Tom 215 #1 Posted April 13, 2015 Hi all, With the recent sale of the Brinly plough for over £600 and having no luck finding one and after seeing Marks amazing adaptation of a Barford atom plough I set about adapting a spare Barford atom plough I had. I only have a slot hitch at the moment so I adapted it to suit a slot hitch but no welding or modification was made to the plough I just used the original bolt holes which means it can be reverted back to a plough for a Barford atom or even changed for a sleeve hitch. I cut a part out of some 8" box section we had to make the L-shaped bracket and then used a piece off of an old forklift carriage for the bar which will go in the slot hitch and be welded to the underside of the L-shaped bracket. It's currently only G-clamped. I will cut the bracket down so there is no risk of it hitting the fender and so the adjustment lever has enough space to move. Tom 3 Triumph66, slf-uk and nigel reacted to this Share this post Link to post Share on other sites
the showman 4,074 #2 Posted April 13, 2015 Well done Tom, if it works as good as it looks you've cracked it Share this post Link to post Share on other sites
Chris 642 #3 Posted April 13, 2015 Looks good Tom £600 for a brinly I would expect the tractor to pull it with that price Share this post Link to post Share on other sites
slf-uk 914 #4 Posted April 13, 2015 Great one Tom, it looks the business Iain Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted April 13, 2015 Well done lad. A good, simple idea. Share this post Link to post Share on other sites
meadowfield 1,900 #6 Posted April 13, 2015 Nice work tom! Share this post Link to post Share on other sites
Tom 215 #7 Posted April 13, 2015 Thanks guys, I really appreciate all the positive comments. I can't wait to test it and hope the geometry of it works out OK. There is a fair bit of adjustment on the plough itself so I am hopeful. Keep watching as there is more to come soon Tom Share this post Link to post Share on other sites
Triumph66 1,256 #8 Posted April 13, 2015 Excellent improvisation Tom. Share this post Link to post Share on other sites
nigel 1,876 #9 Posted April 14, 2015 i knew you could do it tom Share this post Link to post Share on other sites
Tom 215 #10 Posted April 17, 2015 Thanks Andrew and Nigel No updates yet, hopefully I will get some more done this weekend... Tom Share this post Link to post Share on other sites
