S1g 579 #1 Posted July 22, 2016 On a jap engine the exhaust outlet is threaded, it measures 2" or 50mm across the threads and has 19 threads per inch. Can anyone identify what it is please? Share this post Link to post Share on other sites
wurzel 117 #2 Posted July 22, 2016 if you google 19tpi it comes up as 1/4 bsp its either a none standard thread or a different tpi count cheers nick Share this post Link to post Share on other sites
C-101plowerpower 548 #3 Posted July 22, 2016 thinking its a non standard size, maybe the same as the coupling thread on a big union joint? Share this post Link to post Share on other sites
S1g 579 #4 Posted July 22, 2016 1 hour ago, wurzel said: if you google 19tpi it comes up as 1/4 bsp its either a none standard thread or a different tpi count cheers nick This is the problem I'm up against. I've used a very accurate set of thread gauges to arrive at 19 threads per inch. Every chart I've used doesn't seem to make sense. Due to my job I have access to allmost any bsp fittings so it defiantly isnt it. Thank you for your thoughts. I would of thought that jap would of used something off the shelf but I'm dammed if I can work out what. 1 wurzel reacted to this Share this post Link to post Share on other sites
wurzel 117 #5 Posted July 23, 2016 is it female or male your after you may have to cut your own Share this post Link to post Share on other sites
Anglo Traction 1,022 #6 Posted July 23, 2016 Hi Gareth, your right that it is not the standard BSP size, as everything (normally) over nominal 1" is 11TPI. I presume the inclusive thread angle is 55 degrees?. Is the Outlet a threaded insert, or part of a Casting?. I'm wondering if they machine cut the thread to a special size. A picture would be good if you can provide one. Share this post Link to post Share on other sites
expeatfarmer 591 #7 Posted July 23, 2016 Some of the threads on mG2 137 were like that , they turned out to be what are known as "cycle " threads from the bicycle manufacturing industry. Which would fit with 137 having a Sturmey Archer engine. Share this post Link to post Share on other sites
Wristpin 400 #8 Posted July 23, 2016 Very unlikely to be Cycle Thread in that diameter. No reference table for Cycle Thread goes any where near 2" . My guess would be a manufacturer's special. Share this post Link to post Share on other sites
S1g 579 #9 Posted July 23, 2016 11 hours ago, Anglo Traction said: Hi Gareth, your right that it is not the standard BSP size, as everything (normally) over nominal 1" is 11TPI. I presume the inclusive thread angle is 55 degrees?. Is the Outlet a threaded insert, or part of a Casting?. I'm wondering if they machine cut the thread to a special size. A picture would be good if you can provide one. Hi Richard I'll dig a photo out when I'm next at the unit. It is part of the casting. 10 hours ago, expeatfarmer said: Some of the threads on mG2 137 were like that , they turned out to be what are known as "cycle " threads from the bicycle manufacturing industry. Which would fit with 137 having a Sturmey Archer engine. Thanks for the suggestion, I've been able to identify all the other threads as either bsf or bsw, just drawn a blank with this one. 3 hours ago, Wristpin said: Very unlikely to be Cycle Thread in that diameter. No reference table for Cycle Thread goes any where near 2" . My guess would be a manufacturer's special. That's what I'm fearing, can't see why they would use a special thread. 12 hours ago, wurzel said: is it female or male your after you may have to cut your own It's a female thread that I need, I don't posses the skill to cut my own nut unfortunately. Share this post Link to post Share on other sites
expeatfarmer 591 #10 Posted July 24, 2016 Bicycle bottom bracket bearing cups are 2" and bigger> 1 S1g reacted to this Share this post Link to post Share on other sites
S1g 579 #11 Posted July 24, 2016 1 hour ago, expeatfarmer said: Bicycle bottom bracket bearing cups are 2" and bigger> Thanks for the information, i'll check it out. Share this post Link to post Share on other sites
Rocboni 257 #12 Posted July 24, 2016 I always use Maryland metrics to identify a thread https://mdmetric.com/thddata.htm Share this post Link to post Share on other sites
ranger 373 #13 Posted July 24, 2016 Have you tried on one of the vintage motorcycle forums ? Share this post Link to post Share on other sites
Anglo Traction 1,022 #14 Posted July 25, 2016 Don't know how old your engine is Gareth, but it look's like the low 250-650cc original early Jap engines onwards used the same size Exhaust Flange Nut?. I don't know if Villiers made any chnges ?. Could the TPI be 20?. and the outer dia across the threads be 2" or 50.8mm (actual). If so, then the Thread form could be BSF (0.0500" pitch and thread height of 0.032". This will give a Core dia (or Tapping diameter) of 1.937" (49.2mm). There appears to be a worldwide search by many for used versions, as the price of a new (manufactured) one is silly money. See this link where the numbers seem to merge ok if 20 tpi- http://de.vintage-motorcycle.com/index.php?language=en&site=4&pid=24&id=26427&limit=0 They can be made!. 1 meadowfield reacted to this Share this post Link to post Share on other sites
S1g 579 #15 Posted July 26, 2016 Hi Richard the engine is approx 1946, I believe this was before villiers involvement, I'll double check the threads when I back at the unit but I'm sure it was 19, couldn't get any other of the thread gauges to match. Share this post Link to post Share on other sites
