The Blues Brothers 19 #1 Posted May 15, 2021 Having an inspection of the latest 1032 to arrive at the workshop. Can anybody tell me what's growing in the seat 1 4x4forks reacted to this Share this post Link to post Share on other sites
Stormin 4,458 #2 Posted May 15, 2021 A much closer photo would help. Share this post Link to post Share on other sites
The Blues Brothers 19 #3 Posted May 15, 2021 Thanks for your comments will be uploading more photos Here is the close up Share this post Link to post Share on other sites
Jarrovian 237 #4 Posted May 16, 2021 I reckonise that trailer in first picture but will not spoil the fun Share this post Link to post Share on other sites
mattblack 76 #5 Posted May 16, 2021 Looks like a Nettle? Probably not what you want growing on a seat... Share this post Link to post Share on other sites
The Blues Brothers 19 #6 Posted May 16, 2021 It's a big nettle now. Theres more than a nettle on this tractor the chassis full of snail shells an hundreds of them even under the seat clear outs required. Share this post Link to post Share on other sites
The Blues Brothers 19 #7 Posted May 27, 2021 Found the engine wasn't turning over all the way was locking up. Anyway decided to investagate the problem the exhaust valve was stuck shut Whipped the head off loads of carbon. The engine now has been decoked and valve's have been cleaned. Engine back in new chassis. Then have to completely rewire the hole tractor. Need some new parts now New parts have been arriving daily the latest to arrive are set front indicators. Share this post Link to post Share on other sites
The Blues Brothers 19 #8 Posted May 27, 2021 (edited) Why can't people fix thinks properly. Been fixed now and new a tube been fitted Edited May 27, 2021 by The Blues Brothers Share this post Link to post Share on other sites
The Blues Brothers 19 #9 Posted May 27, 2021 Found more snail shell under the seat thats all I keep finding. Share this post Link to post Share on other sites
Stormin 4,458 #10 Posted May 27, 2021 Don't think that engine has ever had a decoke. What is the cylinder bore like? Share this post Link to post Share on other sites
The Blues Brothers 19 #11 Posted May 27, 2021 Thanks for you comment stormin the cylinder and bore appears to be very slightly scored this tractor hasn't be running for 10yrs But it will come alive again over the next few weekends.. Some new parts arrived today replacement indicators Share this post Link to post Share on other sites
The Blues Brothers 19 #12 Posted May 30, 2021 Great weather on Saturday work continues on Gutbrod 1032 refitted top of the transmission tunnel with steering column and new brass brushes fitted into socket Next job to tackle was to refit the swivelling rear hitch Share this post Link to post Share on other sites
The Blues Brothers 19 #13 Posted May 30, 2021 The next job was to fit dashboard surround and fit petrol tank bracket battery tray. Refit rear lift frame then refit petrol tank. Refit the all the odds and connector up clutch brake pedals Share this post Link to post Share on other sites
The Blues Brothers 19 #14 Posted May 30, 2021 The day was coming to an end fitted the mud wings That's all folks stay safe enjoy the rest of the Bank holiday weekend Hame time now. 2 Stormin and Anglo Traction reacted to this Share this post Link to post Share on other sites
Anglo Traction 1,023 #15 Posted May 30, 2021 Very nice project you have there. Good machines. The top cylinder condition is very familiar to me from past experiences (and current ones). Certainly better condition than the sort I get. Keep to updates coming . Share this post Link to post Share on other sites
The Blues Brothers 19 #16 Posted June 5, 2021 Here we are back at the workshop today starting to find out why we have no spark at the plug Started to remove front mask to get into the point Starting to remove flywheei Have now removed flywheel found more snail Here I have got to the bottom of the problem points dirty so whipped them out will clean them later. Replaced them with new points. 1 Stormin reacted to this Share this post Link to post Share on other sites
The Blues Brothers 19 #17 Posted June 5, 2021 New points have been gapped new sparkplug gapped Started to rebuild front of the engine Share this post Link to post Share on other sites
The Blues Brothers 19 #18 Posted June 5, 2021 now its time to see if the engine will spark and bypass the fuel tap and fuel pump needs cleaned out pipe work full of old crap That will be the next job to overhaul the fuel pump and tap leaks. Sparkplug is sparking now to put a small amount of fuel down plug hole Yes it offered to fire. I just tied a spare old fuel tank that was kicking about the workshop connected up fuel lines and it now running. That's enough for today still more to do the next few weekends 2 Stormin and Maxwell-8 reacted to this Share this post Link to post Share on other sites
Maxwell-8 9 #19 Posted June 5, 2021 How is the steering on it? Wasn't that a weak point too? Share this post Link to post Share on other sites
rolloman 1 224 #20 Posted June 6, 2021 Hello Maxwell- 8 Welcome to the forum I am interested on your comments about the Gutbrod Tractor on here, this is one of 7 my brother and I own, I have had my own tractor since i was 14 and have found them fantastic little tractors. I use my tractors all the time also use them at Ploughing matches and have never found any weakness in them quite the opposite fact they seem to be unstoppable are you speaking from experience or some thing you have read ? 1 Maxwell-8 reacted to this Share this post Link to post Share on other sites
Jarrovian 237 #21 Posted June 7, 2021 I like your comment on the Old Tank kicking about the workshop which looks remarkebly like my tank off my Kohler K141 T engine from my Howard 350 so do not lose it Share this post Link to post Share on other sites
Maxwell-8 9 #22 Posted June 7, 2021 12 hours ago, rolloman 1 said: Hello Maxwell- 8 Welcome to the forum I am interested on your comments about the Gutbrod Tractor on here, this is one of 7 my brother and I own, I have had my own tractor since i was 14 and have found them fantastic little tractors. I use my tractors all the time also use them at Ploughing matches and have never found any weakness in them quite the opposite fact they seem to be unstoppable are you speaking from experience or some thing you have read ? Could once buy a 312 and gutbrod with renault engine. It had flopping steering and floppy transshifter. Was the same as a WH D250. But apart from that, Gutbrod are good machines. Had my first riding mower when I was 15-16. And my first garden tractor (raider10) november 2020. I have 2 GT's and i am 19 years old. Hard to find affordable GT's in Belgium as most gardens are to small for one. Share this post Link to post Share on other sites
The Blues Brothers 19 #23 Posted June 27, 2021 After a bit of searching now have Road legal number plates. Now have new warning lamps 1 Stormin reacted to this Share this post Link to post Share on other sites
The Blues Brothers 19 #24 Posted July 10, 2021 Number plates fitted, New log book arrived, 1 Stormin reacted to this Share this post Link to post Share on other sites
The Blues Brothers 19 #25 Posted August 14, 2021 New seat fitted first class job done by first class seat upholstery done By local company in Edinburgh Number plate now fitted this project is now comming to an end soon 2 Maxwell-8 and Stormin reacted to this Share this post Link to post Share on other sites
