Fishnuts2 22 #1 Posted March 21, 2020 As long as we are to pretty much stay at home, I thought it would be a good time for a build thread on my Orline 13B. I've been tinkering with it since January, and finally got it running well, with a special Thanks for all the tips and advice from this forum. Here is how it looked when I brought it home, and after getting it cleaned up. 4 factory, pmackellow, JUST O&R and 1 other reacted to this Share this post Link to post Share on other sites
Fishnuts2 22 #4 Posted March 21, 2020 (edited) So had to split this tank, and had quite a time getting the piston out of the oiler bore. Someone must have used varnish instead of bar oil in this thing. Put a new filter and internal line on this one too, after the picture. You can see where the grease escaped the cavity here too. I used Yamabond and cleaned the surfaces with acetone before assembly. It seems to hold this time thankfully. Next step was to track down the no spark issue, which led to a pinched wire under the flywheel housing. Repaired it with liquid electrical tape and cleaned and reset the points. Actually, a couple of times, since I put the points plunger in backwards! When checking the flywheel side seal I noticed the original didn't seal to either the crankshaft, or the outside of the retainer. A bearing and hydraulic repair shop had an O-ring that seems to do the job. Edited March 21, 2020 by Fishnuts2 2 CNew and factory reacted to this Share this post Link to post Share on other sites
Fishnuts2 22 #5 Posted March 21, 2020 Easily, the worst part of this whole saw is the process you have to go through to access even simple things that are in view! And some fasteners are really hard to get at. This shows a straight blade screwdriver in a Phillips head screw just to get it started most of the way. UGH! So, after figuring all this out and obtaining a nice spark, I had to decrease the points gap to about .018", because it seemed like it wanted to start, but just couldn't take off and run. Basically advancing the timing got it to run quite well. Next, was finishing the paint for the rest of the parts, and sharpen the 3/8's chain. Off to the wood pile for some cuts and pictures. 4 CNew, factory, Wallfish and 1 other reacted to this Share this post Link to post Share on other sites
CNew 409 #10 Posted March 21, 2020 That turned out fantastic, very nice refresh! I have one of those saws and it also needs a complete overhaul amen cleaning. It’s always inspiring to see these projects. Share this post Link to post Share on other sites
Wallfish 724 #12 Posted March 21, 2020 NICE JOB on the saw! Fishnuts2 discovered the process for 90% of O&R tools. They all have fastners which are difficult to get to and how parts need to be removed to get to others. Make tools to work to get to them. Trust me, that chainsaw is easier compared to some others but also more difficult than some. But once you go through a couple it gets easier. Just wait until you get to that recoil on the Sears for the first one. Please don't smash it with a BFH. LoL Making your own gaskets and seals is a big part of this hobby. @Webhead Joe told me when I first started, "you have to be resourceful if you get into this hobby and collect them". Absolutely true Share this post Link to post Share on other sites
factory 487 #15 Posted March 22, 2020 On 3/21/2020 at 2:48 PM, Fishnuts2 said: As long as we are to pretty much stay at home I must be the only one on here still working, can't see that changing anytime soon as I work repairing train parts. That's a very nicely restored Orline chainsaw. You've found out the problem with the tank seals, the manual mentions that used tank seals shrink once exposed to air, if anyone finds some new-old-stock it would be a good idea to use them to have some more made (there are a couple of different ones depending on the age of the chainsaw). David Share this post Link to post Share on other sites
CNew 409 #16 Posted March 22, 2020 3 minutes ago, factory said: I must be the only one on here still working, can't see that changing anytime soon as I work repairing train parts. I’m still working too. So far it’s been business as usual where I am even though it seems like stuff is shutting down all around the area. I’m still going to the office every day... Share this post Link to post Share on other sites
factory 487 #18 Posted March 22, 2020 It's certainly getting quieter on the roads at rush hour, very little open in the UK too apart from essential shops & services. David Share this post Link to post Share on other sites
Wallfish 724 #19 Posted March 22, 2020 Still work for me too. As long as they haven't shut me down it's has to be a go. Hopefully we can finish this week at minimum but get the feeling it's getting close as many other states are locking down. I just peck away at it on weekends and nights but running out of the small stuff to do like chainsaws. Got started on the paint for a winch. Soon the bigger stuff like hedge trimmers and outboards will be the only thing left to do. Really been enjoying to get back at them again after a long hiatus of not touching them. It's here on the forum that motivates me by seeing what others are doing. Not so much just to keep up with the Jones" but more to share the experiences of restoring and repairing them. It's more fun to get involved. Plus bust'n on Terry is fun too! Did ya see that funny crap he did with the wires for a glow plug? I was LMAO. Share this post Link to post Share on other sites
factory 487 #21 Posted March 22, 2020 7 minutes ago, Wallfish said: Plus bust'n on Terry is fun too! Did ya see that funny crap he did with the wires for a glow plug? I was LMAO. Can't help thinking he could have saved it for Apr 1st. David 1 CNew reacted to this Share this post Link to post Share on other sites
CNew 409 #23 Posted March 22, 2020 1 hour ago, Wallfish said: Really been enjoying to get back at them again after a long hiatus of not touching them. It's here on the forum that motivates me by seeing what others are doing. Not so much just to keep up with the Jones" but more to share the experiences of restoring and repairing them. It's more fun to get involved. Amen to that! This forum is a blast and I look forward to checking it out daily, hourly sometimes, to see what everyone is working on and who has found a cool engine or tool. The friends and experiences are what it’s all about! It’s been fun having you back in action too! Fun to also see a few others like Fishnuts joining the fun... 1 Wallfish reacted to this Share this post Link to post Share on other sites
factory 487 #24 Posted March 25, 2020 On 3/22/2020 at 10:11 PM, JUST O&R said: IM not sure we will make it tell april went to the store today like a ghost town here Complete opposite here in the UK, massive queues to get food in some places & too many people close together. I'm now off work till Easter, someone finally had sense & closed work as distancing just wasn't working in most areas, plus passenger train parts must no longer be key work. On 3/22/2020 at 11:32 PM, CNew said: This forum is a blast and I look forward to checking it out daily, hourly sometimes That was impossible for me, work don't like people looking on their phones, plus many cameras are now watching & being used against us. David Share this post Link to post Share on other sites
CNew 409 #25 Posted March 26, 2020 4 hours ago, factory said: That was impossible for me, work don't like people looking on their phones, plus many cameras are now watching & being used against us. Yep, same here but in the evenings and on the weekends it’s hard to stay away from checking in on you guys! Share this post Link to post Share on other sites
