Ian 2,417 #26 Posted June 8, 2016 Your soon have it up and water tight. Are you adding insulation and boarding it out inside? Share this post Link to post Share on other sites
Rocboni 257 #27 Posted June 8, 2016 Yes It has Internal tounge and groove plus fibreglass insulation Share this post Link to post Share on other sites
Rocboni 257 #28 Posted June 11, 2016 Bit more done, nearly water tight! 2 nigel and Stormin reacted to this Share this post Link to post Share on other sites
Rocboni 257 #29 Posted June 14, 2016 Roof on and water tight! Now to make a start on the inside. 5 expeatfarmer, Stormin, nigel and 2 others reacted to this Share this post Link to post Share on other sites
Ian 2,417 #30 Posted June 15, 2016 Don't forget to leave some space for a small wood burner, I'm guessing it can get quite cold on the border during winter.. Share this post Link to post Share on other sites
Rocboni 257 #31 Posted June 17, 2016 Usually avoid working in the winter but could change now! I've got most of the insulation in, doors hung and new side doorway cut, hasn't half made it feel small but think once its panelled inside it will feel bigger. 3 Alan, nigel and pmackellow reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #32 Posted June 18, 2016 The mice will be cosy when they get into all that insulation Share this post Link to post Share on other sites
Rocboni 257 #33 Posted June 18, 2016 5 minutes ago, expeatfarmer said: The mice will be cosy when they get into all that insulation Not sure how they will get in but I'm sure they will manage. Share this post Link to post Share on other sites
Rocboni 257 #34 Posted June 18, 2016 Roof and ends to clad, side door made this morning. 1 pmackellow reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #35 Posted June 19, 2016 Bit of steam and a few naked people and you could set up your own sauna. 1 Rocboni reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #36 Posted June 19, 2016 Steady now Jonathan. Don't give the lad ideas. 1 Rocboni reacted to this Share this post Link to post Share on other sites
Rocboni 257 #37 Posted June 19, 2016 As long as they were of the opposite gender then I might just do that! Managed the ceiling today even with a hangover so even more sauna like now. 2 Ian and pmackellow reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #38 Posted June 19, 2016 Nice job, Rhys. Share this post Link to post Share on other sites
Ian 2,417 #39 Posted June 22, 2016 Looking good Rhys 1 Rocboni reacted to this Share this post Link to post Share on other sites
Rocboni 257 #40 Posted June 22, 2016 Cladding finished, just need to finish up the wiring. 2 nigel and pmackellow reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #41 Posted June 23, 2016 looks big now, is it double doors on the other end. Are the neighbors pleased? 1 Stormin reacted to this Share this post Link to post Share on other sites
Rocboni 257 #42 Posted June 23, 2016 Yes bigger now the cladding is finished, two 4" thick doors at front (which weigh a lot!) Neighbours don't mind, although I've never asked, not worried. 2 Stormin and pmackellow reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #43 Posted June 24, 2016 Looks superb well done I can see you spending many happy hours in there ! 1 Rocboni reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #44 Posted June 24, 2016 Cracking job well done 1 Rocboni reacted to this Share this post Link to post Share on other sites
Rocboni 257 #45 Posted June 26, 2016 First tractor in the new shed for some general maintenance and touch up, never been out for 2 years, carb was blocked after that started a treat! (Pics on there side again, must be the iPad) 1 Stormin reacted to this Share this post Link to post Share on other sites
expeatfarmer 591 #46 Posted June 26, 2016 I like the track mats where did you find those? Share this post Link to post Share on other sites
Rocboni 257 #47 Posted June 26, 2016 It's rubber conveyor from the bottom of a road gritter, mainly got it for putting on my trailer with the crawlers on but had a length left so using it in the shed. If it had npbeen thinner and didn't have the chevrons then it would have went on the skimmer. See also the latest purchase (engine crane) was a bargain at £70 only 10 miles away it's a Clark strong arm long reach version, only issue you have to unbolt it to store it, it doesn't fold. Share this post Link to post Share on other sites
nigel 1,881 #48 Posted June 26, 2016 2 expeatfarmer and Rocboni reacted to this Share this post Link to post Share on other sites
