Jarrovian 237 #1 Posted June 19, 2021 Howard Dragon awakening from a long sleep after having a fuel pump transplant engine back on and bolted down one side panel re-fitted work stopped due to losing fuel pipe which can only be fitted with side panel removed 3 expeatfarmer, Rayp and Stormin reacted to this Share this post Link to post Share on other sites
The Blues Brothers 19 #2 Posted June 19, 2021 the fire breathing dragon is a live keep ken away is he fire retardant nice machine Share this post Link to post Share on other sites
Jarrovian 237 #3 Posted June 25, 2021 Has anyone got any idea or tips on how to remove clutch cable from this machine ? Share this post Link to post Share on other sites
The Blues Brothers 19 #4 Posted June 27, 2021 I have the Howard dragon operating instruction and part list Share this post Link to post Share on other sites
Jarrovian 237 #5 Posted June 27, 2021 I also downloaded it but not much help however I have started to remove tensioner pulley brake band but screws on trunking will not move will have to get under machine to remove tensioner bracket and spring Share this post Link to post Share on other sites
howardman 30 #7 Posted July 4, 2021 Took photo with my phone and ran into trouble with file size...anyway i have 2 Howard dragons ..one of which stripped for a gearbox repair hence the photo with engine removed. Its a while since i took it apart but from memory the side panel is removed , the clutch is bolted on with two bolts onto the side of the gearbox, and onto the front mechanism. Those clutch cables are of course hens teeth. Your one looks a lovely machine , my good one was used for landscaping and while still working is battle scarred. The one in the photo i posted a few years back on the VHGMC forum...i bought it minus the rotor box.. a non runner with a gearbox issue. Amazingly i met an ex Howard employee at a vintage show in 2019 and he had a dragon gearbox and a gear change cable ...he worked for Howards Ireland operation (Closed in 1982)..the gearbox he had was replaced under warranty ,so was damaged .... but had the bits i needed. Share this post Link to post Share on other sites
