wurzel 117 #1 Posted January 7, 2016 Hi heres a couple of pics of my homemade grader/dozer . The 2 blades see saw on a pivot under the front wheels the front blade works a treat for spreading gravel and the middle blade levels like a charm. The middle blade is just a piece of 4x2 chanel bolted on with 2 steel straps so it can be angled if required.I used the deck lift cylinder to move it up and down . It doesnt look pretty but i had to knock it up in a hurry to move 12 tons of gravel 3 Triumph66, nigel and Alan reacted to this Share this post Link to post Share on other sites
Chris 642 #2 Posted January 7, 2016 Looks like it does the job Never fancied a QT model. Stick to tube & large frame machines Share this post Link to post Share on other sites
Triumph66 1,256 #3 Posted January 7, 2016 Tidy job and does the job as designed. Share this post Link to post Share on other sites
harryt 281 #4 Posted January 7, 2016 Looks like it would do the job very well, a simple yet effective attatchment Share this post Link to post Share on other sites
wurzel 117 #5 Posted January 7, 2016 i originaly bought it as a spare engine for the 1886 (£200)the engine was reving up and down and the brakes didnt work 5 minutes adjusting the governer and an hour on the brakes it worked a treat .I love the sound of the engine on tickover so it has been reprieved nick 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #6 Posted January 7, 2016 Worth keeping the QT as you got it running sweet now. 1 wurzel reacted to this Share this post Link to post Share on other sites
wurzel 117 #7 Posted January 10, 2016 The qt17 is on the keeper list its too usefull 1 Triumph66 reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #8 Posted January 10, 2016 Hopefully you will some action in the snow ? If we get snow that is? 1 wurzel reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #10 Posted January 11, 2016 Supposedly coming later this week?..... 1 wurzel reacted to this Share this post Link to post Share on other sites
Triumph66 1,256 #11 Posted January 12, 2016 That's a Kohler engine in the QT? They are good looking machines and the implements are belt driven as opposed to shaft driven I think? 1 wurzel reacted to this Share this post Link to post Share on other sites
Ian 2,417 #12 Posted January 12, 2016 Nice work Nick, you can't beat simple home built attachments 1 wurzel reacted to this Share this post Link to post Share on other sites
wurzel 117 #13 Posted January 12, 2016 Hi Ian thanks for the compliment hi Andrew QT 17 has kohler KT17 standard Bolens front rear splined PTO with magnetic clutch for pto and cruise control on the hydro pedal same format in the DGT 1700 but also has power steering the newish looking rotovator in my gallery will fit both of them cheers nick Share this post Link to post Share on other sites
diggerjames 543 #14 Posted January 13, 2016 Simple but very effective I like it 1 wurzel reacted to this Share this post Link to post Share on other sites
