pmackellow 2,728 #26 Posted September 16, 2014 If you want pipes for it Chris you could pinch them off that old Harley in your garage... Share this post Link to post Share on other sites
nigel 1,874 #27 Posted September 16, 2014 i always use old wheelbarrows, cut up they make lovley exhausts with plenty of bends to cut and shut 3 neil, the showman and diggerjames reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #28 Posted September 16, 2014 So that's why you can't find a wheelbarrow in Hawkhurst !! Share this post Link to post Share on other sites
the showman 4,074 #29 Posted September 16, 2014 Woe Chris that looks great gong they look better with the old style hood it's gonna give a new lease of life what horse power us that engine? Its a 20 HP kohler twin James 1 diggerjames reacted to this Share this post Link to post Share on other sites
nigel 1,874 #30 Posted September 17, 2014 So that's why you can't find a wheelbarrow in Hawkhurst !! the nursery are always losing theres Share this post Link to post Share on other sites
the showman 4,074 #31 Posted September 17, 2014 Downloaded a tranny manual yesterday and it appears that the under pan doesn't have a gasket only bolted together with sealant, so iam off to get some tomorrow and see if I can stop the leak. now its outside its dripping on the drive, got a nappy on it at the moment Share this post Link to post Share on other sites
the showman 4,074 #32 Posted October 23, 2014 Just an update on the Hypo Horse, I took a chance and dropped the sump pan thingy without taking the axle out today, drained the oil and undone the bolts, very gently lowered it down then my worst fears, a clatter and some bits fell out then I went in doors 1 diggerjames reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #33 Posted October 23, 2014 Naughty words being spoke at Telscombe then !! Share this post Link to post Share on other sites
diggerjames 543 #34 Posted October 23, 2014 Sounds like you have my luck Chris any pictures ? Share this post Link to post Share on other sites
pmackellow 2,728 #35 Posted October 23, 2014 I doubt Chris was in the mood to take photos James... Share this post Link to post Share on other sites
Ian 2,417 #36 Posted October 23, 2014 I'm sure your work out where the bit's go Chris Share this post Link to post Share on other sites
the showman 4,074 #37 Posted October 24, 2014 When I went out to the shed this morning I found out what the two clips do, they hold the grown-wheel and planet gears in, as I had a drain bucket full of parts next move was to remove the tranny (didn't have room to tip the tractor upside down) and after a lot of head scratching I got all the parts back in and refitted the sump. on moving the axle back under the tractor the nearside driveshaft slid out so stripped it down again and one of the locking clips wasn't rite in. now its back in the tractor, just have to fill it with oil and see if it works 3 nigel, diggerjames and pmackellow reacted to this Share this post Link to post Share on other sites
pmackellow 2,728 #38 Posted October 25, 2014 We await developments (and hopefully a smiley face) then Mr Showman !! Share this post Link to post Share on other sites
amcrules00 24 #39 Posted October 26, 2014 Already on to a good lookin' Horse there. Share this post Link to post Share on other sites
the showman 4,074 #40 Posted October 26, 2014 Had a bit of spare time this afternoon so I refilled the tranny up with oil after i found the bleed screw to let the oil in, fired her up and surprise surprise it works. took a while to get going and purge the air out, but seems ok, well it goes backwards and forwards. next job to put the wheels back on and test it outside. (makes my eyes water with it running it in the shed) 2 amcrules00 and diggerjames reacted to this Share this post Link to post Share on other sites
the showman 4,074 #41 Posted October 27, 2014 Got home tonight after a day on the road and rushed out to the shed and looked underneath, no oil leaks 1 Ian reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #42 Posted October 27, 2014 Well done! Share this post Link to post Share on other sites
diggerjames 543 #43 Posted October 28, 2014 Great news CHRIS any pictures mate ? Share this post Link to post Share on other sites
the showman 4,074 #44 Posted October 28, 2014 Didn't do any photos James, my camera wont work in the shed , waiting for a new one to turn up Share this post Link to post Share on other sites
Ian 2,417 #45 Posted October 29, 2014 That's good news Chris, leak free is the way it needs to be Share this post Link to post Share on other sites
the showman 4,074 #46 Posted October 30, 2014 Just noticed its leaking again will have to pull it out again. gonna try and make a gasket this time, at least I know how it works this time Share this post Link to post Share on other sites
diggerjames 543 #47 Posted October 30, 2014 Good luck Chris these things are sent to try us ! Share this post Link to post Share on other sites
the showman 4,074 #48 Posted October 31, 2014 Yeh it sure is James, I used some Volvo joint sealant that I had in my toolbox, wondered if its gone off and hasn't set What sealant do you guys use ?? Share this post Link to post Share on other sites
Stormin 4,458 #49 Posted October 31, 2014 I use Loctite gasket sealant or Hylomar universal blue. 1 diggerjames reacted to this Share this post Link to post Share on other sites
meadowfield 1,900 #50 Posted October 31, 2014 I generally make a new gasket and use grease, it's worked on bendy. My GT leaks like mad though Share this post Link to post Share on other sites
