factory 487 #76 Posted November 6, 2019 18 hours ago, Wallfish said: there's one for $9 + $3 shipping. Those aluminum pieces are fairly easy to clean up and make nice. https://www.ebay.com/itm/Sears-Mighty-Light-Orline-Chainsaw-OEM-Plate/151651948770?hash=item234f2918e2:g:5EQAAOSwPgxVL~yf Is this the one you were looking at? That was the same item I posted, just without all the extra keywords & random letter/number gibberish that ebay URL's give. 22 hours ago, JUST O&R said: David thanks I tried to buy them from him he has two on there but he would not deal. I bought a few bits from them about 4 or 5 years ago* when the currency conversion rate was cheaper, they were happy to combine shipping but that was all, low value listings like these don't make for sellers (with all the ebay fees, paypal fees, etc), hence why they can't do much for a deal. David *Hence my earlier comment about looking closely at the condition of the parts, some of which are damaged or very corroded. Share this post Link to post Share on other sites
JUST O&R 237 #77 Posted November 6, 2019 I know by the time you pay ebay and paypal they eat you up but they have been on there for some time not Evan combined shipping. but Ill have an extra . Share this post Link to post Share on other sites
factory 487 #78 Posted November 8, 2019 They have only been on there a long time because they weren't listed with Ohlsson & Rice in the title, always good to have spares of those as they are so often missing, despite what the service bulletin says. David Share this post Link to post Share on other sites
JUST O&R 237 #79 Posted November 8, 2019 (edited) Ya OK WHY ARE THERE SO MANY MISSING ? You don't normally loose the block Edited November 8, 2019 by JUST O&R 2 factory and Wallfish reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #80 Posted November 9, 2019 Can anyone tell me if these is the same gearbox as the j- II ser 091196 ?? O&R 196.pdf Share this post Link to post Share on other sites
factory 487 #81 Posted November 10, 2019 On 11/8/2019 at 9:49 PM, JUST O&R said: Ya OK WHY ARE THERE SO MANY MISSING ? Usually the original or previous owner takes it apart after something like the starter mechanism breaks and before the web existed they probably couldn't get parts (after O&R/AEP closed down), or figure out how to get it back together, so left it in bits or never put them back on. On 11/9/2019 at 5:12 PM, JUST O&R said: Can anyone tell me if these is the same gearbox as the j- II ser 091196 ?? I will check my info and let you know. David Share this post Link to post Share on other sites
factory 487 #82 Posted November 10, 2019 Yes the Type 196 has the same gearbox as a Model JIII (900 R.P.M. reduction, counter clockwise PTO shaft), but the Type 196 engine has a back-shaft with a flat, part no #42-49. David. Share this post Link to post Share on other sites
JUST O&R 237 #83 Posted November 10, 2019 (edited) Thanks David this is the engine I used to repair the toby cart . A lot of good parts just would like to ad numbers to the parts before I put them in a box . Most of my inventory is in the computer The gear boxes are not in the most of the parts breakdowns . Thanks for the help before I got this post done you already replied . That's awesome Your the best Edited November 10, 2019 by JUST O&R 1 factory reacted to this Share this post Link to post Share on other sites
factory 487 #84 Posted November 10, 2019 I've edited my last post as the Type 196 has a back-shaft with flat. I have two pages from 1964 covering older gearboxes, it's too late tonight to add them to the forum. David Share this post Link to post Share on other sites
JUST O&R 237 #85 Posted November 11, 2019 On 11/5/2019 at 9:07 PM, Wallfish said: there's one for $9 + $3 shipping. Those aluminum pieces are fairly easy to clean up and make nice. https://www.ebay.com/itm/Sears-Mighty-Light-Orline-Chainsaw-OEM-Plate/151651948770?hash=item234f2918e2:g:5EQAAOSwPgxVL~yf Is this the one you were looking at? The worst parts was getting the model ans serial numbers off. 1 factory reacted to this Share this post Link to post Share on other sites
CNew 408 #86 Posted November 11, 2019 That’s pretty cool, I hadn’t seen one all polished up like that - that’ll add s little bling to the board... Share this post Link to post Share on other sites
factory 487 #87 Posted November 12, 2019 Looking nice, I'm surprized they weren't polished up like that on the Chromer chainsaw @Webhead has. David Share this post Link to post Share on other sites
factory 487 #88 Posted November 12, 2019 On 11/10/2019 at 11:09 PM, factory said: I have two pages from 1964 covering older gearboxes, it's too late tonight to add them to the forum. Parts diagrams for the gear case models from 1964 have been cleaned up, turned into a PDF and added to the manuals 'sticky' thread. Note: there may be slightly different parts used in earlier or later gear-cases, for example alloy gears in earlier models, the flat 'D' shaft used for the later clutch (instead of tapered shaft) and updated bearings. I've only just noticed part of drawing for the clutch assembly has a bit of the print missing, I checked and the original (below) is the same. David Share this post Link to post Share on other sites
JUST O&R 237 #89 Posted November 12, 2019 Just takes a little time after grinding the numbers off had to do something. I couldn't leave the numbers on it you Can't have a engine with two sets of number . talk about being confused . Thanks David for the diagrams that will help . Would like to tag this parts as I put them in a box Share this post Link to post Share on other sites
JUST O&R 237 #90 Posted June 9, 2020 Well she's down off the shelf and on the counter . need to check it over and get some extra insurance ( just in case ) I hate to put fuel in it because I will have to take the carb back off and clean it . but its on like donkey Kong now !!!! Need to figure out how to put seat belts on her and away will go. 1 Wallfish reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #91 Posted June 9, 2020 Not like diving a mini bike this thing wont turn but it does barn rubber. IMG_3820[1].MOV 2 CNew and Wallfish reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #92 Posted June 9, 2020 The other thing don't put a 240lb man on a kids toy cracked the motor bracket a little . weight limit 45 lb besides that it hard to get up 1 Wallfish reacted to this Share this post Link to post Share on other sites
Wallfish 719 #93 Posted June 9, 2020 Bravo! I was hoping that challenge would get ya on it. That's good stuff! But I thought you were going stand up on it and do some skateboarding tricks like this. Alright Clint, get your man hole fan out, it's your turn Share this post Link to post Share on other sites
JUST O&R 237 #94 Posted June 9, 2020 I tried to standup that's when I found the crack in the engine bracket would not drive belt was slipping not much for a bracket thin alloy not very stout . IMG_3825[1].MOV Share this post Link to post Share on other sites
CNew 408 #95 Posted June 10, 2020 Ha ha, now this is getting good! I’ve been looking forward to seeing this all day! That Toby Cart looks fun and sounds good too- nice work getting it all fixed up. Cracked me up, too funny! You guys are awesome! That fan bicycle concept looks interesting. Maybe I can rig up some backpack straps and give it a go sometime. Share this post Link to post Share on other sites
Wallfish 719 #96 Posted June 10, 2020 8 hours ago, CNew said: That fan bicycle concept looks interesting. Maybe I can rig up some backpack straps and give it a go sometime. Sometime? Now all the video pressure is on you. Looks like Terry beat my land speed record so I'll get the bike tuned for the street and give it another go this weekend 1 1 CNew and JUST O&R reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #97 Posted June 10, 2020 5 hours ago, Wallfish said: Now all the video pressure is on you. I got a $20 sees he won't do it 1 Wallfish reacted to this Share this post Link to post Share on other sites
SoCalFD 1 #98 Posted August 2, 2021 Hey guys. I’ve been going through some of my Dad’s old stuff and came across this Toby Cart board. Obviously it has seen better days! It has been exposed to the elements here in California for a good 20 years. My father has owned it since the 60’s, it was complete and functional into the 80’s, but burglars stole the motor. As you can see, the aluminum parts are there. Everything is original. The front trucks are frozen, one side handle is missing. The throttle plate on the nose is there. The board is split, but can be used as a pattern to make a new board. The throttle rod is not pictured, but I do have it. It’s rusty, and appears to be cut when the clowns stole the motor unit. Does someone need spare parts? My dad told me these are rare. My web search led me here, so I thought I’d give it a shot. 1 JUST O&R reacted to this Share this post Link to post Share on other sites
JUST O&R 237 #99 Posted August 2, 2021 Not much left of that is there any of the motor brackets ? Its to bad that it was cannibalized like that. Share this post Link to post Share on other sites
SoCalFD 1 #100 Posted August 3, 2021 16 hours ago, JUST O&R said: Not much left of that is there any of the motor brackets ? Its to bad that it was cannibalized like that. This is all that’s left, besides the throttle rod. Share this post Link to post Share on other sites
