,I'll fit a car condenser outside by the points. Share this post Link to post Share on other sites
Jarrovian 237 #12 Posted November 11, 2020 at £28 it is a lot cheaper than getting one from America with postage and possible import tax rolloman at Edinburgh might be able to help Share this post Link to post Share on other sites
