tvenetis
    175
Everything posted by tvenetis
  1. I sold everything except a tiny tiger generator which runs and I am trying to sell it on ebay.
  2. I have the spring wound up in the round piece that comes with new springs and I set it in the recoil housing but how do you remove the holder from the spring thanks.
  3. On putting the wire on the spool I can get the wire from the outside hole of the spool and feed it to the middle of the spool but how do you feed the wire down the center of the spool to come out of the other hole in the spool to make a loop for the rope.
  4. Thanks II have to find the one that goes to the bottom.
  5. does it matter where to connect the line that goes to the carburetor?
  6. I separated the entire generator thanks. On the fuel tank why does it have a fuel line from one side of the tank to the other side as well as a fitting for the carburetor?
  7. I will try to remove both but how do you get the cap off that covers the bolt for the rotar?
  8. I bought another tiny tiger with a statur on it. After I remove the 2 screws and nuts what is the best way to remove it without disturbing the wires thanks.
  9. We used a soldering gun to solder the wire. I do not understand why the black wire comming from the outlet branches off and connected to the diod with a wire nut that was crimped from the factory.
  10. I never checked if the dc was working. When I put the 2 probles of the meter in the plug socket and put it on continuity it beeped indication of a short.
  11. I have a talking meter so put the meter leads on the wires that go to the plug outlet?
  12. A friend helped me and we soldered the wire and I put the generator together. It is not producing 120 volts. I even tried speeding ut up and no change.
  13. I replaced the plug outlet on a tiny tiger generator and the white wire that goes to the plug broke off flush with the windings. I was wondering if some one has the stator that i can buy because it looks like the wire comes from the windings from the middle of the winding and there is no slack. Thanks
  14. I want to sell a ohlsson hedge trimmer on ebay but i am wondering how do people ship large items like that? Do they take the blade off it? thanks.
  15. I found out that the plug broke so i ordered one from amazon. Does any one have a schematic for the generator? One of the wires that went to the outlet came off and I can't find where it goes. It is the black wire that comes from the outlet. We looked on the Stator but did not see where it should go.
  16. I took the plug outlet apart on a tiny tiger generator and spread the 2 contacks because they were not making good contack when i plugged some thing in to it. I put the plug back in with the wires inserted and I put the center u piece with a screw which held the plug in. I noticed that after the screw was snug there was nothing holding the 2 plug pieces that had the wire solder to them in. You can just pull the wires out of the socket. What I am trying to ask is that after the plug recepticle is screwed in to the rear housing of the generater, when you plug something in to it what prevents the 2 wires from comming out of from the plug socket.
  17. I was wondering what they called the ride on car for kids. I saw some info about it on the forum but now can't find it.
  18. Is there a way to start the generator so it runs at a lower speed and then when it calls for power it will speed up itself?
  19. I am sorry you can deleete the thread. I am using a screen reader and could not find where to pm a person.
  20. I like the tiny tiger because it is small but does not produce much power.
  21. What kind is your other generators.
