the showman 4,074 #1 Posted August 20, 2019 Picked this up at the weekend, anyone know what make it is ? . 1 Stormin reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted August 20, 2019 No idea, Chris. Most likely a walk behind. The depth/land wheel looks on the wrong side for behind a tractor? Share this post Link to post Share on other sites
the showman 4,074 #3 Posted August 21, 2019 Its a Brinly plough which is good news, I’m pleased with that, 3 Stormin, Cub Cadet and Alan reacted to this Share this post Link to post Share on other sites
4x4forks 258 #4 Posted August 25, 2019 I would agree looks like a Brinly but not as it came out the factory . Mean modified over the years i would say. 1 the showman reacted to this Share this post Link to post Share on other sites
ranger 373 #5 Posted August 28, 2019 What You have is one third of the Wheelhorse implement package, Plough, Discs and Cultivator assemblies which all use the same mounting beam. I have the other two thirds, I'm missing the plough. Have a look in the Wheelhorse magazine 1981 on Red Square, it shows the setup. The clevis part on the front can be fitted in either of two positions, one way up it's square to the beam for the discs or cultivator, or turned over it is at the correct angle for ploughing use. The furrow wheel looks to be an addition, it's not shown in the original pictures. 3 the showman, Stormin and Cub Cadet reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #6 Posted August 28, 2019 You now know where there is a plough now Doug. And good to hear from you. Share this post Link to post Share on other sites
the showman 4,074 #7 Posted August 29, 2019 That’s great Doug and nice to hear from you, it’s good to see a photo of one as I haven’t been able to find anything on google about it. given me all sorts of ideas now. That explains why some of it is red. I can’t find it on Redsquare can you tell me where to look please Doug Share this post Link to post Share on other sites
Cub Cadet 613 #8 Posted August 29, 2019 10 hours ago, ranger said: What You have is one third of the Wheelhorse implement package, Plough, Discs and Cultivator assemblies which all use the same mounting beam. I have the other two thirds, I'm missing the plough. Have a look in the Wheelhorse magazine 1981 on Red Square, it shows the setup. The clevis part on the front can be fitted in either of two positions, one way up it's square to the beam for the discs or cultivator, or turned over it is at the correct angle for ploughing use. The furrow wheel looks to be an addition, it's not shown in the original pictures. I have the mouldboard and adjuster but no bracket or coulter for one of these, perhaps your missing plough Share this post Link to post Share on other sites
the showman 4,074 #9 Posted August 30, 2019 Thanks to rangers guidance I found these. 3 Alan, Stormin and pmackellow reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #10 Posted August 30, 2019 I think you have discs? All you need now is a genuine cultivator. You could modify a clevis hitch if you have a spare? Share this post Link to post Share on other sites
the showman 4,074 #11 Posted August 30, 2019 Mid-day update, I’ve replaced all the bolts with the right size, made a temporary hitch so i can mount it on my Raider 12 and cleaned some of the rust off with a grinder. I see how it works over the weekend, i can always use my old faithful. 3 pmackellow, Stormin and 4x4forks reacted to this Share this post Link to post Share on other sites
the showman 4,074 #12 Posted September 6, 2019 In haste i made a quick hitch on Friday just to try it in the ground, it dug in well but had a lot of sideways movement so I decided to make a new one but only had the photos of above to go on. Just using some scrap bits of angle iron and a lump of plate, drill and welder this is what i came up with. 3 Alan, Stormin and 4x4forks reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #13 Posted September 6, 2019 I like that. The way you can move it in or out. I need to make a clevis hitch and do something similar. Share this post Link to post Share on other sites
the showman 4,074 #14 Posted September 6, 2019 At least it’s adjustable in every direction now, just need to try it Share this post Link to post Share on other sites
the showman 4,074 #15 Posted September 8, 2019 Just out of interest I thought I would weigh the ploughs, the Auto-cults is 26 kg, the Brinly is 32 kg and the depth wheel is 6 kg. Share this post Link to post Share on other sites
Stormin 4,458 #16 Posted September 8, 2019 I was going to weigh mine, but they're right back behind the tractors. Plus I got side tracked with a trailer load of wood and a green to mow. Share this post Link to post Share on other sites
the showman 4,074 #17 Posted September 8, 2019 As it’s a Wheelhorse tool bar i thought I’d make a cultivator from some junk I’ve got in the shed 2 Alan and Stormin reacted to this Share this post Link to post Share on other sites
