Mattyk 0 #1 Posted April 10, 2021 (edited) Hi.... I've recently bought a couple of howard rotavators. One being a howard gem with a kohler k301t engine. Unfortunately it has no spark and after testing with a multimeter the coil is dead. I've tryed looking for a replacement on Internet but can't seem to find one. Can anyone point me in the right direction at all? It's a tecumseh coil so I'm presuming this is the original? Thanks in advance Matt Edited April 11, 2021 by Mattyk Share this post Link to post Share on other sites
howardman 30 #3 Posted April 11, 2021 Those coils are easily sourced on eBay UK.....one Chinese seller has one for just over a tenner...... just type in kohler K301 and scroll down.There is also a company called "Guy parts and service" (just type this into google).. a chap called Mike Hitchin in kenilworth who has the coils and also electronic ignition units ...that eliminate the points ... worth getting as the points often need cleaning on these machines. There are also plenty of non original carbs for theses engines available on eBay and other sites. Share this post Link to post Share on other sites
Wristpin 399 #4 Posted April 12, 2021 Fairly sure that it’s the same coil that was used on Tecumseh, Aspera and Kirby Lawson etc on stators branded Phelon, Ducati and Marelli etc . A scrap pre electronic Flymo should yield one. Share this post Link to post Share on other sites
Mattyk 0 #5 Posted April 12, 2021 Hi and thanks for the replys.... Think it reads tecumseh on the top of the coil. Still can't seem to find one on eBay. If anyone see's one put the item number on here if you would. Cheers guys. Share this post Link to post Share on other sites
Jarrovian 237 #6 Posted April 13, 2021 there are several suppliers of Kohler parts one I use regular is MEETENS at PRESTON LANCS they do excellent mail order try NOT to use Chinese coils they tend not to fit or fail very quickly 1 1 Stormin and Mattyk reacted to this Share this post Link to post Share on other sites
howardman 30 #7 Posted April 14, 2021 (edited) I changed those coils several times on different kohler gems. The circular black coil bit is removed from the metal horseshoe bit of your old coil after removing the metal clip on the side. The replacement coil (black circular piece only ) is pushed down onto your old metal horseshoe shaped piece . Do not get hung up on the tecumseh marked on the old plastic coil ....the replacement round black coils on ebay or from Guy parts and service (where i got mine) will fit down on to the metal section you have ..once you remove the black tecumseh piece first. Edited April 14, 2021 by howardman Share this post Link to post Share on other sites
Mattyk 0 #8 Posted April 14, 2021 Ahhhh right OK. No wonder I've been struggling to find one, I've been looking for a direct bolt on replacement with the mounting bracket. doh.... Never had dealings with Howard rotavators and minimal knowledge on the older machines. Thanks for the info mate 👍 Share this post Link to post Share on other sites
Fix'em all 49 #9 Posted April 15, 2021 The vintage chainsaw guys in a US based group I am in always heat these old coils in an oven. 200F (90c) for 2 hours will very often bring the spark back. Take care that the wife does not return home during this period as a back hander with a frying pan is quite memorable 😃 1 Mattyk reacted to this Share this post Link to post Share on other sites
Mattyk 0 #10 Posted April 15, 2021 Haha 😂 I might give it a go... As long as I don't serve it up with the wife's dinner I should be safe 😜 Cheers for the tip. Share this post Link to post Share on other sites
