meadowfield 1,900 #1 Posted August 13, 2015 In the back of the shed there was a lawnflite hydro with grass collector. The previous owner said I could have it, so I agreed...knowing it was probably a flat battery Hmmm, hooked up a jumped start and nothing, just a solenoid click.... Hmm, tried to turned over by hand... Just moved. Unscrewed the oil filler cap to check the oil. Plenty of oil - infact too much, and it stinks of fuel. Drained a gallon of petrol and oil from the oil pan! Previous owner or kids have filled the crankcase with petrol to the top! Refilled with engine oil and engine turns over pumping a lot of fuel out of the bore. Left it a while to evaporate and tried starting. Big mistake, the exhaust and air filter were full of fuel... BANG Abandoned for now, will take a look later when my ears stop ringing 1 WestwoodGazelle reacted to this Share this post Link to post Share on other sites
pmackellow 2,738 #2 Posted August 13, 2015 At least its red Mark... Share this post Link to post Share on other sites
nigel 1,881 #3 Posted August 13, 2015 if the float sticks on them it fills the sump with petrol mark Share this post Link to post Share on other sites
meadowfield 1,900 #4 Posted August 15, 2015 if the float sticks on them it fills the sump with petrol mark I think you might be onto something Nigel... Does anyone know if you can get the bits? I'm struggling to find anything, engine model 274826 doesn't show on the Briggs site... Share this post Link to post Share on other sites
Wristpin 400 #5 Posted August 16, 2015 Nigel's diagnosis is almost certainly correct - a common problem with gravity fed fuel systems. That Briggs number looks a bit suspect, can you post the full Model, Type and Code numbers?. Also, there should be an MTD model sticker either on the underside of the seat or on the chassis below the seat. Shouldn't be a problem with either the Briggs parts or the MTD / Lawnflite parts. Share this post Link to post Share on other sites
Stormin 4,458 #6 Posted August 16, 2015 Got a text off a mate about a Lawnflite. Having trouble getting a wheel off to mend a puncture. Taken out bolt that goes through axle, but wheel still won't come off. Rusted on maybe? Share this post Link to post Share on other sites
Stormin 4,458 #8 Posted August 17, 2015 That's what I thought, Nigel. Share this post Link to post Share on other sites
Wristpin 400 #9 Posted August 17, 2015 Got a text off a mate about a Lawnflite. Having trouble getting a wheel off to mend a puncture. Taken out bolt that goes through axle, but wheel still won't come off. Rusted on maybe? Easy to do all sorts of damage trying to get a bad one off. Quickest in the long run to drop the transaxle, split it and find someone with a press and push it out. Even then, make sure that you support the centre boss on the press bed and don't push against the rim. Seen fifteen tons on the gauge on a bad one! or repair the puncture / fil with OKO or similar / fit a tube with the wheel in situ ! Share this post Link to post Share on other sites
meadowfield 1,900 #10 Posted August 17, 2015 heres what i have if it's any help plus engine cowl sticker cheers Share this post Link to post Share on other sites
nigel 1,881 #11 Posted August 17, 2015 bits should be easy to get for that mark, what are you looking for, is it a 12hp have you a pict of the top of the cowling Share this post Link to post Share on other sites
Wristpin 400 #12 Posted August 17, 2015 That cowling sticker with family name numbers is a bit misleading, what is needed is the three sets of numbers under the words Model, Type and Code. On older engines they were stamped into the cowling above the spark plug , then later on a riveted on tag or on some overhead valve engines stamped into the rocker covers. if you should need engine parts they are essential. Share this post Link to post Share on other sites
meadowfield 1,900 #13 Posted August 17, 2015 I got the kids to take the pics, will see if they can find the plate. 272's used to be 11hp, but are now rated at 12hp nigel. It's a walbro carb it that helps? Share this post Link to post Share on other sites
Wristpin 400 #14 Posted August 17, 2015 Should have said, your 13AA number makes it a 2004 model 703. Parts should not be a problem . Lawnflites tend to be very fussy about belts - use genuine. Share this post Link to post Share on other sites
meadowfield 1,900 #15 Posted August 24, 2015 engine model 285H77 0252E1 040107ZE Share this post Link to post Share on other sites
meadowfield 1,900 #16 Posted August 24, 2015 woa... found the carb rebuild kit - 679241, been quoted £81.06 for it at my local dealer. sounds steep - how much should I be paying? Share this post Link to post Share on other sites
Wristpin 400 #18 Posted August 25, 2015 woa... found the carb rebuild kit - 679241, been quoted £81.06 for it at my local dealer. sounds steep - how much should I be paying? There were two carbs used on that engine Walbro and Nikki. The part number that you quote is for the o/h kit for the Walbro and is £51.15 inc vat Retail. There is a carb 794572 that can be used to replace either of the above £56.28 inc vat retail. Share this post Link to post Share on other sites
meadowfield 1,900 #19 Posted August 25, 2015 Thanks for the info, I order from the states at £28 all in... Just got to sit back and wait for international shipping! Share this post Link to post Share on other sites
meadowfield 1,900 #20 Posted September 4, 2015 Carb kit arrived Tuesday, carb rebuilt. Engine runs! But solenoid is shot and needs a battery too. Once you work out that it has to be in neutral, cutter disengaged, grass box on, sit on seat, etc.... You can make them work! I can see why so many people bypass the interlocks, it's a pain in the backside! You can't even reverse with the deck engaged!!! Anyway, we've had a cut out of it, and child no.1 seems to be up for adopting it, it's had a wash and polish! 4 Cub Cadet, diggerjames, Stormin and 1 other reacted to this Share this post Link to post Share on other sites
