Anglo Traction 1,023 #1 Posted April 1, 2018 Asked if I could do something to save this Fuel Tap from an early 60s machine for a friend. I first tried to obtain the part as a spare from the manufacturers (Karcoma). They still produce them for various motorcycles etc . No parts available even though the design is pretty well unchanged. The original little screw on Filter Cup is plastic with a coin slot and hex end to undo it. A mistake in design really, as they are likely to be over tightened, I suppose as there are no spare parts, they can sell more for replacement (up to £35.00 each) - The cup is the 3rd fuel filtration process which will also separate and retain any water (small quantity) and has a small cylindrical filter which fits onto small spigots both in the cup and the Tap body, so I had to measure carefully to ensure it is not crushed when the Cup is screwed on, but that the seal doesn't leak. I settled for Brass to make it, which allowed me to do all the work and produce and insert the small internal spigot, then Hard solder it in the exact position. I also had to I.D. the thread form (metric 18 x 1mm) and cut it on the old Myford (imperial). After reading up on it, I had to do this by manual turning, as you can't disengage the 'Leadscrew' drive, or it will be misaligned!. All went well- Fortunately, there were only 4 full threads and it was the first time for me producing them. To finish it off, I produced a new sealing washer from reinforced Viton rubber of the correct thickness. To reduce the over tightening factor, I added a 'reeded' finger grip area on it, rather than a screwdriver slot etc. All finished ready for years of use- 6 factory, Cub Cadet, Triumph66 and 3 others reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted April 1, 2018 Really nice job there, Richard. I reckon your friend owes you a few beers. 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Alan 1,274 #3 Posted April 1, 2018 As Norm said. 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Rayp 48 #4 Posted April 2, 2018 It just reinforces the view that everything is now about money and the way of the world is why sell a rubber bush when you can sell a whole new bracket! Share this post Link to post Share on other sites
HeadExam 1,783 #5 Posted April 4, 2018 Great job Richard, send me your address, I'm sending a bucket of bits your way. 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,023 #6 Posted June 23, 2019 Don't usually like to revisit old Topics, but this Tap came back to haunt me. I started dripping fuel out of the Tap and apparently emptied the fuel out on the floor probably over last winter. Having concerns that my workmanship, or the materials I had used were at fault, I took it back to find the cause. Glad to say the bits I did were not faulty, but found the fuel was leaking out of the lever end. So I stripped it down on the understanding that if I can't fix it, they will have to replace the whole unit (if they can find one). Talk about over engineered!. Seven separate parts just for the tap lever control !, including a plastic type seal which had dissolved/rotted which was causing the leak- So as usual, I hit the challenge and went for making a replacement seal from fuel resistant 1.5mm thick nitrile/nylon reinforced rubber. I had to make 2 special punches that could cleanly punch through the tough layers and in the correct positions- Glad to say that when the cleaned parts were assembled and the tap fitted , there were no further leaks. Hope I've seen the back of this one now. 4 HeadExam, Stormin, Alan and 1 other reacted to this Share this post Link to post Share on other sites
