paul 64 #1 Posted May 9, 2014 Hi All, having a bit of a problem, I have a little lawn edger with a 3hp Briggs and Stratton engine on which wouldn't go so went to try the common things as the points and found there wasn't any neither a condenser, the coil is there with a lug on it which goes to the throttle so presume its a stop switch. When looking further I found out that the engine had no hole for the peg that holds the points arm spring on also no hole or plunger to operate the points. So cant figure out how it worked ? was it electronic? Hope someone can help. The engine numbers are 80232-2222-01-88060803 Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted May 9, 2014 Look in ride on's at my post B&S 11hp. I've fitted that with electronic ignition. May help you. Share this post Link to post Share on other sites
pmackellow 2,738 #3 Posted May 9, 2014 That number sequence indicates a June 1988 build date Share this post Link to post Share on other sites
paul 64 #4 Posted May 10, 2014 Thankyou. I will see about elec ignition as that's what I think has happened as there is no evidence of points and condenser. Paul Share this post Link to post Share on other sites
pmackellow 2,738 #5 Posted May 10, 2014 Whats the make of the edger Paul, looks like quite a machine ?? Share this post Link to post Share on other sites
Anglo Traction 1,023 #6 Posted May 10, 2014 You may prefer to go down the route that Stormin suggests, but depends what your plans are for it, if you want to keep it to original spec, then you will need this info- There is another part number for the Unit that has a 14 3/8" long HT Lead, but suspect yours will be the shorter one. They are still common-ish available online i.e. Bay of E, but one will set you back about £30. Before you write the Coil off, have you checked- 1-The strength of the Magnet on the Flywheel. 2-The Air Gap between the Flywheel and Armature pick up Legs (should be 0.006"-0.010" or 0.15-0.25 mm). 3- Spark Plug and ground connections?. Look's a useful machine. Share this post Link to post Share on other sites
paul 64 #7 Posted May 10, 2014 Hi All. Good news. I spoke to john at the mower centre hailsham and described the problem to him. He told me to look at the underneath of the coil to see if it had a brass plate and does it have a lug at the top (IT HAS BOTH) the lug is the stop switch and the brass plate is the electronic ignition. Cleaned all the rust off the flywheel and reset the armature then wound it over with a drill and it has a lovely spark. Will see if it runs tomorrow. Thanks for everybodys help, I will put some pics up tomorrow for you Mr Mackellow but pretty sure the badge says little wonder patent Southampton and somewhere in America will look tomorrow. THANKS AGAIN ALL Paul Share this post Link to post Share on other sites
paul 64 #8 Posted May 10, 2014 Heres some pics of the maker. Paul Share this post Link to post Share on other sites
pmackellow 2,738 #9 Posted May 10, 2014 Thanks Paul, great photos, nice machine Share this post Link to post Share on other sites
paul 64 #10 Posted May 11, 2014 Had a go at the engine today and it is running, took a while mind you so touch wood all ok now. Time to strip the rest down and try and find out some history on it. It has a fox of bishops Waltham dealer sticker on it and they are 5-6 miles away from me so I will see if they can shed some light on it. Paul Share this post Link to post Share on other sites
Ian 2,417 #11 Posted May 12, 2014 That's quite a mad looking machine, one to keep the toes away from Good to see you have got it running Paul Share this post Link to post Share on other sites
Anglo Traction 1,023 #12 Posted May 12, 2014 You will find a copy of the Manual that covers your Model (and others) in the Downloads Section now. There was little change in the designs from 1965-1990, so If there are any parts that can't be fabricated cheaply, you may still be able to obtain them from the States. The Manual also includes Bolt and Thread sizes. Share this post Link to post Share on other sites
paul 64 #13 Posted May 12, 2014 Thank you for the download manual Anglo Traction, your a star. The more I go on this club/ site the more I like it. A credit to all people involved. Paul Share this post Link to post Share on other sites
paul 64 #14 Posted May 21, 2014 Hi All. Lawn Edger all finished now and cuts a treat, nice borders now. Paul 3 pmackellow, nigel and sten reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #15 Posted May 21, 2014 Cracking job Paul, that looks very smart, well done Share this post Link to post Share on other sites
Stormin 4,458 #16 Posted May 21, 2014 You've made a grand job of that. Share this post Link to post Share on other sites
Ian 2,417 #17 Posted May 25, 2014 A fantastic job Paul Any chance of a video of it in action? Share this post Link to post Share on other sites
