wurzel
Bolens QT17 home made grader/dozer
Hi heres a couple of pics of my homemade grader/dozer .
 The 2 blades see saw on a pivot under the front wheels
the front blade works a treat for spreading gravel and the middle blade levels like a charm. The middle blade is just a piece of 4x2 chanel bolted on with 2  steel straps so it can be angled if required.I used the deck lift cylinder to move it up and down . It doesnt look pretty but i had to knock it up in a hurry to move 12 tons of gravel
i originaly bought it as a spare engine for the 1886 (£200)the engine was reving up and down and the brakes didnt work 5 minutes adjusting the governer and an hour on the brakes it worked a treat .I love the sound of the engine on tickover so it has been reprieved
nick
Hi Ian thanks for the compliment
hi Andrew QT 17 has kohler KT17 standard Bolens front rear splined PTO with magnetic clutch for pto and cruise control on the hydro pedal same format in the DGT 1700 but also has power steering the newish looking rotovator in my gallery will fit both of them
cheers nick
