Ian 2,417 #101 Posted October 25, 2017 Still no luck getting the rear diff out, but I did take the input shaft out to try and see what's going on inside.. No diff inside but both cogs look in great shape. Getting drive from the Honda bike gearbox was always going to be fun as there isn't much space! The only thing I could do was move the transfer box as far back as possible. So out came the Quadzilla battery tray, followed by a slice taken out of a rear strut tower. The transfer box/rear diff coupler limits how far box the TB (transfer box) can be moved back. But notch cut out of the strut tower allowed me to move the TB back a good 1/2 inch.. Not much but it all helps. At this point I still didn't have a working Mig welder and couldn't really do any more on the project, so I tidied the bench and had a think. A change of plan getting the drive to the front er... I keep going to call them "diff's" but they dont have a diff in them! Anyway, you know what I mean. Rather than go the chain and sprockets way I meantioned in my last update, I will be using the Quadzilla drive shafts, all I need is one more UJ tyo get the shafts around the engine. Of course the front part of the exhaust won't fit because of a drive shaft in the way, but hey, it's only metal While on the subject of shafts, this is part of the drive shaft that fit's on the bike gearbox, the problem is the splines inside don't go all the way to the UJ, so I can't just cut it to length! The only way to do it is to slice a bit out the middle and weld the splined section back on much closer to the UJ. I need to shorten this so it will fit onto the gearbox splines and leave enough room for the UJ on the shaft that runs from the TB to the front axle. To make it easier to line the two bits back up for welding I needed to machine the slined end to an even size outside. As the UJ isn't designed to be taken apart (thanks for that Honda!) I had to be inventive and find a way to hold it all steady in the lathe. It's been a long time since I've used a steady rest, but it did the job well and the machining went smoothly. 4 Cub Cadet, ranger, Stormin and 1 other reacted to this Share this post Link to post Share on other sites
Ian 2,417 #102 Posted October 25, 2017 A big thank you to Rex at this point for turning up at the workshop one day sporting a couple of massive MAN truck steering columns. Thanks mate I can't use two of the UJ's as they have a plastic center bit. "I have since found out that the plastic bit is only a cover so I can use them" But I can use the shafts and other UJ's (one of which is a double) to get the power from the GB (gearbox) to the TB input shaft... But more on that when I get to sort it. With my Murex TradeMig finally fixed I decided to celebrate and make some mounts for the TB. Two of the mounts were cut off the remains of the Quadzilla frame which gave me a good start. Space is so tight getting the TB in and out of the frame I have to make all the mounts removable from the frame so they don't get in the way! I welded on a couple of captive nut before welding this bit to the frame. Once the TB has been taken out again I can fully weld it up. MMmmm, some nice strong welds This bracket bolts the TB to the frame, but I didn't like the look of it. So the corners were sliced off. And some new metal was added to put the strenth back in the bracket. Will you look at those pretty colours, yep I'd say my Mig is now working better than ever and producing the heat it needs to do a very strong weld That looks better.. The TB mount the other side. Nice and strong (well it will be when I can fully weld it up when the TB comes out), but I'm not sure I like the shape of it so a few mods will need to be done. That will do for now, it's given you all plenty to read More to come later.. 17 minutes ago, Stormin said: Sounds to me you could be right about things being welded up. Maybe a half shaft broke at sometime. I think you'll need to split the box. The trouble is I can't split the box with it in the frame, and I can't get it out! 3 Cub Cadet, Stormin and ranger reacted to this Share this post Link to post Share on other sites
Ian 2,417 #104 Posted October 29, 2017 On 25/10/2017 at 6:12 PM, ranger said: If you're going to use those steering shafts for drive shafts, how about balance? Those clamping thingy's look a bit offset. Well spotted The off-set bits of the UJ's will be ground down to make them..er... Not off-set As I will be grinding off the bits where the clamping bolts go I will need another way of making sure the UJ's don't come off the shafts.. On the Quadzilla roll pins were used, so that would be the way to go I think.. The TB didn't officially have a mount around the input shaft I thought it might be wise to make one as a lot of forces will be going into the TB there.. A cardboard template taking shape, pencils being just the right size to screww into an M8 thread As I didn't have a big enough bit of strong plate to make the bracket from I had to make it in two parts. Two of the bolt holes on the TB didn't stick out as much as the other two, so to level things up a couple of spacers were added to the inside of the plate. Welds cleaned up. The chain driller hole is slowly getting filed round. By doing it a bit at a time it breaks the bordom/arm ache up into managable bite sized chunks Bolted back on with a few extras. The top right hand bolt bolts into a threaded tube thats welded to the strut tower. As any "tabs with captive nuts" type things would get in the way of reoving the TB, I had to come up with another mounting spot. Something like this.. It was also a good time to mark out a bolt hole. Off with the bracket them slice the top off the foot rest mount.. Drill it, weld a captive nut inside then weld it all back onto the frame... Top mounting point sorted 2 Stormin and Alan reacted to this Share this post Link to post Share on other sites
Ian 2,417 #105 Posted October 29, 2017 To get the drive from the Honda bike gearbox to the TB I had to find a way of turning the drive direction around by 90'd.. One of the steering UJ's fitted with the the splined section from the original CX/trike propshaft.. The shaft will run diagonally between the engine and TB with a nice meaty bearing to hold it in place. And via this double UJ thingy the drive will come out the side of the frame through another meaty bearing and put the drive in the same orientation as the TB input shaft.. Working out space for the TB to front drive shaft. Using a mixture of different shafts and UJ's there is plenty of space to run the front drive up the side of the engine. Hhhmm... Maybe not quite the same size where they need to be joined! A bit of lathe work later.. Ta-Daa Not fully fitted together in this photo as I don't know the exact length yet, but you get the idea Popping back around to the other side of MadTrax for a mo, the pulley (I will be using chain and sprockets) is about the right size to give me an idea how much space I need to create to fit a bearing in. I need to slice some of the frame out here, but I planned to do that anyway to get rid of the un-needed swing arm mount.. It's the only bit left that says "I've welded a few extra tubes to a bike frame" The bearings arrived Wednesday but I've not had a chance to do anything with them.. That's fun for tomorrow 4 1 ranger, Alan, Cub Cadet and 2 others reacted to this Share this post Link to post Share on other sites
Ian 2,417 #106 Posted November 3, 2017 On 25/10/2017 at 6:12 PM, ranger said: If you're going to use those steering shafts for drive shafts, how about balance? Those clamping thingy's look a bit offset. HI Doug, I've had another thought on the clamp thingys.. Rather than take metal off of one side to balance the UJ's, it would be better and stronger to add metal to one side and build it up with weld (making sure not to let things get too hot) until both sides match.. While waiting for the bearings to turn up, I thought I'd make a start on a sleeve to fit over the input shaft on the TB.. Not the best photo (I will get a better one) but here's the shaft in question. The only bit of steel bar I have which is long enough is made from very hard steel and looks like it has been used to hold a JCB bucket on... That sort of hardness! Anyway, I can make it in two parts and weld them together which would make it easier turning the tapered part half way down the shaft inside.. These two lumps I made years ago as pivot points for a dozer blade that was going to go on the 6x6.. A lot of turning to get them down to size! At least one is mostly done Woo Hoo... The bearings arrived Here's the TB to front end bearing mocked in place.. Best start getting the bearings mounted then.. First up something to bolt them to.. Well, a couple of somethings.. Bolted on. The black bit of steel across the lower bearing bolts is just to keep the bearing square to each other. You can just see where I welded on some tempoary bracing to the drive shaft to stop anything moving about withough the axle stand and other bits that were holding the bearings etc in place. If you flip the bearings over you can see the captive nuts that have been welded on... Don't think they are going anywhere Now the fun bit.. Making four somethings to bridge the gap between the back of the bearings and the chassis/frame.. Starting with a bit of CAD (cardboard aided design) work.. Which goes somewhere here.. Rather hard to hold it in place and take a farto at the same time! Roughly cut out of steel.. That looks better. Four of em made and tacked in place.. Bearings off.. Fully welded up... Almost.. It will be easier to weld the extreme top on bottoms where the brackets fit on the frame without the engine in and sump guard in place, so that can wait until stripdown time. Welds ground down, a nice curve at the back to clear the engine. And most importantly, there is still plenty of UJ clearance here.. And here And to finish off this update, a photo of the bearings etc quickly bolted on for this very photo.. The mounts were still very hot from welding and grinding so I didn't want the bearings sitting getting hot for too long.. 2 1 1 ranger, Alan, nigel and 1 other reacted to this Share this post Link to post Share on other sites
Ian 2,417 #107 Posted November 8, 2017 Not much to report, Monday was spent arguing with a car radio, and yesterday my knees were so bad I was only in the workshop for a little while.. But I did manage to get the front driveshaft welded up.. I don't think the welds are going to break Almost forgot, the latest MadTrax video... Enjoy 2 Cub Cadet and Stormin reacted to this Share this post Link to post Share on other sites
Ian 2,417 #109 Posted November 22, 2017 On 08/11/2017 at 10:50 AM, ranger said: Great workmanship and thought going into this project Ian, grand job. I hate to say this but, in the photo of your driveshaft, it looks like the shaft yokes are out of phase. All shafts I've had dealings with, (apart from steering shafts installed at high angles, which don't spin at high speed), always have the shaft inner yokes in line to aid in cancelling out vibrations, not a problem if the whole assembly runs in a dead straight line, but when angles are involved? Not a criticism , just an observation . You don't want that coming adrift at any speed close to your leg The ideal perhaps, would be a pair of CV joints, if there's room. Well spotted Doug, I had an idea that the yokes both should be in a certain position but wasn't sure which.. Guess I should of googled it first! At least I had a 50/50 chance of getting it right The shaft also had a slight length problem as something had moved during welding, so in the vice the shaft went to have a weld cut down. Welded back up at the right length with the UJ's in phase The shaft out the TB is way too hard to drill, so the UJ is held on with a couple of grub screws.. I will add a couple more for peace of mind.. The UJ's that fit on the shaft with bearings are a very tight fit on the shaft, so I drilled them out to fit some nice tight roll pins.. The bolts are only there at the mo to make it easier to take things apart (many times) during building and will be replaced with roll pins. One of the UJ's being a MAN steering coloum UJ is normally held onto a shaft with a nut and bolt one side.. Fine if it's being used for steering but as it will be turning a lot faster it would of been out of balance! My solution was to cut most of the clamping bit off but leave enough to get a bolt through and clamp it tightly. (The drill bit is only there to line the holes up for putting a roll pin through) Part welded up.. A little at a time as I didn't want to fry the UJ. The bolt head and tread were cut off before more welding, then some shaping.. Still a little more to take off.. Oh, and I found a rather nice if rusty steel bar buried in the workshop, I guess I will be re-making the TB input shaft sleeve, but this time out of one piece.. It's a good job I have just got some more cutting tips and cooling fluid for the lathe 2 Stormin and Cub Cadet reacted to this Share this post Link to post Share on other sites
Ian 2,417 #110 Posted November 22, 2017 With all the front drive train bolted back on the foot rest thingy needed a little trim to clear a UJ.. I will add a cover over the shafts/UJ's to add some leg protection should something go bang and start flapping about the place. Before I started to cut any more metal out I put some strength back in with a nice bit of curved tube that clears the UJ When the frame is stripped back down I will add some extra metal to tie the tubes together neatly. This join between old and new tubes just had to go! Hhmmm, nice rust inside one of the few remaining bits of the original FourTrax frame... It felt good to remove it There is no neat way of joining big and little tube together, at least the other end is easy For extra strength a length of steel bar has been added inside, you can just about see it where the tubes join.. The steel bar does go all the way up and in the larger tube. I like getting good value for money, think I might of got the maximum use out of this cutting disc Compair it to a new disc!! While on the subject, some cheap cutting discs are better than others, I can't remember the make (Germany is mentioned on the Fleabay ad) but they are by far the fastest wearing most easily broken disc's I have ever bought! That looks better.. Way better than the bit I removed 4 Alan, meadowfield, Stormin and 1 other reacted to this Share this post Link to post Share on other sites
Ian 2,417 #111 Posted November 22, 2017 Now the fun part, getting drive from the Honda bike gearbox which points towards the back, out the left side of the frame. A thank you to Nigel at this point for getting a shaft, pulley and UJ off the remains of a Kubota flail mower before it went off for scrap... It really was that rotten! The UJ in question, heavy duty and with no play in the bearings at all One side of the UJ is easy to attach as I have the shaft and roll pin that came out of it.. The other end has or (should I say had) some rather large splines! I'd be lost without a lathe, taking the OD down to size before cutting it off. Boring the ID out, a couple of arty flying cooling fluid shots The finished sleeve, yes it was turned down from a lump of steel the same shape and size it's standing on! UJ, shaft and sleeve.. A nice tight fit.. The sleeve has now been welded into the end of the UJ, yet another roll pin will hold it all together. Starting at the back, or is it the front!... Er.. Back of engine we have a UJ with splines in one end to slide over the output shaft on the bike gearbox. A shaft then goes through another bearing and into the Kubota UJ.. And comes out through the left side of the frame and another bearing. A chain and a couple of sprockets will give me drive into the transfer box As you can see I have some metalwork to do to hold everything in the right place.. Space is tight but shafts and UJ's turn as the should without hitting anything or feeling "notchy" which proves the concept of it will all work 4 Stormin, Cub Cadet, nigel and 1 other reacted to this Share this post Link to post Share on other sites
Ian 2,417 #113 Posted November 29, 2017 On 22/11/2017 at 9:52 AM, Stormin said: Somehow I don't think I'd be wanting to do a strip down. You or MadTrax Norm? And onwards with the story, another slight change of plan coming up shortly.. The outter bearing needs something strong to bolt on to, so I dug out a bit of 8mm plate and set to on the lathe. It will fit somewhere here, to make life more interesting the plate needs to be removable or I won't be able to get the transfer box back out the frame! Before I started on the mountings I thought it would be wise to tidy up this bit of frame first. Mostly chopped out.. That looks better. Plate and bearing set back in the frame a tad, it fit's rather well.. Plenty of UJ clearance by the transfer box. Before I can start mounting the plate I need to make sure both shafts are parallel to each other.. 2 Stormin and Cub Cadet reacted to this Share this post Link to post Share on other sites
Ian 2,417 #115 Posted November 29, 2017 There was no way the exhaust system I had built would fit back on with a transfer box and a dive shaft in the way, the only part that fits is the big bore pipe that runs down the side of the engine through the frame! So a bit of a re-make is needed, I started at the front after slicing off the bits that fit into the engine.. The only tube I have enoug of is a bit bigger than I had been using, so how to go from something small to the bigger blue bit size! Find a bit of tube that's slightly bigger than the small bit but slightly smaller than the big blue bit and make four long-ish cuts in it. A hose clip squeezes it down to size. Welded on and extra tube trimmed off. Welds cleaned back. A bit of hammer work soon had the other end a bit wider. Welded on to the big bore pipe. Lot's of careful welding later had the gaps filled up. Test fitted to the engine, one side cleaned up. Now I have these made I can work out how the next part of the system.... But that's something for Friday.. Oh... the slight change of plan... With the UJ's etc removed I found there is just enough space to fit this er... final drive? 90'd drive thingy from the very same Honda Silverwing that gave it's engine up for Why Not all those years ago! I will need to fit a chain n sprocket to get the power from the bike gearbox into the 90'd drive thingy which has a 5 to 1 ratio (I can "gear" that ratio out), and yes it will spin the right way And to finish off a couple of photos of the unit I had taken to put it on Fleabay.. Quite glad I didn't get around to listing it 4 Stormin, Cub Cadet, Alan and 1 other reacted to this Share this post Link to post Share on other sites
Ian 2,417 #118 Posted December 13, 2017 A bit of lunch and lot's of welding later the result is some what curvy Some bit's could not be welded in situ so to make sure nothing could move during welding I added a couple of braces before taking the exhaust off. Fully welded up, just a lot of welds to grind down.. Funky shape eh? With the exhaust bolted back on.. I could start on the next part of the puzzle, the rear exhaust section.. It's going to be interesting trying to join these cans.. To the bit of big bore pipe you can see below the tank in the triangular bit of frame.. As someone has put a transfer box right in the way and there isn't really enough space between the TB linkage arms and the frame.. Yep, it's going to be interesting for sure 3 1 Cub Cadet, nigel, Stormin and 1 other reacted to this Share this post Link to post Share on other sites
Alan 1,274 #120 Posted December 13, 2017 Don't think even Frankenstein would look quite like that. 1 Ian reacted to this Share this post Link to post Share on other sites
Ian 2,417 #121 Posted December 20, 2017 On 13/12/2017 at 6:28 PM, Stormin said: Exhaust gas flow is just as important as porting a head. It is indeed Norm, the cleaner and faster the gasses can get away from the engine the better On 13/12/2017 at 9:53 PM, Alan said: Don't think even Frankenstein would look quite like that. It will look a lot better once the welds are ground down and it's all been wrapped in heat proof tape sort of stuff The solution to joing the two bit's of pipe together was this ear trumpet shaped bit of pipe. It's a tight fit around the transfer box, a very thick ally heat shield will be going between the exhaust and the black electrical gizmo with the word up, upside down.. Don't want to melt it! Apart from grinding down lot's of welds that's the exhaust system done Next on the hit list to sort is the shifter for the transfer box.. It needs to go somewhere around here, also the bracket looks really ugly so a new one is being made.. The fun bit is going to be making the rods that connect it to the transfer box, but luck might be on my side as I found an easy route through the frame, above the carbs that will require minimal bends to the rods.. Oh, a scrap pile raid produced all the rods I could need To finish off this update have a moody smokey picture of the MadTrax 3 1 Cub Cadet, Alan, nigel and 1 other reacted to this Share this post Link to post Share on other sites
Ian 2,417 #122 Posted January 5, 2018 Morning all, time for a long over due update, though not a great deal has been happening.. I needed a better looking bracket to mount the transfer box shifter stick as the Quadzilla one was too big and very ugly. I'm sure you can guess which one is the new one Shifter bolted in. Still not quite sure where to mount it on the frame at this point, so I welded a couple of bolts to soe blue steel bar. Very long bits of bar With the "bolt ends" of the rods stuffed through the frame and bolted on the TB levers, I could see there was a fairly straight run to connect the rods to a "next to tank" mounted shifter... But then I found out all the shifter marlarky fitted nice just above the exhaust, tucked into the frame a bit.. Just enough space to get the connecting rods on With one shifter box mount thingy done, the rods were shortened a bit, had a few bends put in and a bolt welded on the other ends.. It's a bit crude, I may re do the rods with rose joints, but for now the shifter works very well, and you get a reasuring "thunk" sound as the TB goes into gear 3 Alan, Cub Cadet and Stormin reacted to this Share this post Link to post Share on other sites
Ian 2,417 #123 Posted January 5, 2018 As you can see the shifter stick er... Sticks a fair way out from the gas tank.. A bit too far out for my liking.. Before I could narrow it I needed to find out why the stick just fell to one side under the weight of it's self. Once cracked open I found two springs were missing that that should hold the gear stick in the middle.. Not being able to find any compreession spring in the workshop that were the right length, width and strength I found a couple of bit of clear fuel pipe work just as well Just over an inch removed from the shifter.. Both halves were V'ed before welding back together to give maximun strength.. It looked quite nice once the welds were ground down nice and smooth Bolted back on to the frame, but I don't like the look of the shifter knob, it's more "Montego/Maestro" than MadMax, but thanks to Nigel I have something a bit er... Different to graft on... Yes it is what you think it is... A titainium hip joint 2 1 Cub Cadet, Stormin and Alan reacted to this Share this post Link to post Share on other sites
nigel 1,881 #125 Posted January 5, 2018 1 hour ago, C-101plowerpower said: so nigel is now hopping around the shop? Ha! Ha! I hope you know koen there is a real sad story behind that hip joint,😏 1 Ian reacted to this Share this post Link to post Share on other sites
