Stormin 4,458 #26 Posted October 25, 2018 We'll make an engineer/machinist of you yet. 1 the showman reacted to this Share this post Link to post Share on other sites
Alan 1,274 #27 Posted October 25, 2018 Looks good Chris. 1 the showman reacted to this Share this post Link to post Share on other sites
the showman 4,074 #28 Posted October 27, 2018 Got some more done and the first thing to do was change the fixing bracket, as the blower is pre 1973 it had a long 3/8" nut and bolt to bolt it to the frame of the tractor. I drilled out the hole to 5/8" and used a solid bar so that I can use the quick hitch, also cleaned and primered a few more parts. The parts box is almost empty but I'm missing a rod that fits on the chute to adjust the aim so that will be the next job. 3 Cub Cadet, Stormin and Alan reacted to this Share this post Link to post Share on other sites
the showman 4,074 #29 Posted October 29, 2018 There seems to be a difference on length on the mounting bracket between the bolt on and the quick hitch of 4 inches so I had to mod the bracket, luckily it's shorter and I hadn't painted it. I drilled a couple of more holes and welded another 5/8" bar on, I will cut off the excess tomorrow. 3 Alan, Cub Cadet and Stormin reacted to this Share this post Link to post Share on other sites
the showman 4,074 #30 Posted October 30, 2018 Didn't get as much done as I hoped today. First job was to cut down the mounting bracket and clean up then I noticed the chute aim adjuster was missing so more fabricating needed. By the time I finished that it was too late to paint as the temperature was dropping. 4 Alan, Stormin, Triumph66 and 1 other reacted to this Share this post Link to post Share on other sites
the showman 4,074 #31 Posted November 3, 2018 Today's plans went out the window so I spent some time in the shed, now I've got a load of red bits hanging up. 3 Stormin, Alan and Cub Cadet reacted to this Share this post Link to post Share on other sites
the showman 4,074 #32 Posted November 5, 2018 The paint has dried enough to get a few more bits bolted on, the driveshaft and chain sprocket with the new bearings fitted. i can now fit the new chain and align the other sprockets, hope to get the mounting bracket and drive belt pulleys on today 4 Alan, Scottwilson, nigel and 1 other reacted to this Share this post Link to post Share on other sites
the showman 4,074 #33 Posted November 8, 2018 Fitted a few more bits on, after fitting the chain and aligning the sprockets I found the bracket to hold the chain guard on missing and as it's now painted I didn't want to weld something on so I just made one and bolted it on. I don't really want to do much more now until I get it off the bench and fitted to a tractor as its quite heavy. 3 Cub Cadet, Stormin and Alan reacted to this Share this post Link to post Share on other sites
the showman 4,074 #34 Posted November 12, 2018 Made some good progress today after getting it off the bench, i put it on a sack trolley and got it from the workshop to under the carport. It was quite easy to fit it into the quick hitch on the front of the Raider 12, the flag was easy to fit on the lift lever and all I had to do was put a 1/2" spacer on the lift rod to get a bit more height. The next hour was spent looking through all my belts and was lucky to find one that fitted. Bolted some more bits on so the parts box is almost empty and as darkness fell I fired the tractor up and ran the blower, spinning well and fast and the best bit the right way. 4 harryt, Cub Cadet, Alan and 1 other reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #35 Posted November 12, 2018 Looks good, Chris. Now all you need is snow. Share this post Link to post Share on other sites
Alan 1,274 #36 Posted November 12, 2018 1 hour ago, Stormin said: Looks good, Chris. Now all you need is snow. Or take it down to the beach and see how far the sand, or the pebbles go. 1 Stormin reacted to this Share this post Link to post Share on other sites
the showman 4,074 #37 Posted November 13, 2018 19 hours ago, Alan said: Or take it down to the beach and see how far the sand, or the pebbles go. Bit late for sand blasting now I’ve painted it. 1 Alan reacted to this Share this post Link to post Share on other sites
