the showman 4,074 #1 Posted October 4, 2018 While I was at Kingsfold last weekend I picked up this engine and just had chance to unload it. Its all complete apart from the air filter, has the wiring loom , solenoid, exhaust, starter and coil, it turns over with compression. dont know what it's out off but has an electric pto and the crankshaft sticks out of the wire screen. Comments welcome, here's some photos. 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Wristpin 399 #2 Posted October 4, 2018 That's a configuration often used in heavier duty garden tractors such as JD, Ariens or Cub Cadet with a U/J off the back of the engine to shaft drive to the transmission and the drive to the deck via the electric clutch and one or two belts dropping down to a mule shaft under the chassis and a U/J and short shaft to the deck.. However the position of the fuel tank looks a bit wrong for that application. 1 the showman reacted to this Share this post Link to post Share on other sites
Anglo Traction 997 #3 Posted October 4, 2018 Listed as being delivered and fitted to a Jacobsen machine. It's a 10hp K241. If the serial number is readable, it will give the year of manufacture. Share this post Link to post Share on other sites
the showman 4,074 #4 Posted October 4, 2018 Your right Richard I didn't notice that, bloke said it was a 12 Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted October 4, 2018 I don't want it then. Share this post Link to post Share on other sites
the showman 4,074 #6 Posted October 5, 2018 Just had another look at the engine, I spose the spelling sums it up. . 1 Cub Cadet reacted to this Share this post Link to post Share on other sites
the showman 4,074 #7 Posted October 8, 2018 On 4 October 2018 at 10:30 PM, Anglo Traction said: Listed as being delivered and fitted to a Jacobsen machine. It's a 10hp K241. If the serial number is readable, it will give the year of manufacture. Managed to get the serial number which is 7051812 Share this post Link to post Share on other sites
the showman 4,074 #8 Posted October 12, 2018 Looks like it's a 1975 with electric start and special oil pan Share this post Link to post Share on other sites
the showman 4,074 #9 Posted November 13, 2018 Moved this into the shed , tidied up the wiring and changed the earth lead now it spins over and has a spark at the plug. I’ll put some fuel in it tomorrow and it should start. Share this post Link to post Share on other sites
