Steve2018 3 #1 Posted May 25, 2018 The manual lists both but says to use the resistor type due to some states having different laws (guessing this is just aimed at the US market) Would there be any difference in fitting the resistor type over the non resistor as that seems more readily available in the stores Currently the previous owner had a NGK BPMR6A fitted but the manual says to use a Champion J19LM or a NGK B2LM Its for a Lawnflite 504 ride on with a 8hp briggs and stratton engine Thanks Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted May 25, 2018 Not sure what you mean by resistor or non resistor. I'd get the Champion J19LM or NGK B2LM. Share this post Link to post Share on other sites
Sammoore13bolens1053 11 #3 Posted May 25, 2018 2 hours ago, Steve2018 said: The manual lists both but says to use the resistor type due to some states having different laws (guessing this is just aimed at the US market) Would there be any difference in fitting the resistor type over the non resistor as that seems more readily available in the stores Currently the previous owner had a NGK BPMR6A fitted but the manual says to use a Champion J19LM or a NGK B2LM Its for a Lawnflite 504 ride on with a 8hp briggs and stratton engine Thanks Get the nam, resistor ones are the ones with th ‘r’ in the name, they probably help somehow. I’d say stay away from champion, not taht goodin my experience Share this post Link to post Share on other sites
Anglo Traction 1,018 #4 Posted May 25, 2018 Spark Plugs with resistors are for reducing or eliminating 'ignition noise' and removing 'Peaks' in current which can have a detrimental affect on running. Should be used where specified. For example, using Non- resistor Plugs can cause erratic Idle, misfires at higher rpm, overrun (pre-ignition), abnormal combustion and power drop at certain speeds. It all depends on the application etc. Ignition noise affects electronics in the vicinity of the engine i.e transistorised electronic ignition, phones and other equipment. Make of Plug is personal choice and personally, I use both NGK and Champion and never (50 years) had any fail, but replace when felt necessary. Share this post Link to post Share on other sites
nigel 1,881 #5 Posted May 25, 2018 Br2lm have resister b2lm don’t, I use both in those engines both run exactly the same Share this post Link to post Share on other sites
Steve2018 3 #6 Posted May 25, 2018 (edited) Thanks all I went with the Resistor type NGK resistor gapped to 0.76mm as it was the easiest one to get hold of Just need to stick my new filter on (the one on now is falling to bits) new breather tube on (a mouse chewed through the one on the engine) and new oil breather gasket Edited May 25, 2018 by Steve2018 1 Anglo Traction reacted to this Share this post Link to post Share on other sites
Wristpin 400 #7 Posted May 25, 2018 Quote Spark Plugs with resistors are for reducing or eliminating 'ignition noise' and removing 'Peaks' in current which can have a detrimental affect on running The only reason that resistor plugs are specified in some markets is to comply with that market's electrical interference legislation, not anything to do with the performance of the engine. (Quoting a well-known engine manufacturer) The thing to avoid is using a resistor plug where there is already a resistor plug cap - then there can, but not always, be erratic performance. Said engine manufacturer normally supplies HT leads with a plain non-resistor (unsuppressed) plug connector; hence them specifying a resistor plug for certain markets. Share this post Link to post Share on other sites
HeadExam 1,783 #8 Posted May 25, 2018 On a side note, the Champion plugs worked great in older engines, but do not seem to be as as proficient in newer fuel injected or new design types of engines. I run Champion plugs in my old chainsaws and garden tractors and they run great and burn clean, but I wouldn't put them in my old Volvo 850 or a newer vehicle or engine. Share this post Link to post Share on other sites
Anglo Traction 1,018 #9 Posted May 26, 2018 14 hours ago, Steve2018 said: Thanks all I went with the Resistor type NGK resistor gapped to 0.76mm as it was the easiest one to get hold of. Yep!, if it's recommended, then probably the best way to go. I don't know how old your machine/engine is, but B&S quoted the use of both types Res/non Resistor type Plugs, depending on application. This is according to the 1981 version of the workshop Manual. Modern engine versions in various categories are a different story (Vehicle, Non road, handheld etc), so it's good to see you checked the requirement and asked the question. 13 hours ago, Wristpin said: The only reason that resistor plugs are specified in some markets is to comply with that market's electrical interference legislation, not anything to do with the performance of the engine. (Quoting a well-known engine manufacturer). Yep! Legislation has a lot to do with it and interference is another word for Ignition Noise. Many of us can remember the interference on our old 405 line Tellys when an Un-suppressed car went past the house!. At the end of the day, manufacturers specify a particular type and we ignore this at our own (possible) cost. We have to choose who we want to believe, either modern Vehicle engine manufacturers, or Spark Plug manufacturers as to what the (possible) causes of performance issues are from incorrect application- -NGK- Kohler Manual also specified Non and Resistor types (as at revision 1992), but also quoted 'RH' for all (then current) models, which may well be as a result of legislation. 1 HeadExam reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #10 Posted May 26, 2018 3 hours ago, Anglo Traction said: Many of us can remember the interference on our old 405 line Tellys when an Un-suppressed car went past the house!. 1 HeadExam reacted to this Share this post Link to post Share on other sites
squonk 71 #11 Posted May 27, 2018 In the 60's every time a Ford went by the house the TV would get fuzzy. 2 Anglo Traction and HeadExam reacted to this Share this post Link to post Share on other sites
HeadExam 1,783 #12 Posted May 27, 2018 2 hours ago, squonk said: In the 60's every time a Ford went by the house the TV would get fuzzy. Still does, 1 1 Anglo Traction and squonk reacted to this Share this post Link to post Share on other sites
Ransomes256 19 #13 Posted July 18, 2018 Not wishing to be to controversial but my experience shows more capacitor failures with a magneto ignition if used with a resistor plug or a suppressor cap which has the same affect. Look at http://www.brightsparkmagnetos.com and see the results obtained with a controlled test. Resistor plugs OK with coil ignition. Neil Share this post Link to post Share on other sites
Wristpin 400 #14 Posted July 18, 2018 46 minutes ago, Ransomes256 said: Not wishing to be to controversial but my experience shows more capacitor failures with a magneto ignition if used with a resistor plug or a suppressor cap which has the same affect. Look at http://www.brightsparkmagnetos.com and see the results obtained with a controlled test. Resistor plugs OK with coil ignition. Neil That’s an interesting observation. I’ve always associated condenser failure to be age related rather than resulting from any other influence.These days I rarely work on anything with an exterior ignition coil , slightly more often on machines with exterior “ platform” magnetos and the bulk of the time on flywheel magnetos. I do change a lot of condensers on the latter group but then they are usually 50+ years old. Not sure. This lot have been changed in the past 15 months or so. Share this post Link to post Share on other sites
