we don't come on here very often, if you have facebook, come onto the wheel horse owners uk page. One of us will help you!
As usual - rather splendid work Richard!
Good pics Norm, shame I missed you!
late to the party, we've welded two of these successfully... there are all just tacked! presumably to break the fork instead of something else when you swing on it!
the more I see, the more I'm astounded! such awesome engineering!
wow - that is amazing work Richard!
Ewan doesn't get on here much like me - we are in so many groups and forums is impossible to keep up! He's currently in the process of building a 1984 range rover - almost from scratch as the titanic probably has less rust!!!!
quick video - it sounds good inside, but theres a lot of squeaks and rattles....
it sounds really good on the outside
late to the show - happy Birthday old boy!
Need to get the kids to film me
could do!
what width do you want Norm?
After building a few monster tractors - I got bored and went big...
6 litre, 6 cylinder, straight pipe and a turbo... 😁
Been a while since I updated things...
firstly new rubber!
after getting the wheels powder coated I stuck a new set of 6-12 on. I couldn’t find another Dunlop ag tyre.
Ewan fixed the hood... made a smart job, where it had been butchered
then this happened.
I made a three point for the back.
then this 😀
the IH club helped me get the original number plate. Registered in Carlisle in 1964.
I painted a plate in scale with the tractor. Not legal, but I’m hardly likely to drive it on the road...
Still need to sort a trip darn south to see Chris and pick up that engine. Then I can think about adding hydraulic lift 😁
in the meantime I’m planning a pto on the back...
they aren't that hard to fix, though that input shaft is the first thing you put in when you are re-assembling - so the last thing to come out
happy to guide you and tell you what bearing and seal you need if you fancy a go... I've just rebuilt one two months ago.
pulling the hubs is the hardest bit though... then a 9/16" spanner splits the case and it's easy after that.
Hey Doug, good to have you back - nice work!
Sorry to hear you've been having a rough time
if you are stuck removing them...
here is the easy way, though this one needed 6 tons and a lot of heat!
yours looks like mk3, we've done quite a few sets of 8hp 28"
Assume it has lights on the dash? - hard to tell from the pic...
I suspect hubs will be your first challenge, just popped one on a C-121, 5 mins of heat and 6 tons of pressure to budge it!
reading the brochure... Only 3 models on Mk2 . W8R, W8E and W11E - all 36" deck.
So when did 28 and 32" decks become options? Mk1 or Mk3?
whatever the issue, you need to strip it. It could be a selector fork worn or bent...
fab stuff,
so can we say mk1 had flat footrests and central gear select before moving to column change and sloping footrests?
I note the main dash decal stayed the same for quite a while, but the ignition, lights and warning decals changed a few times?
