ill do a propper job of removing the neg/earth loop..i wasnt sure about the wiring so just snipped it to try it...the farms on very dodgy old wiring so iv had to learn how to wire the shed etc.at the time.i really didnt see much point in hammering a 5ft earth rod through stoney ground......im glad titch nagged me about rcd's and earths now really
this is the bottom right of the control box where the power comes in...the blue (negative) which was looped to the earth, iv snipped the loop and taped it ,,
the blue looped cable looks factory,was run up into the conduit and is in the same shrink wrap as the earth,,,could there be any reason that it has been wired like this??
your right..............i'll post a few pics tommororow...........its got a control panel/box and where the main power comes in above that where the power was distributed the negative had been piggy backed accross to the earth? it looks factory? i snipped the loop and it works fine...it has had a new power cable and plug fitted and im guessing the previous owner thought it was knackered and stuck it in the auction........3 phase scares me to death ......thanks for your replies chaps
warwick
hi, our house is fed with 3 phase it runs straight into 3x 25 amp wire fuses from there it goes to my old workshop.again to wire fuses..iv moved the workshop to a bigger shed..iv run a 6mm 5 core cable accros to the new shed from the 25 amp fuses in the house.....in the new shed iv used a 64 amp twist on/off switch then to a plastic box as described below
16A 5 pin socket 3P + N + E IP44 (no overload protection)
32A 5 pin socket 3P+N+E IP44 ( no overload protection)
4 Pole RCD 63A 30mA
2 Pole RCD 63A 30mA
2 x 16amp MCBs
2 x 240V 16A 3 pin Commando Industrial Socket IP44 (RCD and overload protected)
Enclosure dimensions:
H 240mm, W 190mm, D 150mm
Dimensions with sockets:
H 240mm W 300mm D 150mm.
We can change sockets on request, please send us a message prior to buy.
400V3phase16A&32A 5 Pin RCD Industrial Socket +240V16A 3pin .Distribution board.
my 300 amp butters mig/400 amp inverter stick and plasma all work fine no issues........
yesterday i bought a BIG horizontal 3 phase band saw,it was getting dark when i got home so unloaded it straight into the old shed on wire fuses,plugged it in and it worked great..today i managed to get the saw into the new shed, plugged it in and it just pops the rcd..i have turned the master switch to off on the band saw and it still trips the rcd...if i run the saw with our standby generator it works fine any ideas could well be a big help
iv never seen such a great paint job done with rattle cans......absolute credit to you..
i bought it to break as i needed the pto clutch.....dash......carb etc etc......i thought id fit a starter motor and see what it went like.......im really impressed with it....ill post a video of it as soon as it uploads.....
iv managed to buy a c120 auto (pics to follow)......what are the gearboxes like??
and i thought it was just me that played like that...........
i was wondering what it would be like for wheel horse tin work?? iv got access to a shot blaster but it really isnt a job i like and i guess it will bend the panels
is it a few days to wait or hours? any before and after pics of stuff thats been through the process??
id of made you an offer but being french and left hand drive
what is this project for???
exellent project, this doesnt look out of place
iv just bought a raider. not sure if im going to break or restore it yet........
wow great find.....they look great
a few pics...what other parts do i need to get it to work??
also third gear hardly engages grinds and jumps out..it a 3 speed box..what normally causes this problem?
cheers woz
ah yeh sorry, ill get some posted up asap......will be in the work shop later on this evening so ill take some pics of the old girl.....
hi, iv bought my first propper wheel horse .....has anyone got any pics of the pto pedal set up as the one iv got has had a piece of metal bar welded to the pulley....
in the first photo it looks almost like you had got him in that snare......
wow what an awsome but brave project.....iv never even heard of a sand skimmer....drop me a pm if you need any of the tin work fabricating...
its been irratating me that i failed to repair this tuff torque box,so i had another go at it today, iv replaced the damaged shaft with a wheel horse shaft and played with the splines in the dif.......i had it on our back field for over an hour thrashing it back and forth, iv honed my wheely skills.....the repair seems to have held this time.........
