Stormin 4,458 #1 Posted February 21, 2014 Some will recall this Wheel Horse C-81. Bought in the condition you see it. Nicely done by Martin Hurst, who I bought it off well over a year ago. Unfortunately progress has been somewhat slow. Actually practically none existent due to other factors. But hopefully in the next week or so things will progress. Share this post Link to post Share on other sites
pmackellow 2,738 #2 Posted February 21, 2014 Looks great so far, bet it will look A1 once finished !! Share this post Link to post Share on other sites
meadowfield 1,900 #3 Posted February 21, 2014 I remember it, I saw it just as Martin had built the new hood stand. Looking good now, once the weather picks up I'm sure you'll be on the case... We want to see it at the wheel horse round up! Share this post Link to post Share on other sites
bowtiebutler956 166 #4 Posted February 21, 2014 Wow, thats goint to be one Gorgeous machine!! Look forward to seeing your progress. Matt Share this post Link to post Share on other sites
Stormin 4,458 #5 Posted May 28, 2014 Not managed to get much done, but hopefully get the tin ware back from painting by tomorrow. Then a push to get it ready for Newby. Share this post Link to post Share on other sites
meadowfield 1,900 #6 Posted May 28, 2014 Hurry up and stop gassing then Look forward to seeing it... Share this post Link to post Share on other sites
Stormin 4,458 #7 Posted May 28, 2014 I'm looking forward to it finished. Can't do anymore till the panels are back. Memo to self. Must get a battery. Share this post Link to post Share on other sites
the showman 4,074 #8 Posted May 28, 2014 Yeh, don't forget the battery Norm. you don't want to push it to Newby, at least its down hill from up there Share this post Link to post Share on other sites
the showman 4,074 #9 Posted May 28, 2014 The HT lead looks a bit long Norm, might make the motor run a bit retarded, do you want me to bring you a shorter one to Newby ? 1 meadowfield reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #10 Posted May 28, 2014 I know it's a bit long. I've got plenty HT wire thanks. Share this post Link to post Share on other sites
diggerjames 543 #11 Posted May 28, 2014 Looking good nice to see it done James Share this post Link to post Share on other sites
WestwoodGazelle 103 #12 Posted May 28, 2014 Good luck with your project! Looks like she'll be a great 'Horse when done. Share this post Link to post Share on other sites
Stormin 4,458 #13 Posted May 29, 2014 Panels won't be ready till the weekend. I'm busy Sat and Sun. I can see this getting finished at Newby, cos it's going running or not. Share this post Link to post Share on other sites
the showman 4,074 #14 Posted May 29, 2014 That's not good Norm, bring it in boxes, there's enough of us to screw it together Share this post Link to post Share on other sites
Stormin 4,458 #15 Posted May 29, 2014 That's what I was thinking. Someone will know where the bits go that I can't work out where . Share this post Link to post Share on other sites
Stormin 4,458 #16 Posted June 3, 2014 Well I managed to get a bit more done today. First The start of play this morning. Rear fender and seat fitted. Dash and control cables fitted. More panels on. Electrics to sort out and then see if I can get it to run. That's for tomorrow. 2 Ian and pmackellow reacted to this Share this post Link to post Share on other sites
Ian 2,417 #17 Posted June 3, 2014 She's looking good Norm, the finish must be in sight.. and then onto the next project Share this post Link to post Share on other sites
Stormin 4,458 #18 Posted June 3, 2014 Still several details to see too, touch up here and there and decals to apply, but that will be most likely after Newby. Some accidental damage to the paint on the hood when one of the dogs knocked it over. Share this post Link to post Share on other sites
Ian 2,417 #19 Posted June 3, 2014 Accidental damage is all part of the game unfortunately Norm, I managed to drop a starter motor on the hood of my 6x6!! Share this post Link to post Share on other sites
meadowfield 1,900 #20 Posted June 3, 2014 Looking great Norm Share this post Link to post Share on other sites
pmackellow 2,738 #21 Posted June 3, 2014 Top job Norm Share this post Link to post Share on other sites
diggerjames 543 #22 Posted June 3, 2014 Looking good norm Share this post Link to post Share on other sites
Stormin 4,458 #23 Posted June 4, 2014 Got the electrics sorted with the help of an electrical clued up friend. I really should say, he sorted them out. Put petrol in and started to turn it over. And over, and over. Didn't even cough. Took the fuel pipe off the pump and I gave it a little suck to pull fuel through. It came through alright and I certainly coughed. Pipe back on still no joy, so I poured a bit of petrol into the carb. It soon fired up after a short crank. It won't run right though. Keeps stopping and won't run without some choke jigging. Give it some throttle and it will die. I suspect dirt in the carb or maybe flooding. I'll have a look in the morning. One thing I've noticed, no main mixture screw on the top. Looks like it's been snapped off. Share this post Link to post Share on other sites
diggerjames 543 #24 Posted June 4, 2014 It might have been screwed in full and snapped off Share this post Link to post Share on other sites
meadowfield 1,900 #25 Posted June 4, 2014 Norm, We've all been through the same issues! Firstly the tank is a long way away from the carb, the pump has to work hard. The first thing to check is the pump, undo the two screws and take it off the engine. Split it and give it a clean, checking the diaphragms aren't split and the seats are clean. You can check the seal by pumping with your finger over the end. My sons is shot and we put and electric pump on to prime it. If you're happy it's ok, then check the carb, give it a good clean and set up as per the kohler manual. If necessary buy a rebuild kit with the new float gasket, etc. If you don't have time in the next day, then it might be a task for the weekend Cheers Mark Share this post Link to post Share on other sites
